Just upgraded to 7.2 and getting RFXCOM errors
Sat Nov 10, 2018 12:33 pm
Busta999 offline
Hi
the upgrade worked fine, just odd that I now have two Indigo apps in my Applications Indigo and Indigo 7.2.
It all went well until I moved my Mac Mini downstairs - The intent is to move Indigo to a recently updated iMac. But not started that yet,
Plugged in the RFXCOM
The Logs show
Enabling plugin "RFXCOM 2.1.8"
   Starting plugin "RFXCOM 2.1.8" (pid 7850)
   Started plugin "RFXCOM 2.1.8"
   RFXCOM Error                    "RFXCOM serial port" serial port open error: [Errno 2] could not open port /dev/cu.usbserial-A13X8U3: [Errno 2] No such file or directory: '/dev/cu.usbserial-A13X8U3'
   RFXCOM Error                    make sure the USB virtual serial port driver (ex: FTDI driver) is installed and correct port is selected
   RFXCOM Error                    serial port could not be opened
Not sure how or why a reboot would cause this.
Any ideas on how to get it fixed?
Sat Nov 10, 2018 2:30 pm
Re: Just upgraded to 7.2 and getting RFXCOM errors
Did the serial port name just change? You might just to need to select a new serial port in the RFXCOM plugin's configuration dialog.
Sat Nov 10, 2018 5:03 pm
Busta999 offline
I suspect a dodgy usb cable.
I put the original cable back on it and got this.
   Reloading plugin "RFXCOM 2.1.8"
   Stopping plugin "RFXCOM 2.1.8" (pid 67005)
   RFXCOM Error                    initialization failed (retrying in 10 seconds)
   Hue Lights                      received "Temp: Study (Hue)" sensor update to 20.4 ºC
   Stopped plugin "RFXCOM 2.1.8"
   Starting plugin "RFXCOM 2.1.8" (pid 67318)
   RFXCOM                          initializing communication on port /dev/cu.usbserial-A13X8U3 at speed 38400
Mon Nov 12, 2018 7:10 am
Busta999 offline
OK got it working again
Rebooted computer it came back up ok.
I need to check that cable though.
Mike
