Somfy rts memory (MY)
Sat Mar 10, 2018 6:34 am
koburg offline
Hi
I have somfy rts blinds and consider buying rfxcom unit.
1. do the rfxcom plugin support the "MY" (memory) function from the remote so it can use the programmet memory spot
in from the remote called "my"
2. is it possible to make xx% to how long the blinds will go and stop
Sat Mar 10, 2018 11:42 am
b_weijenberg offline
Re: Somfy rts memory (MY)
MY is supported. This is the same as the STOP function in the RFXtrx433E
Sat Mar 10, 2018 11:46 am
koburg offline
Yes it is stop but Also a memory function
So if you push the button it Will go to programmed mem place.
Sat Mar 10, 2018 12:06 pm
Correct, the position is stored in the Somfy motor and is called by the STOP/MY function of the remote and RFXtrx433E.
