Some Errors
Posted: Fri Sep 11, 2015 3:18 am
Hi
Every so often I get some errors:
- Code: Select all
RFXCOM Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 290, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/RFXCOM.indigoPlugin/Contents/Server Plugin/RFXTRX.py", line 1851, in startComm
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/RFXCOM.indigoPlugin/Contents/Server Plugin/RFXTRX.py", line 582, in processPacket
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/RFXCOM.indigoPlugin/Contents/Server Plugin/RFXTRX.py", line 954, in showRain
<type 'exceptions.KeyError'>: key raintotal not found in dict
RFXCOM Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
- Code: Select all
Error device "Wind 2 Dir at Speed" state key humidity not defined (ignoring update request)
Error device "Wind 2 Dir at Speed" state key humidityStatus not defined (ignoring update request)
