New to RFXCOM plugin - trying to get blinds working
Sat Aug 15, 2020 5:28 pm
agame offline
Re: New to RFXCOM plugin - trying to get blinds working
I've picked up one other thing, once the first device is configured, the log no-longer reports an error when a different unit button is pressed, even though no device is created. But once the device -is- created by duplicating the original and changing the unit code, it works correctly ... including changing status on a remote control press.
this is the log for a stop button press on unit code 5 (no corresponding device is configured):
   RFXCOM Debug                    processing: 9 25 3 102 36 245 5 1 2 112 (09 19 03 66 24 F5 05 01 02 70)
   RFXCOM Debug                    Blinds Remote with id1-3 384505 and unitcode 1 command 2 received
   RFXCOM Debug                    Blinds Remote with subtype 3 and sensor 38450501 received
   RFXCOM Debug                    HouseCode:24F505
   RFXCOM Debug                    Subtype:3
   RFXCOM Debug                    UnitCode:1
   RFXCOM Debug                    Switch Command 38450501 in list, command=Stop
   RFXCOM Debug                    ++++++++++++++
   RFXCOM Debug                    finalizeStatesChanges:new blinds lounge :[{'value': 'Stop', 'key': u'command'}, {'value': 3, 'key': u'type'}, {'value': '2020/08/16 09:29:11', 'key': u'lastUpdated'}]
   RFXCOM Debug                    address1,2,3,house = 36 , 245 , 5 , 1
I'm guessing this is also because the unit code is being reported incorrectly.
Sat Aug 15, 2020 5:36 pm
GlennNZ offline
Ok
Have had a look - need Debug logs!
Ideally for multiple unit codes (as this is not being reported correctly)
Can
1. Add actions open/close/program/limit/stop - and have done so in new version
2.
I suspect because this is because your blinds are subtype=3, testing on subtype=6 (appears to be Silent Glass ones as well)
Can create new device type completely if needed, but prefer to look at debug logs first.
Glenn
Sat Aug 15, 2020 9:17 pm
agame offline
no problem!
here are some logs:
Blind configured as unit 0 [blind 1 on the multi-remote] stop:
   RFXCOM Debug                    processing: 9 25 3 3 36 245 5 1 2 113 (09 19 03 03 24 F5 05 01 02 71)
   RFXCOM Debug                    finalizeStatesChanges:blinds middle copy :[{'value': 'Stop', 'key': u'command'}, {'value': 3, 'key': u'type'}, {'value': '2020/08/16 13:07:43', 'key': u'lastUpdated'}]
   RFXCOM Debug                    address1,2,3,house = 36 , 245 , 5 , 4
blind configured as 1 (which is blind 2 on remote) 'stop':
   RFXCOM Debug                    processing: 9 25 3 6 36 245 5 1 2 113 (09 19 03 06 24 F5 05 01 02 71)
   RFXCOM Debug                    finalizeStatesChanges:blinds middle copy :[{'value': 'Stop', 'key': u'command'}, {'value': 3, 'key': u'type'}, {'value': '2020/08/16 13:08:51', 'key': u'lastUpdated'}]
blind configured as 3 [which, oddly, is 3 on the remote......previously, I has unit code 3 enrolled to work all the blinds simultaneously...obviously I can replicate this by stringing together 3 commands but it's weird it seems to have changed since the update ] 'stop'
 RFXCOM Debug                    processing: 9 25 3 17 36 245 5 1 2 113 (09 19 03 11 24 F5 05 01 02 71)
   RFXCOM Debug                    finalizeStatesChanges:blinds middle copy :[{'value': 'Stop', 'key': u'command'}, {'value': 3, 'key': u'type'}, {'value': '2020/08/16 13:14:53', 'key': u'lastUpdated'}]
- whilst I have all 3 blinds working and properly reporting status - pretty happy about that- I'm having now having no joy with creating further devices/unit codes: no matter what unit code I try devices don't update their status after a remote press regardless of all the unit codes being tried. I'm pretty sure I had that working before I deleted and recreated everything.
Sat Aug 15, 2020 9:29 pm
agame offline
in case it helps, here is 'up' on two different zones:
unit code 0/ physical button 1:
RFXCOM Debug                    processing: 9 25 3 26 36 245 5 1 0 113 (09 19 03 1A 24 F5 05 01 00 71)
   RFXCOM Debug                    Blinds Remote with id1-3 384505 and unitcode 1 command 0 received
   RFXCOM Debug                    Switch Command 38450501 in list, command=Open
   RFXCOM Debug                    finalizeStatesChanges:blinds middle copy :[{'value': 'Open', 'key': u'command'}, {'value': False, 'key': u'onOffState'}, {'value': 3, 'key': u'type'}, {'value': '2020/08/16 13:19:40', 'key': u'lastUpdated'}]
unit code 1/physical button 2:
   RFXCOM Debug                    finalizeStatesChanges:blinds middle copy :[{'value': 'Open', 'key': u'command'}, {'value': False, 'key': u'onOffState'}, {'value': 3, 'key': u'type'}, {'value': '2020/08/16 13:21:00', 'key': u'lastUpdated'}]
And here is another 'up' sequence...this time from a second physical remote for which I hadn't created a device but which is also enrolled to physical blind #1 - it reports a different house code and is generating the 'create device' prompt. After I captured this I was able to create a working device with it on unit code 0 (communicating with the same blind [physical #1] as the other unit code 0.
  RFXCOM Debug                    processing: 9 25 3 32 36 244 137 1 0 113 (09 19 03 20 24 F4 89 01 00 71)
   RFXCOM Debug                    Blinds Remote with id1-3 384537 and unitcode 1 command 0 received
   RFXCOM Debug                    Blinds Remote with subtype 3 and sensor 38453701 received
   RFXCOM Debug                    HouseCode:24F489
   RFXCOM Error                    unknown device detected (type = 25). Select a BlindsT1234 Device from the list of devices
   RFXCOM Error                    HouseCode (hex)=24F489 ,subtype (int)=3 ,unitCode (int)=1
Sat Aug 15, 2020 9:31 pm
GlennNZ offline
Ok
Your blinds unitcode is configured differently to the subtype=6 which I have.
I can update something in next 10-15 if around?
Sat Aug 15, 2020 9:35 pm
GlennNZ offline
agame wrote:
no problem!
here are some logs:
Further to these ones.
Stick with the one remote for the moment - and change the unitnumber.
Can you give me a few stops in a row from each unit - need to check something ...
(need the processing bit of info - the Hex, rest can work out)
Sat Aug 15, 2020 9:40 pm
GlennNZ offline
GlennNZ wrote:
agame wrote:
no problem!
here are some logs:
& Can you confirm Controlling blinds works okay - each with the different unit numbers?
(Must be a difference between what is received and what is sent)
Probably need a few command sends from from within Indigo - confirming that controls appropriately.
(Stick to the one physical remote/housecode for moment)
Tah!
Sat Aug 15, 2020 9:48 pm
agame offline
sure:
here are 3 stops from the blind that responds to unit code 0:
   RFXCOM Debug                    finalizeStatesChanges:blinds middle copy :[{'value': 'Stop', 'key': u'command'}, {'value': 3, 'key': u'type'}, {'value': '2020/08/16 13:44:47', 'key': u'lastUpdated'}]
   RFXCOM Debug                    processing: 9 25 3 74 36 245 5 1 2 113 (09 19 03 4A 24 F5 05 01 02 71)
   RFXCOM Debug                    finalizeStatesChanges:blinds middle copy :[{'value': 'Stop', 'key': u'command'}, {'value': 3, 'key': u'type'}, {'value': '2020/08/16 13:44:48', 'key': u'lastUpdated'}]
   RFXCOM Debug                    processing: 9 25 3 75 36 245 5 1 2 113 (09 19 03 4B 24 F5 05 01 02 71)
   RFXCOM Debug                    finalizeStatesChanges:blinds middle copy :[{'value': 'Stop', 'key': u'command'}, {'value': 3, 'key': u'type'}, {'value': '2020/08/16 13:44:49', 'key': u'lastUpdated'}]
   RFXCOM Debug                    processing: 9 25 3 76 36 245 5 1 2 113 (09 19 03 4C 24 F5 05 01 02 71)
   RFXCOM Debug                    finalizeStatesChanges:blinds middle copy :[{'value': 'Stop', 'key': u'command'}, {'value': 3, 'key': u'type'}, {'value': '2020/08/16 13:44:50', 'key': u'lastUpdated'}]
and physical button 4:
   RFXCOM Debug                    finalizeStatesChanges:blinds middle copy :[{'value': 'Stop', 'key': u'command'}, {'value': 3, 'key': u'type'}, {'value': '2020/08/16 13:46:14', 'key': u'lastUpdated'}]
   RFXCOM Debug                    processing: 9 25 3 80 36 245 5 1 2 113 (09 19 03 50 24 F5 05 01 02 71)
   RFXCOM Debug                    finalizeStatesChanges:blinds middle copy :[{'value': 'Stop', 'key': u'command'}, {'value': 3, 'key': u'type'}, {'value': '2020/08/16 13:46:15', 'key': u'lastUpdated'}]
   RFXCOM Debug                    processing: 9 25 3 81 36 245 5 1 2 113 (09 19 03 51 24 F5 05 01 02 71)
   RFXCOM Debug                    finalizeStatesChanges:blinds middle copy :[{'value': 'Stop', 'key': u'command'}, {'value': 3, 'key': u'type'}, {'value': '2020/08/16 13:46:17', 'key': u'lastUpdated'}]
   RFXCOM Debug                    processing: 9 25 3 82 36 245 5 1 2 113 (09 19 03 52 24 F5 05 01 02 71)
   RFXCOM Debug                    processing: 10 82 1 83 252 1 0 201 49 1 105 (0A 52 01 53 FC 01 00 C9 31 01 69)
   RFXCOM Debug                    Temp sensor 508 now 20.10 degrees and 49 humidity.
   RFXCOM Debug                    Temp sensor 508 in list
   RFXCOM Debug                    UpdateMinMax state temperature value 20.1
   RFXCOM Debug                    check if new day: last date 2020/08/16, new date 2020/08/16
   RFXCOM Debug                    UpdateMinMax state humidity value 49.0
blindresponding tounit code 1 (corresponding to physical button 2):
  RFXCOM Debug                    processing: 9 25 3 87 36 245 5 1 2 113 (09 19 03 57 24 F5 05 01 02 71)
   RFXCOM Debug                    finalizeStatesChanges:blinds middle copy :[{'value': 'Stop', 'key': u'command'}, {'value': 3, 'key': u'type'}, {'value': '2020/08/16 13:48:31', 'key': u'lastUpdated'}]
   RFXCOM Debug                    processing: 9 25 3 88 36 245 5 1 2 113 (09 19 03 58 24 F5 05 01 02 71)
   RFXCOM Debug                    finalizeStatesChanges:blinds middle copy :[{'value': 'Stop', 'key': u'command'}, {'value': 3, 'key': u'type'}, {'value': '2020/08/16 13:48:32', 'key': u'lastUpdated'}]
   RFXCOM Debug                    processing: 9 25 3 89 36 245 5 1 2 113 (09 19 03 59 24 F5 05 01 02 71)
   RFXCOM Debug                    finalizeStatesChanges:blinds middle copy :[{'value': 'Stop', 'key': u'command'}, {'value': 3, 'key': u'type'}, {'value': '2020/08/16 13:48:33', 'key': u'lastUpdated'}]
   RFXCOM Debug                    processing: 9 25 3 90 36 245 5 1 2 113 (09 19 03 5A 24 F5 05 01 02 71)
Sat Aug 15, 2020 9:51 pm
GlennNZ offline
Hi
Correct me if I'm wrong
But the physical Buttons are Up/Down/Open/Close/Stop - are they not?
The UnitCode/Numbers 0-4 are selectable - the buttons fixed?
GLenn
Sat Aug 15, 2020 9:57 pm
agame offline
fyi when I ran those I had 3 working devices configured, on unit codes
0,1,3
the device 'blinds middle copy' was configured on unit code 4 - I see it is appearing in the logs against 2 different buttons...2 and 4.
I've deleted that device now, and pressing stop button 2 now triggers this run of errors:
 RFXCOM Debug                    processing: 9 25 3 103 36 245 5 1 2 113 (09 19 03 67 24 F5 05 01 02 71)
   RFXCOM Error                    Error in plugin execution runConcurrentThread:
  File "plugin.py", line 308, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/RFXCOM.indigoPlugin/Contents/Server Plugin/RFXTRX.py", line 2338, in startComm
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/RFXCOM.indigoPlugin/Contents/Server Plugin/RFXTRX.py", line 809, in processPacket
  File "/Library/Application Support/Perceptive Automation/Indigo 7.4/Plugins/RFXCOM.indigoPlugin/Contents/Server Plugin/RFXTRX.py", line 46, in _finalizeStatesChanges
KeyError: key id 1297126934 not found in database
   RFXCOM Error                    plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
   RFXCOM Debug                    runConcurrentThread called
   RFXCOM Debug                    startComm called
   RFXCOM Debug                    processing: 9 25 3 104 36 245 5 1 2 113 (09 19 03 68 24 F5 05 01 02 71)
Sat Aug 15, 2020 10:01 pm
GlennNZ offline
OK
Can you log some Indigo Control sends?
I suspect this is unfixable unfortunately - it may pay to update firmware of RFX device (check Userguide) as to best (think Pro1 Firmware covers most)
Have added Stop, and may be able to fix the new device not appearing aspect, but bottom line is the received info is the same.
Stop Unit Code 0
Stop Unit Code 1
Above are from your logs - and other than the 4th Entry they are all the same.
4th Entry - just counts up/around, doesn't do much
RFXCOM not actually receiving any unitcode info
Breakdown
09 - Cmd
19 - Blind
03 - Subtype
-- = counter
24
F5
05 - remote physical ID
01 - Unitcode
71 - Checksum
Got your email about device error; thats not mine - but restarting plugin should fix.
Glenn
Sat Aug 15, 2020 10:04 pm
agame offline
GlennNZ wrote:
Hi
GLenn
The physical buttons are up, stop, down; and left/right left/right selects blinds 1 through to 6. [not 1-4]
Sat Aug 15, 2020 10:10 pm
GlennNZ offline
Yep - thanks
Stick to the Stop button. Across the different blinds (my Dooya Multichannel remote is similiar except 16 'channels' or unitcodes')
See above message, regarding send commands.
The problem will be because not receiving any unitcode information from Remote, multiple devices may think they are the same.
One physical remote (different Housecode) and one unitcode will work, multiple unitcodes across same remote will cause problems as won't be distinguished from each other.
Still can send commands - manually entering unitcode, but may have to disable receiving, unless firmware changes something...
Thoughts?
Glenn
Sat Aug 15, 2020 10:22 pm
agame offline
here on the blind working with unit code 3 and responding to remote. control channel 3
  RFXCOM Debug                    Actions...TurnOn
   RFXCOM Debug                    Turn BlindsT1234 Appliance/Dimmer On (level 0).
   RFXCOM Debug                    Address 24F505
   RFXCOM Debug                    housecode:3
   RFXCOM Debug                    address1 and 2 and 3 = 36 , 245 , 5
   RFXCOM Debug                    device type:BlindsT1234
   RFXCOM Debug                    device subtype:6 / Command:On
   RFXCOM Debug                    device level:0
   RFXCOM Debug                    PackData:=: 25 3 0 36 245 5 3 1 0 (19 03 00 24 F5 05 03 01 00)
   RFXCOM Debug                    send x10 cmd: 9 25 3 0 36 245 5 3 1 0 (09 19 03 00 24 F5 05 03 01 00)
   RFXCOM Debug                    processing: 4 2 1 0 0 (04 02 01 00 00)
   RFXCOM Debug                    ACK Message ACK, transmit OK
   RFXCOM Debug                    sent "blinds kitchen" on
   RFXCOM Debug                    Actions...TurnOff
   RFXCOM Debug                    Turn BlindsT1234 Appliance/Dimmer Off (level 0).
   RFXCOM Debug                    device subtype:6 / Command:Off
   RFXCOM Debug                    PackData:=: 25 3 0 36 245 5 3 0 0 (19 03 00 24 F5 05 03 00 00)
   RFXCOM Debug                    send x10 cmd: 9 25 3 0 36 245 5 3 0 0 (09 19 03 00 24 F5 05 03 00 00)
   RFXCOM Debug                    sent "blinds kitchen" off
and blind 1/unit code 0
   RFXCOM Debug                    housecode:0
   RFXCOM Debug                    PackData:=: 25 3 0 36 245 5 0 1 0 (19 03 00 24 F5 05 00 01 00)
   RFXCOM Debug                    send x10 cmd: 9 25 3 0 36 245 5 0 1 0 (09 19 03 00 24 F5 05 00 01 00)
   RFXCOM Debug                    sent "blinds wollemi" on
   RFXCOM Debug                    PackData:=: 25 3 0 36 245 5 0 0 0 (19 03 00 24 F5 05 00 00 00)
   RFXCOM Debug                    send x10 cmd: 9 25 3 0 36 245 5 0 0 0 (09 19 03 00 24 F5 05 00 00 00)
   RFXCOM Debug                    sent "blinds wollemi" off
   DSC Alarm                       Alarm Zone 'alarm zone 1 lounge' Opened.
Forgive me if I said this (I thought I sent but may have deleted): what is really odd is that indigo clearly does -somehow- have some awareness of the unit number as its correctly differentiating. the three blinds. When recently updating the firmware on the RFX-TRX (I think to the most recent type 2...its a fairly old device not sure if PRO will work?); I noticed discrepancies between the indigo logs and the RFXmgr reports....certainly in relation to unit number.
Sat Aug 15, 2020 10:23 pm
GlennNZ offline
How is it distinguishing the 3 blinds?
- Commands sent are because you have manually entered the unitcode
Rest pretty sure will be cross-recognised....
(see my earlier reply)
