Cheap China Wall switches etc
Wed Feb 20, 2019 5:33 am
haimoo112 offline
First thank You for in my home the most used INDIGO plugin!
There is a small (simple?) thing that I deeply would like to be added RFXCOM Bluligin:
There are a lot off China made transmitters in price range 2 to 4 Euros/USD in eBay market. They are 433 and 315 MHz transmitters and receivers that most use EV1527 chip. They (i think) use Lightning4 protocol or close to it.
A good example is:
[url]https://www.ebay.com/itm/433MHz-RF-Wireless-Remote-Control-Switch-86-Wall-Panel-Transmitter-1-2-3-Button/202478950580?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D3beec43fa54b4edeae7f8ad48b6465ee%26pid%3D100675%26rk%3D5%26rkt%3D15%26sd%3D283197253555%26itm%3D202478950580&_trksid=p2481888.c100675.m4236&_trkparms=pageci%3A4cf21ea3-3202-11e9-bdeb-74dbd1808724%7Cparentrq%3Af6fe9a351680ac3de91daf83ffed5bfc%7Ciid%3A1
[/url]
The chip itself has 4 channels (buttons) that send messages. EV 1527 is serialised whit one million individual numbers. Wall switches use 3 of those in 1-3-2 order from left to right. The center button (3) is recognised by current RFXTRX- plugin as an RFX Security sensor.:
ID: chips serial number ( one million different numbers ) or part of it.
TYPE: 32
Buttons 2 and 4 (if available) will not be praised, and they give unknown type error 19.
EXSAMPLE:
CENTER BUTTON:
RFXCOM Debug processing: 8 32 0 29 61 170 240 2 105 (08 20 00 1D 3D AA F0 02 69)
RFXCOM Debug Security sensor 61501 of type 0 (X10 security door/window sensor) has status 2 (X10 alarm)
RFXCOM Debug Security sensor 61501 in list ](<<< Each unit have different number)[/b]
LEFT BUTTON:
RFXCOM Debug processing: 9 19 0 18 61 170 244 1 40 96 (09 13 00 12 3D AA F4 01 28 60)
RFXCOM Error unknown device type detected (type = 19)
RIGHT BUTTON:
RFXCOM Debug processing: 9 19 0 22 61 170 242 1 37 96 (09 13 00 16 3D AA F2 01 25 60)
So at the moment I can only use the mid (number 3) button as it is. It is possible to make a little soldering to get one button switches to act as mid button, but it would be nice to have all 3 or even all 4 buttons working.
a workout could also be a device type (xxx), that can be created based on incoming raw data. Example:
processing: 9 19 0 18 61 170 244 1 40 96 (09 13 00 12 3D AA F4 01 28 60) data will turn device type (xxx) on (and different data off)?
Or just toggle (xxx)
I believe that this economical solution would be in interest of most INDIGO users, as it would give a easy way of controlling home appliances at a marginal cost. Also, as RFXTRX can send commands, a sending option could also be possible. Again maybe just raw data. All those switches have a compatible learning code devices as relays or receiver- modules at a price tag of 0,50 cent to a few dollars.
Again, thank you what we already have, and I hope that this will be implemented in near future.
I will give all my help for whatever I can do: test, find compatible devices, send You samples etc...
Best Regards,
Jari
FINLAND
Fri Mar 15, 2019 11:25 am
haimoo112 offline
Re: Cheap China Wall switches etc
Ok,
Did some hacking, in the plugin - sorry-, made #19 device act as another item, that I will not need, and then trigger #32 security. Works ! Great.
// Jari
Users browsing this forum: No registered users and 19 guests
