RFXtrx433 and RFX TRX Plugin
Fri Apr 13, 2012 4:51 pm
chanteruk offline
Hello,
Following the news in the April 2012 PA newsletter about the plugin for the RFXtrx433 controller, i bought one from UK-automation, in the hope that I would be able to include some Homeasy appliance and dimmer switches Ive had for a while, but aren't able to use with my indigo and x10 setup.
I am not having any joy sending signals to any of my home easy devices through the Indigo plugin. I have managed to transmit signals successfully from a windows machine running RFXmagr
IN RFXmngr I was able to successfully signal a homeasy light switch with the following settings
TYPE -AC
ID - 1 74 26 8C
UNIT CODE - 9
LEVEL - 6
When plugging the trx433 back into my mac running my indigo system, i created a rfx-trx plugin device with type "AC dimmer" house code 0174268C and unit code 9
When issuing an "on" command from the indigo main window i get no response from the dimmer switch. Ive attached below trace from my log file when the on command is issued.
If anyone has any suggestions or ideas, i would be ever so grateful.
Thank you
Andy Brown
London UK
delayAmount : 900
description : turn on device
deviceAction : TurnOn
deviceId : 1027872237
replaceExisting : True
textToSpeak : address : 174268C
brightness : 0
buttonGroupCount : 0
description :
deviceTypeId : ACDimmer
enabled : True
errorState :
folderId : 0
nl.rjdekok.indigoplugin.RFXRDK : (dict)
address : 174268C (string)
unit : 9 (string)
lastChanged : 2012-04-13 23:44:51
ledStates : []
model : AC Dimmer
name : Lounge Rose Window
onState : False
pluginId : nl.rjdekok.indigoplugin.RFXRDK
pluginProps : nl.rjdekok.indigoplugin.RFXRDK : (dict)
unit : 9 (string)
protocol : Plugin
remoteDisplay : True
states : States : (dict)
brightnessLevel : 0 (integer)
supportsAllOff : False
supportsStatusRequest : True
version : 0
RFX TRX By RdK Debug Turn On Appliance/Dimmer (level 0).
RFX TRX By RdK Debug Address 174268C
RFX TRX By RdK Debug housecode:9
RFX TRX By RdK Debug device type:ACDimmer
RFX TRX By RdK Debug device type:0
RFX TRX By RdK Debug device level:0.0
RFX TRX By RdK Debug sent "Lounge Rose Window" on
RFX TRX By RdK Debug Processing data 4 2 1 0 0
RFX TRX By RdK Debug ACK Message ACK, transmit OK
RFX TRX By RdK Debug ++++++++++++++
Sat Apr 14, 2012 4:54 pm
RJdeKok offline
Re: RFXtrx433 and RFX TRX Plugin
Hello,
Can you send me the Hex string sent by the RFXMGR which works?
Sat Apr 14, 2012 5:21 pm
chanteruk offline
Hello,
this is the string sent from RFXMGR
Lighting2 command:0B 11 00 02 01 74 26 8C 09 01 05 00
0402010200
Packettype = Receiver/Transmitter Message
subtype = Transmitter Response
Sequence nbr = 2
response = ACK, data correct transmitted
Thank you
Andy
Sun Apr 15, 2012 4:21 am
RJdeKok offline
Hi Andy,
There is a new version of the plugin available.
This one knows HomeEasy appliance and Dimmer.
I also extended the logging, so you can see what the RFX transmits when you send a command:
RFX TRX By RdK Debug Address 0174268C
RFX TRX By RdK Debug device type:HEDimmer
RFX TRX By RdK Debug device type:1
RFX TRX By RdK Debug Transmitting data 11 17 1 0 1 116 38 140 9 1 0 0 (0b1101000174268c09010000)
RFX TRX By RdK Debug sent "HETest" on
RFX TRX By RdK Debug Processing data 4 2 1 0 0 (0402010000)
This can help us to find the problem if it still does not work.
Sun Apr 15, 2012 7:52 am
chanteruk offline
Hello again.
Fantastic! This now works perfectly with:-
HE302 Appliance switch
HE108 Double gang light switch
HE107 Single gang light switch
HE205 In line bulb holder
Also managed to define a HE303 PIR sensor as an AC switch and use it to control other devices via a trigger.
This plugin has allowed me to bring 9 devices that were previously isolated from my X10/Indigo setup.
Thank you! :-)
Andy
Sat May 05, 2012 10:08 am
henkjanvries offline
How do i get the housecode?
Theres no step by step anywhere?
Thu May 17, 2012 3:48 pm
How did you get the HE107/8 to integrate, i don't seem to have any option for HE switch (Just appliance and dimmer)
