The Awning has a Somfy remote. I also have the Somfy MyLink app but of course getting control into Indigo would be much preferred.
Found this plugin and want to confirm that I understand correctly.
Is RFX433XL USB the correct device/bridge to order from RFXCOM?
Using the RFXCOM plugin I can then open/close/stop the Awning with Indigo?
Any other plugin/device I could optionally use or is the RFXCOM easiest/best?
