Losing connection to RFXtrx device
My Indigo Pro 5.1.1. log shows;
"RFXCOM serial port" serial port open error: could not open port /dev/cu.usbserial-02VEMM2E: [Errno 2] No such file or directory: '/dev/cu.usbserial-02VEMM2E'
RFXCOM Error make sure the USB virtual serial port driver (ex: FTDI driver) is installed and correct port is selected
RFXCOM Error serial port could not be opened
and in the RFXCOM plugin i can now ONLY see the(USB-SerialPL2303-0000103D) port used by CM11
But I had it running before did some NEXA Dimmer installations that worked …... But then a did a MAC OS update to 10.7.4 and now i get this errors
and in ls /dev/cu.* all I get is the following;
koks-datorn:dev familjen$ ls /dev/cu.*
/dev/cu.Bluetooth-Modem /dev/cu.PL2303-0000103D
/dev/cu.Bluetooth-PDA-Sync /dev/cu.SerialPort
I have tried to reinstall the FTDI VCP driver , but not luck,
(running on Macmini with VCP FTDI 2.2.17 (64bit)
Please advice me how to get this fixed
Thanks in advance
Lars Lidström
