New version of the RFXTRX Plugin available
Tue Jul 07, 2015 12:45 am
Re: New version of the RFXTRX Plugin available
Thanks for the suggestions :D
Mon Jul 13, 2015 10:08 pm
Fishysan offline
Hi b_weijenberg,
Having everything up to date, I am getting the error below at various times.. with no particular pattern. Ideas? Thanks!
Indigo 6.1.2
RFXCOM plugin 1.6.3
RFXtrx v190
OS X 10.10.4
RFXCOM initializing communication on port /dev/cu.usbserial-004014FD at speed 38400
RFXCOM connected to RFXtrx 433.92 MHz, firmware version 190
RFXCOM currently enabled receiver protocols: La Crosse, Oregon Scientific
RFXCOM enabling receiver protocols: Undecoded
RFXCOM stored changed settings into non-volatile memory
Script Error embedded script: unsupported operand type(s) for -: 'unicode' and 'int'
embedded script, line 4, at top level
TypeError: unsupported operand type(s) for -: 'unicode' and 'int'
Tue Jul 28, 2015 2:16 pm
RJdeKok offline
Hi Fishysan,
It looks like the settings of the RFXCOM aren't saved correctly.
Can you go to the setup of the module, (Plugins/RFXCOM/Configure) and turn on or off one of the protocols?
Save the settings and try again?
If you still don't succeed then please send me a screen dump of your RFXCOM settings, so I can try to reproduce the error.
Bye, Robert.
Thu Jul 30, 2015 8:17 am
Fishysan offline
Thanks Robert,
I had tried a few things, and tried a few more based on your suggestions.
I removed all the protocols, left it a day, no errors. I also turned off "Show undecoded packets in log" which I didn't know was bad. Was an old setting.
As soon as I turned back on Oregon Scientific the errors started up.
For the configuration UI - I have nothing selected except Oregon Scientific. No other options.
Now I just turned on debugging to see if I can determine more - maybe a specific sensor is causing it.
Thanks!!
Jul 30, 2015, 10:00:31 AM
RFXCOM initializing communication on port /dev/cu.usbserial-03VHDCBN at speed 38400
RFXCOM enabling receiver protocols: Oregon Scientific
Embedded script executor host started
Jul 30, 2015, 10:01:19 AM
Mon Aug 03, 2015 1:16 pm
RJdeKok offline
Hi Fishysan,
I think your problem is that the firmware in your RFXTRX is to old.
I know settings changed at some release of the firmware and I had to make changes as well.
Your version is 190, mine is 226 and I think the most actual version is 245.
You can find the firmware and instructions here:http://www.rfxcom.com/epages/78165469.sf/nl_NL/?ObjectPath=/Shops/78165469/Categories/Downloads
Probably one disadvantage, you need a Windows machine to update the firmware.
Good luck,
Robert.
Tue Aug 04, 2015 10:04 am
Fishysan offline
Interesting Robert. Thanks. I just updated it to 190 prior to upgrading indigo and the plugin and thought it was the latest. I'll look again for newer.. Well 190 was the newest a few weeks ago and now it is 191.
Your v 245 is for a different product. The EXT thing.
The previous plugin version I was using had no errors. Might roll back and see.
Thanks.
Tue Aug 04, 2015 10:12 am
RJdeKok offline
Hi Fishysan,
Can you send me a screen dump of your configuration?
Thu Aug 06, 2015 8:45 am
Sanderkoers offline
should i use a somfy RTS motor on my shades or IO homecontrol ?
Thu Aug 06, 2015 9:18 am
b_weijenberg offline
Somfy RTS is supported.
Tue Sep 01, 2015 4:14 am
Still looking for a UK sourced antenna :)
Would this antenna from RF Solutions work with the RFXtrx433E ? : RF Solutions Antenna
Tue Sep 01, 2015 10:23 am
Anyone using a Somfy Roll Up 28 RTS motor in a roller blind controlled by this plugin?
I am looking to install a roller blind for my kitchen window :)
Tue Sep 01, 2015 1:15 pm
wiery offline
I am yeah Jon, works perfectly
Tue Sep 01, 2015 1:34 pm
Thanks for the feedback - it will be good to get this sorted :)
Thu Sep 03, 2015 2:35 am
Follow up question - I am thinking of getting the battery version - is yours mains or battery?
Any views on which is best?
Fri Mar 11, 2016 2:01 am
colinpartridge offline
is it just me or has the plugin hosting site down? just tried to download latest version and got no reply. The version hosted by Indigodomo is a little behind.
Colin
Page 7 of 10 1 ... 4, 5, 6, 7, 8, 9, 10
