Measuring Signal Strength?
PostPosted: Sat Nov 14, 2015 11:11 am
by autolog
Is it possible to measure signal strength of the RFXtrx433E?
I have just replaced the aerial and would like to understand if it has made the signal more reliable / stronger. :)
Re: Measuring Signal Strength?
PostPosted: Sat Nov 14, 2015 11:37 am
by kw123
Click on an rfx device and move the lower pan up. There you see the signal strength.
PostPosted: Sat Nov 14, 2015 12:26 pm
by autolog
Not seeing it on this device (battery Mood Switch):
or this one (mains socket plug switch):
Am I looking in the correct place?
PostPosted: Sat Nov 14, 2015 2:54 pm
by kw123
this what I see. If you don't see anything with your device you should ask the plugin author.
PostPosted: Mon Nov 16, 2015 4:01 am
by autolog
Maybe it depends on the device type?
