Klik aan klik uit remote
Fri Aug 07, 2015 1:12 pm
Sanderkoers offline
Hello,
i am using RFXCOM with the klik aan klik uit modules (AC appliance).
when i am using a 4 channel wireless remote i want the remote to execute a action group if the ON or OFF command is send.
that is not a big problem that works fine, the only problem i have is when i want to execute for example the OFF command for a second time it does not run the action group, because indigo still thinks it is already of. But i could have turned the action group on with a ipad or other trigger.
is there anyone with the same problem ? or a solution ?
or is there a way to make RFXCOM set the value for the trigger to nothing after a few second (not ON not OFF)
Tue Sep 22, 2015 12:15 am
slackman1 offline
Re: Klik aan klik uit remote
Hi Sander,
Trigger om something like 'last changed' then filter on the state being On of Off will give you the desired behaviour....
