Updated to 2.1.3 now throwing errors
Tue Feb 06, 2018 9:19 pm
Fishysan offline
Hi, thanks much for continued work on this plugin!
I just upgraded from 2.1.2 which was working fine, to the new version which now leverages the "indigo.sensor" type and wanted the degree symbol so I don't have to manipulate temp strings. I thought it would add F or C - but it just adds degree. F/C would be awesome!
Unfortunately when I fired it up, I get two identical errors every time an Oregon Scientific sensor broadcasts.
What I'm not 100% sure of, is whether this is RFXCOM plugin or something Indigo related. I tried editing/refreshing sensors. Doesn't seem to help.
I rebuilt one of my many sensors, and it doesn't seem to complain anymore. It actually complained with a burst of 4, but once I finished creating it, it seems OK now.
Any idea? Hopefully the expectation is not to have to recreate all RFXCOM temp devices as that hoses all the triggers/actions etc. Does my RFXtrx need an update? I was going to soon, but now wonder. Thanks!
Here are some log snippets, hopefully this helps;
   RFXCOM                          initializing communication on port /dev/cu.usbserial-03VHDCBN at speed 38400
   RFXCOM                          connected to RFXtrx 433.92 MHz, firmware version 190
   RFXCOM                          currently enabled receiver protocols: Oregon Scientific
   Error                           device "OS Sensor - Front Bedroom" state key sensorValue not defined (ignoring update request)
   Error                           device "OS Sensor - Master Bedroom" state key sensorValue not defined (ignoring update request)
And with DEBUG turned on, some samples;
   RFXCOM Debug                    PIC INIT IS: none
   RFXCOM Debug                    send init cmd: 13 0 0 1 2 0 0 0 0 0 0 0 0 0 (0D 00 00 01 02 00 00 00 00 00 00 00 00 00)
   RFXCOM Debug                    rcvd init reply: 13 1 0 1 2 83 190 0 0 32 0 1 0 28 (0D 01 00 01 02 53 BE 00 00 20 00 01 00 1C)
   RFXCOM Debug                    processing: 10 82 1 0 236 1 128 23 44 0 89 (0A 52 01 00 EC 01 80 17 2C 00 59)
   RFXCOM Debug                    Temp sensor 492 now -2.30 degrees and 44 humidity.
   RFXCOM Debug                    Temp sensor 492 in list
   RFXCOM Debug                    UpdateMinMax state temperature value -2.3
   RFXCOM Debug                    check if new day: last date 2018/02/06, new date 2018/02/06
   RFXCOM Debug                    UpdateMinMax state humidity value 44
   Error                           device "OS Sensor - Garage" state key sensorValue not defined (ignoring update request)
   RFXCOM Debug                    ++++++++++++++
   RFXCOM Debug                    processing: 10 82 1 1 87 4 0 189 33 2 105 (0A 52 01 01 57 04 00 BD 21 02 69)
   RFXCOM Debug                    Temp sensor 1111 now 18.90 degrees and 33 humidity.
   RFXCOM Debug                    Temp sensor 1111 in list
   RFXCOM Debug                    UpdateMinMax state temperature value 18.9
   RFXCOM Debug                    UpdateMinMax state humidity value 33
   Error                           device "OS Sensor - Office" state key sensorValue not defined (ignoring update request)
   RFXCOM Debug                    <<-- entering deviceStartComm: OS Sensor - Master Bedroom (1854670858 - Temperature)
   RFXCOM Debug                    deviceStart called. Adding device OS Sensor - Master Bedroom, type: Temperature
   RFXCOM Debug                    Adding sensor 288.
   RFXCOM Debug                    Updating plugin props, Sensor 288
   RFXCOM Debug                    <<-- entering deviceStartComm: OS Sensor - Office (1335542212 - Temperature)
   RFXCOM Debug                    deviceStart called. Adding device OS Sensor - Office, type: Temperature
   RFXCOM Debug                    Adding sensor 1111.
   RFXCOM Debug                    Updating plugin props, Sensor 1111
Tue Feb 06, 2018 10:38 pm
roquej offline
Re: Updated to 2.1.3 now throwing errors
I was getting the same error.
To fix, set the device to X10. Save it. Go back in and specify the type as RFXCOM again, with the applicable device model. Re-save. That did it for me.
Just make sure you make a note of the address. It retained it for me, but just in case.
Hope this helps.
JP
Wed Feb 07, 2018 8:08 pm
Fishysan offline
Awesome, thanks! That did the trick. And a nice one for "resetting" an item without loosing the ID that's used everywhere.
It's likely an Indigo bug then, because it did it for the X10 ones, and I've seen it before. Oh well. Cheers!
Hope this helps.
JP
Sat Feb 10, 2018 4:25 am
davinci offline
Thanks, worked for me as well.
