door sensor executie trigger
Mon May 14, 2012 10:25 am
henkjanvries offline
Hi
I've been playing with a door sensor of klikaanklikuit with the rfxcom plugin.
i see changes in state when not connected etc, but i want to execute a trigger when the door is open. But in the trigger section i can't choose the rfxcom plugin as trigger.
is there a reason for this, or am i looking at it the wrong way?
i hope someone has a answer.
HenkJan
Mon May 14, 2012 10:43 am
Re: door sensor executie trigger
Are you selecting the Device State Changed trigger type? Once you do that, you should see the states available for those devices.
