Indigo Responding differently than expected to LightWaveRF
Posted: Sun Apr 03, 2016 7:24 am
Hi
On Day 5 of Indigo so be gentle with me please....
I'm pressing Button two on my Lightwaverf remote - that I do not have setup in Indigo and it responding as if I pressed Button 3.
Indigo does NOT do this when Button 1 is pressed or Button 4, it does work on Button 3 as described and setup below.
It is driving me crazy trying to understand why this is going wrong.
I have setup a Switch (I thought would be a Remote but can't see how to make that work in Indigo) The JSJSLW100WH
It has 5 On buttons, 5 Off Buttons, A Mood 1 On, and an Everything Off
The Switch is setup as a Device, RFXCOM/LightWave Switch, Name of SwitchMaster Bedroom Mike #3, Device Settings f0ef41 Unicode 3
My understanding of this is that ONLY Button three on the remote will be detected.
Then I created a trigger
Master Bedroom Dim Mike
Device State Changed/ Switch Master Bedroom Mike #3/Command/Becomes Equal to/ On
So If the On Button Three on Mike's Lightwave Remote Control in the Master Bedroom is pressed the following will occur
Condition:-
Always set with No conditions.
Actions:-
Execute Action Group (server Actions)
Master Bed Dim
If press Button 3 On - every thing works OK.
If I press Button 2 On the following occurs - even though I have not set this button up at all - see Screen Grab
RFXCOM Debug processing: 10 20 0 192 240 239 65 2 1 0 96 (0A 14 00 C0 F0 EF 41 02 01 00 60)
RFXCOM Debug LW Switch with housecode f0ef41 and unitcode 02 command 1 received (level:0)
RFXCOM Error probably a LW Remote?
RFXCOM Debug LW Remote with housecode f0ef41 command 1 received (level:0)
RFXCOM Debug Switch Command f0ef41 in list, unit=02, command=On
Error device "Switch Master Bedroom Mike #3" state key unit not defined (ignoring update request)
Trigger Master Bedroom Dim Mike
Action Group Master Bed Dim
RFXCOM Debug ++++++++++++++
RFXCOM Debug Actions...TurnOn
RFXCOM Debug Turn LWAppliance Appliance/Dimmer On (level 0).
RFXCOM Debug Address 335063
RFXCOM Debug housecode:1
RFXCOM Debug device type:LWAppliance
RFXCOM Debug device subtype:0 / Command:On
RFXCOM Debug device level:0.0
RFXCOM Debug send x10 cmd: 10 20 0 0 51 80 99 1 1 0 112 (0A 14 00 00 33 50 63 01 01 00 70)
Sent Hue Lights "Master Floor" on to 30 at ramp rate 2.0 sec.
Sent Hue Lights "Master Mike" off at ramp rate 0.0 sec.
Sent Hue Lights "Master Dawn" off at ramp rate 0.0 sec.
Sent Hue Lights "Landing Globe" on to 30 at ramp rate 2.0 sec.
RFXCOM Debug processing: 4 2 1 0 0 (04 02 01 00 00)
RFXCOM Debug ACK Message ACK, transmit OK
RFXCOM Debug sent "Master Mike Nightlight" on
RFXCOM Debug sent "Master Dawn Nightlight" on
Condition:-
Actions:-
Master Bed Dim
