b_weijenberg wrote:No, the protocols used by the RFXLAN are different from the RFXtrx433/RFXrec433
b_weijenberg wrote:That diagram is a very old page showing the older LAN /USB solutions.
The RFXrec433/RFXtrx433 use a completely different but much simpler protocol compared to the RFXLAN and older USB receivers/transmitters.
Kzintar wrote:Does Indigo support the older USB RFXCOM receivers Bert says share the same protocol as the RFXLAN/RFXe?
matt (support) wrote:Kzintar wrote:Does Indigo support the older USB RFXCOM receivers Bert says share the same protocol as the RFXLAN/RFXe?
I don't know the answer to your protocol question, but I do know that Indigo only supports the older USB RFXCOM in W800 emulation mode. That is, it can receive the basic X10 RF and X10 Security RF data, but not the commands coming from other hardware / protocols.
RFXCOM Debug processing: 10 20 0 8 240 161 68 1 1 0 80 (0A 14 00 08 F0 A1 44 01 01 00 50)
RFXCOM Debug LW Switch with housecode f0a144 and unitcode 01 command 1 received (level:0)
RFXCOM Error unknown device detected (id = f0a144-01, type = 20). Select a LightWave Switch from the list of devices
RFXCOM Debug ++++++++++++++
RFXCOM Debug processing: 10 20 0 9 240 161 68 1 0 0 96 (0A 14 00 09 F0 A1 44 01 00 00 60)
RFXCOM Debug LW Switch with housecode f0a144 and unitcode 01 command 0 received (level:0)
RFXCOM Debug processing: 10 20 0 10 240 161 68 2 1 0 80 (0A 14 00 0A F0 A1 44 02 01 00 50)
RFXCOM Debug LW Switch with housecode f0a144 and unitcode 02 command 1 received (level:0)
RFXCOM Error unknown device detected (id = f0a144-02, type = 20). Select a LightWave Switch from the list of devices
RFXCOM Debug processing: 10 20 0 11 240 161 68 2 0 0 96 (0A 14 00 0B F0 A1 44 02 00 00 60)
RFXCOM Debug LW Switch with housecode f0a144 and unitcode 02 command 0 received (level:0)
RFXCOM Debug processing: 10 20 0 14 240 161 68 16 2 0 96 (0A 14 00 0E F0 A1 44 10 02 00 60)
RFXCOM Debug LW Switch with housecode f0a144 and unitcode 16 command 2 received (level:0)
RFXCOM Error unknown device detected (id = f0a144-16, type = 20). Select a LightWave Switch from the list of devices
RFXCOM Debug processing: 10 20 0 15 240 161 68 16 3 0 96 (0A 14 00 0F F0 A1 44 10 03 00 60)
RFXCOM Debug LW Switch with housecode f0a144 and unitcode 16 command 3 received (level:0)
RFXCOM Debug processing: 11 17 0 36 0 76 180 158 1 1 15 80 (0B 11 00 24 00 4C B4 9E 01 01 0F 50)
RFXCOM Debug AC Switch with housecode 004cb49e and unitcode 01 command 1 received
RFXCOM Debug Switch Command 004cb49e-01 in list, command=On
RFXCOM Debug processing: 11 17 0 37 0 76 180 158 1 0 0 80 (0B 11 00 25 00 4C B4 9E 01 00 00 50)
RFXCOM Debug AC Switch with housecode 004cb49e and unitcode 01 command 0 received
RFXCOM Debug Switch Command 004cb49e-01 in list, command=Off
RFXCOM Debug processing: 11 17 0 38 0 76 180 158 2 1 15 80 (0B 11 00 26 00 4C B4 9E 02 01 0F 50)
RFXCOM Debug AC Switch with housecode 004cb49e and unitcode 02 command 1 received
RFXCOM Error unknown device detected (id = 004cb49e-02, type = 17). Select a AC Switch from the list of devices
RFXCOM Debug processing: 11 17 0 39 0 76 180 158 2 0 0 80 (0B 11 00 27 00 4C B4 9E 02 00 00 50)
RFXCOM Debug AC Switch with housecode 004cb49e and unitcode 02 command 0 received
RFXCOM Debug processing: 11 17 0 40 0 76 180 158 3 1 15 80 (0B 11 00 28 00 4C B4 9E 03 01 0F 50)
RFXCOM Debug AC Switch with housecode 004cb49e and unitcode 03 command 1 received
RFXCOM Error unknown device detected (id = 004cb49e-03, type = 17). Select a AC Switch from the list of devices
RFXCOM Debug processing: 11 17 0 41 0 76 180 158 3 0 0 96 (0B 11 00 29 00 4C B4 9E 03 00 00 60)
RFXCOM Debug AC Switch with housecode 004cb49e and unitcode 03 command 0 received
RFXCOM Debug processing: 11 17 0 42 0 76 180 158 1 4 15 96 (0B 11 00 2A 00 4C B4 9E 01 04 0F 60)
RFXCOM Debug AC Switch with housecode 004cb49e and unitcode 01 command 4 received
RFXCOM Debug Switch Command 004cb49e-01 in list, command=None
RFXCOM Debug processing: 11 17 0 43 0 76 180 158 1 3 0 96 (0B 11 00 2B 00 4C B4 9E 01 03 00 60)
RFXCOM Debug AC Switch with housecode 004cb49e and unitcode 01 command 3 received
RFXCOM Debug Switch Command 004cb49e-01 in list, command=Bright
RFXCOM Debug processing: 11 21 0 163 129 17 71 1 1 1 121 112 (0B 15 00 A3 81 11 47 01 01 01 79 70)
RFXCOM Error unknown device type detected (type = 21)
RFXCOM Debug AC Switch with housecode 10673800 and unitcode 02 command 1 received
RFXCOM Error unknown device detected (id = 10673800-02, type = 17). Select a AC Switch from the list of devices
RFXCOM Debug processing: 11 17 0 1 1 103 56 0 2 0 0 112 (0B 11 00 01 01 67 38 00 02 00 00 70)
RFXCOM Debug AC Switch with housecode 10673800 and unitcode 02 command 0 received
RFXCOM Debug processing: 11 17 0 2 1 103 56 0 3 1 15 112 (0B 11 00 02 01 67 38 00 03 01 0F 70)
RFXCOM Debug AC Switch with housecode 10673800 and unitcode 03 command 1 received
RFXCOM Error unknown device detected (id = 10673800-03, type = 17). Select a AC Switch from the list of devices
RFXCOM Debug processing: 11 17 0 3 1 103 56 0 3 0 0 112 (0B 11 00 03 01 67 38 00 03 00 00 70)
RFXCOM Debug AC Switch with housecode 10673800 and unitcode 03 command 0 received
RFXCOM Debug processing: 11 17 0 4 1 103 56 0 4 1 15 112 (0B 11 00 04 01 67 38 00 04 01 0F 70)
RFXCOM Debug AC Switch with housecode 10673800 and unitcode 04 command 1 received
RFXCOM Error unknown device detected (id = 10673800-04, type = 17). Select a AC Switch from the list of devices
RFXCOM Debug processing: 11 17 0 5 1 103 56 0 4 0 0 112 (0B 11 00 05 01 67 38 00 04 00 00 70)
RFXCOM Debug AC Switch with housecode 10673800 and unitcode 04 command 0 received
RFXCOM Debug processing: 11 17 0 6 1 103 56 0 5 1 15 112 (0B 11 00 06 01 67 38 00 05 01 0F 70)
RFXCOM Debug AC Switch with housecode 10673800 and unitcode 05 command 1 received
RFXCOM Error unknown device detected (id = 10673800-05, type = 17). Select a AC Switch from the list of devices
RFXCOM Debug processing: 11 17 0 7 1 103 56 0 5 0 0 112 (0B 11 00 07 01 67 38 00 05 00 00 70)
RFXCOM Debug AC Switch with housecode 10673800 and unitcode 05 command 0 received
RFXCOM Debug processing: 11 17 0 8 1 103 56 0 2 4 15 112 (0B 11 00 08 01 67 38 00 02 04 0F 70)
RFXCOM Debug AC Switch with housecode 10673800 and unitcode 02 command 4 received
RFXCOM Debug processing: 11 17 0 9 1 103 56 0 2 1 15 112 (0B 11 00 09 01 67 38 00 02 01 0F 70)
RFXCOM Debug processing: 11 17 0 10 1 103 56 0 3 1 15 112 (0B 11 00 0A 01 67 38 00 03 01 0F 70)
RFXCOM Debug processing: 11 17 0 11 1 103 56 0 4 1 15 112 (0B 11 00 0B 01 67 38 00 04 01 0F 70)
RFXCOM Debug processing: 11 17 0 12 1 103 56 0 5 1 15 112 (0B 11 00 0C 01 67 38 00 05 01 0F 70)
