Capture 433.92 remote signals to control blinds
Mon Feb 01, 2016 2:51 am
Quantum Flux offline
I have just bought and received a RFXTRX433E
My roller blinds use a 433.92MHz remote, but I have no idea what brand the system is.
Is there a way to capture the remote control commands to find out?
I have turned on all the debugging for the plugin, but it logs nothing when i press the remote
Mon Feb 01, 2016 4:36 am
durosity offline
Re: Capture 433.92 remote signals to control blinds
Have you enabled the different protocols one at a time and tried it? Some can't be enabled with others, so if you have them all ticked it may be missing it.
Mon Feb 01, 2016 4:48 am
b_weijenberg offline
See chapter 2 in the RFXtrx User Guide which blinds remotes are received.
For some you need to flash Type1 or Type2 firmware as not all blinds are supported in Ext firmware.
Please try with RFXmngr on a Windows system and only BlindsT0 enabled.
If nothing received try with only BlindsT1 and undec on enabled.
If nothing received you can try to pair a motor using BlindsT6, BlindsT9 and BlindsT10
Bert
Mon Feb 01, 2016 4:56 am
OK I have done as durosity suggested.
Sending the "Blind 2 down" signal from the remote, Indigo logs events for two protocols:
Lighting 4:
RFXCOM Debug processing: 9 3 1 2 40 0 0 0 0 0 (09 03 01 02 28 00 00 00 00 00)
RFXCOM Debug ++++++++++++++
ARC:
RFXCOM Debug processing: 9 3 1 3 40 0 0 0 0 0 (09 03 01 03 28 00 00 00 00 00)
Mon Feb 01, 2016 4:59 am
data is only useful with BlindsT0 or BlindsT1 enabled.
Mon Feb 01, 2016 5:02 am
durosity offline
Yeah ignore my comments, follow berts advice.
Mon Feb 01, 2016 5:05 am
OK, here it is:
With 'Blinds T0' and ARC enabled
RFXCOM Debug processing: 9 3 1 0 40 0 0 0 0 0 (09 03 01 00 28 00 00 00 00 00)
With 'Blinds T0 and 'Lighting4'
With 'Blinds T1,2,3,4' and ARC enabled
With 'Blinds T1,2,3,4' and 'Lighting4' enabled
Mon Feb 01, 2016 5:09 am
It is ONLY useful if BlindsT0 or BlindsT1 enabled together with undec on.
Please follow the steps as given in the previous message.
Sat Mar 26, 2016 11:43 pm
Hi All.
Thought I would take another crack at this during the long weekend.
Have flashed firmware 1001 to my RFXtrx433E to make sure it's the latest.
Installed RFXmngr and set "undec" and "blind T1/T2/T3/T4" to on.
Nothing happens on Type1 or Type2 firmware
But, if I turn on "undec" and either "Lighting 4" or "ARC", I get...
27/03/2016 4:36:12 PM
Packettype        = UNDECODED RF Message
UNDECODED ARC:280000000000
Same result both firmware versions
Any ideas how to proceed?
Note that "Blind T0" option is greyed out in RFXmngr for some reason.
Also, I found out what the blinds are
Manufacturer: Rollease Acmeda
Product: Automate EL motors
In the below URL, I found mention of both "Acmeda" and "Rollease", which makes me think these are re-branded Somfy blinds.
https://www.somfysystems.com/file.cfm/500_Databook_6-2015.pdf?contentID=241851
The remote needs to be paired to the blind, but I'm not sure if this is simply to give the blind an address/number.
Sun Mar 27, 2016 4:57 am
If this is a Somfy RTS motor you can add an addiional remote to the motor.
Somfy RTS is not received by the RFXtrx433E!
See also chapter 12 in the RFXtrx User Guide.
BlindsT0 receive is only supported in Type2 firmware. See chaper 2.2.2 for the list of supported devices in each firmware type.
