RFXtrx433 and RFX TRX Plugin
Posted: Fri Apr 13, 2012 4:51 pm
Hello,
Following the news in the April 2012 PA newsletter about the plugin for the RFXtrx433 controller, i bought one from UK-automation, in the hope that I would be able to include some Homeasy appliance and dimmer switches Ive had for a while, but aren't able to use with my indigo and x10 setup.
I am not having any joy sending signals to any of my home easy devices through the Indigo plugin. I have managed to transmit signals successfully from a windows machine running RFXmagr
IN RFXmngr I was able to successfully signal a homeasy light switch with the following settings
TYPE -AC
ID - 1 74 26 8C
UNIT CODE - 9
LEVEL - 6
When plugging the trx433 back into my mac running my indigo system, i created a rfx-trx plugin device with type "AC dimmer" house code 0174268C and unit code 9
When issuing an "on" command from the indigo main window i get no response from the dimmer switch. Ive attached below trace from my log file when the on command is issued.
If anyone has any suggestions or ideas, i would be ever so grateful.
Thank you
Andy Brown
London UK
delayAmount : 900
description : turn on device
deviceAction : TurnOn
deviceId : 1027872237
replaceExisting : True
textToSpeak : address : 174268C
brightness : 0
buttonGroupCount : 0
description :
deviceTypeId : ACDimmer
enabled : True
errorState :
folderId : 0
nl.rjdekok.indigoplugin.RFXRDK : (dict)
address : 174268C (string)
unit : 9 (string)
lastChanged : 2012-04-13 23:44:51
ledStates : []
model : AC Dimmer
name : Lounge Rose Window
onState : False
pluginId : nl.rjdekok.indigoplugin.RFXRDK
pluginProps : nl.rjdekok.indigoplugin.RFXRDK : (dict)
unit : 9 (string)
protocol : Plugin
remoteDisplay : True
states : States : (dict)
brightnessLevel : 0 (integer)
supportsAllOff : False
supportsStatusRequest : True
version : 0
RFX TRX By RdK Debug Turn On Appliance/Dimmer (level 0).
RFX TRX By RdK Debug Address 174268C
RFX TRX By RdK Debug housecode:9
RFX TRX By RdK Debug device type:ACDimmer
RFX TRX By RdK Debug device type:0
RFX TRX By RdK Debug device level:0.0
RFX TRX By RdK Debug sent "Lounge Rose Window" on
RFX TRX By RdK Debug Processing data 4 2 1 0 0
RFX TRX By RdK Debug ACK Message ACK, transmit OK
RFX TRX By RdK Debug ++++++++++++++
TYPE -AC
ID - 1 74 26 8C
UNIT CODE - 9
LEVEL - 6
Thank you
Andy Brown
London UK
delayAmount : 900
brightness : 0
description :
enabled : True
errorState :
folderId : 0
unit : 9 (string)
ledStates : []
model : AC Dimmer
onState : False
unit : 9 (string)
protocol : Plugin
version : 0
