Comments/Questions on RFXtrx
Thu Jun 07, 2012 12:55 pm
Dewster35 offline
Re: Comments/Questions on RFXtrx
b_weijenberg wrote:
Sorry, I don't have a Mac OS system so I can't help you.
I hope this site will give you all help information to get it operational.
http://www.mono-project.com/Mono:OSX
Or find a Windows system to flash the RFXrec433/RFXtrx433
Honestly, I've spent some time looking through that webpage and cannot make heads or tails of what I've got to do. Not real comfortable taking the chance and ruining a $100+ piece of hardware while guessing.
I have access to a PC, but it's running 64 bit xp. Is that more straightforward to use to update the firmware than Mono for a mac? Or is there someone on your team that does have experience with the Mac that could guide me in the right direction?
Thu Jun 07, 2012 1:30 pm
johnpolasek offline
I updated mine on a 64 bit win 7 machine; except for the fact that it apparently had to be completely powered down for the flash to "take", it worked fine. The windows instructions on the RFX website are pretty self explainatory; basically just download the flash program, download the right flash file, run the program and point it to the file you've downloaded.
Fri Jun 08, 2012 6:31 am
RJdeKok offline
Hello All,
Download WinOnX from the AppStore and install it.
Download RFXFlash and run it while WinOnX is running.
Yes, that will do something as WinOnX tries to handle the .exe file.
You will get an error the the runtime is not installed and WinOnX comes with a location from where you can download Mono, the replacement for the standard .Net runtime.
Download the WINDOWS version and run it while WinOnX is running.
after it installed the runtime restart WinOnX.
Now you can run RFXFlash from the WinOnX application.
Wed Jun 13, 2012 6:28 am
johnpolasek offline
The rain rate algorithm isn't bad, but it could use a bit of tweaking on the tail end of a rainstorm... we had a really spectacular one roll through yesterday, and while the RFX picked up the huge rain rates, once the line passed, it claimed it was still raining for a full hour after the sun came back out... and then kept behaving oddly when we got the hour or so of dribbly mist just before sunset. Here's a segment of the log:
    Time Rain RainRate
    6/12/2012 16:54 0 0
    6/12/2012 16:55 0.04 0
    6/12/2012 16:56 0.08 0
    6/12/2012 16:57 0.12 1.89
    6/12/2012 16:58 0.16 2.28
    6/12/2012 16:59 0.28 2.28
    6/12/2012 17:00 0.35 3.5
    6/12/2012 17:01 0.35 3.82
    6/12/2012 17:02 0.51 3.82
    6/12/2012 17:03 0.67 6.14
    6/12/2012 17:04 0.79 7.64
    6/12/2012 17:05 0.83 7.87
    6/12/2012 17:06 0.91 7.2
    6/12/2012 17:07 1.1 5.63
    6/12/2012 17:08 1.14 4.69
    6/12/2012 17:09 1.14 4.33
    6/12/2012 17:10 1.38 5.47
    6/12/2012 17:11 1.46 6.1
    6/12/2012 17:12 1.5 6.34
    6/12/2012 17:13 1.57 5.79
    6/12/2012 17:14 1.77 5.94
    6/12/2012 17:15 1.85 6.65
    6/12/2012 17:16 1.93 5.91
    6/12/2012 17:17 1.97 4.33
    6/12/2012 17:18 2.01 3.58
    6/12/2012 17:19 2.01 2.8
    6/12/2012 17:20 2.01 2.8
    6/12/2012 17:21 2.01 2.8
    6/12/2012 17:22 2.05 2.8
    6/12/2012 17:23 2.05 0.94
    6/12/2012 17:24 2.05 0.94
    6/12/2012 17:25 2.05 0.94
    Identical for 17:26-18:23
    6/12/2012 18:24 2.05 0.94
    6/12/2012 18:25 2.05 0.94
    6/12/2012 18:26 2.05 0.94
    6/12/2012 18:27 2.09 0.04
    6/12/2012 18:28 2.09 0.04
    6/12/2012 18:29 2.09 0.04
    6/12/2012 18:30 2.09 0.04
    identical for 18:31-19:03
    6/12/2012 19:04 2.09 0.04
    6/12/2012 19:05 2.09 0.04
    6/12/2012 19:06 2.09 0.04
    6/12/2012 19:07 2.13 0
    6/12/2012 19:08 2.13 0
    6/12/2012 19:09 2.13 0
    6/12/2012 19:10 2.13 0
    6/12/2012 19:11 2.13 0
    6/12/2012 19:12 2.13 0
    6/12/2012 19:13 2.13 0
    6/12/2012 19:14 2.13 0
    6/12/2012 19:15 2.13 0
    6/12/2012 19:16 2.13 0
    6/12/2012 19:17 2.13 0
    6/12/2012 19:18 2.13 0
    6/12/2012 19:19 2.13 0
    6/12/2012 19:20 2.13 0
    6/12/2012 19:21 2.17 0
    6/12/2012 19:22 2.17 0.04
    6/12/2012 19:23 2.17 0.04
    6/12/2012 19:24 2.17 0.04
    6/12/2012 19:25 2.17 0.04
    6/12/2012 19:26 2.17 0.04
    6/12/2012 19:27 2.17 0.04
    6/12/2012 19:28 2.17 0.04
    6/12/2012 19:29 2.17 0.04
    6/12/2012 19:30 2.17 0.04
    6/12/2012 19:31 2.17 0.04
    6/12/2012 19:32 2.17 0.04
    6/12/2012 19:33 2.17 0.04
    6/12/2012 19:34 2.17 0.04
    6/12/2012 19:35 2.17 0.04
    6/12/2012 19:36 2.17 0.04
    6/12/2012 19:37 2.17 0.04
    6/12/2012 19:38 2.17 0.04
    6/12/2012 19:39 2.17 0.04
    6/12/2012 19:40 2.17 0.04
    6/12/2012 19:41 2.17 0.04
    6/12/2012 19:42 2.17 0.04
    6/12/2012 19:43 2.17 0.04
    6/12/2012 19:44 2.17 0.04
    6/12/2012 19:45 2.17 0.04
    6/12/2012 19:46 2.17 0.04
    6/12/2012 19:47 2.17 0.04
    6/12/2012 19:48 2.17 0.04
    6/12/2012 19:49 2.17 0.04
    6/12/2012 19:50 2.17 0.04
    6/12/2012 19:51 2.17 0.04
    6/12/2012 19:52 2.17 0.04
    6/12/2012 19:53 2.17 0.04
    6/12/2012 19:54 2.17 0.04
    6/12/2012 19:55 2.17 0.04
    6/12/2012 19:56 2.17 0.04
    6/12/2012 19:57 2.2 0.04
    6/12/2012 19:58 2.2 0.08
    6/12/2012 19:59 2.2 0.08
    6/12/2012 20:00 2.2 0.08
    6/12/2012 20:01 2.2 0.08
    6/12/2012 20:02 2.2 0.08
    6/12/2012 20:03 2.2 0.08
    6/12/2012 20:04 2.2 0.08
    6/12/2012 20:05 2.24 0.08
    6/12/2012 20:06 2.24 0.08
    Identical 20:07-22:07
    6/12/2012 22:08 2.24 0.08
    6/12/2012 22:09 2.24 0.08
    6/12/2012 22:10 2.24 0
And BTW, the actual rain was probably pretty accurate; I have both the OSI and a Davis VantageVue, and the two tracked together to within 0.1 inch throughout the entire episode and finished only 0.03 inches apart at the end.
Wed Jun 13, 2012 7:07 am
Otis offline
Make sure the drain hole in the collection bucket isn't partially clogged — that can cause the water to continue dribbling out long after the rain stops.
Wed Jun 13, 2012 8:05 am
johnpolasek offline
I am fully aware of that; someone in my neighborhood has a rain bucket also being picked up by the RFXrec that recorded only 1.3 inches of rain in the event and is STILL climbing slowly this morning. But if you look at the cumulative rain column, the first bucket tip of the day occured at 16:55 and the last bucket trip in the main storm occured at 17:22 (52 bucket tips in about half an hour, each representing 1 mm of rainfall, the resolution of the OSI sensor). The 53rd tip did not occur until an hour later at 18:26 during a light mist that started about 10 minutes earlier. But during the entire period from 17:23 to 18:25, the rain RATE was listed as almost an inch per hour, and as soon as the daily rain added the additional mm of rainfall to the cumulative total, the rain RATE dropped to 0.04 inch, and it remained at 0.04 until the 54th tip at 19:07 when it became 0 until the 55th bucket tip of the day when it went back to 0.04... it should have faded off to 0 witin 10 minutes of having no additional trips of the bucket.
Wed Jun 13, 2012 8:19 am
Dewster35 offline
Anyone have any experience with wind affecting the accuracy? Granted, it would take a lot, but I think it is feasible... especially if the gage is no level.
Wed Jun 13, 2012 8:20 am
Dewster35 offline
Robert,
I did the following below and it's coming up as no com port found. Any suggested remedies?
RJdeKok wrote:
Hello All,
Wed Jun 13, 2012 9:42 am
b_weijenberg offline
Did you disconnect the RFXtrx from Indigo?
Only one application can access a COM port.
Wed Jun 13, 2012 10:26 am
Dewster35 offline
I disabled the RFXCOM plugin, quit indigo, force quit all indigo related process. Installed the USB drivers listed, launched WinOnX, Launched RFXFlash and it is still saying the same message that there is no COM port available. I've tried rebooting and following this same process a couple of times, tried unplugging and replugging the RFX into the USB port and there are no changes.
Fri Jun 15, 2012 2:33 pm
Dewster35 offline
Any other corrective action I should try?
Sat Jun 16, 2012 2:33 am
We have to wait for an answer by Robert as I don't have a Mac and Robert has a test device available.
You only need to flash firmware if a new version updates a function you will use. Sorry, I have no other solution but if it is urgent try to find somebody with a Windows system.
Sat Jun 16, 2012 3:40 am
RJdeKok offline
Still working on this, could take some more time.
For the time being you can make your Mac dual boot with bootcamp or use VMWare Fusion or Parallels to install a virtual Windows PC.
Sun Jun 17, 2012 9:35 pm
Dewster35 offline
Sorry if I sound a little frustrated, but you suggested I buy a 5 dollar piece of software to use for this application and it doesn't do what I need it to do.
Mon Jun 25, 2012 2:45 pm
Instead of WinOnX try using Mono:
http://www.go-mono.com/mono-downloads/download.html
It is free, but the process is still buggy and more difficult than it should be. You have to use Terminal to have mono launch the RFXflash.exe and even then it took it a few times before it started working (and once it launched the UI has bad redraw problems because of Mono). All that said, I was able to re-flash my RFXCOM eventually. Your mileage may vary though...
I do wish that the plugin would allow re-flashing directly from Indigo. That would be the optimal solution, especially given how frequently the firmware updates have been released.
