RFXCOM Device ID changes
Mon Jan 26, 2015 5:33 pm
GlennNZ offline
Hi
Thanks for RFX Plugin - in all working well.
Do have issue though where periodically one of the Oregon Scientific - temp/humd devices would stop updating and I get a unknown device ID= in the log from rfxcom plugin.
I then manage to figure out what device has changed its ID - update in the device settings to the new ID and all works well for a few days - before it changes back.
Any thoughts why these devices are changing IDs?
Glenn
Mon Jan 26, 2015 6:00 pm
Re: RFXCOM Device ID changes
They lose power just for a second then when they restart they come up with a new number. Same as if you replace the battery. The problem might be a bad metal strip that connects to the battery.
[edit] a bit contact spray on the metal strips might help
Tue Jan 27, 2015 1:13 am
GlennNZ offline
Thanks - Maybe :?
But it happens to all the temp devices (not just one) and have found if restart rfx plugin - problem goes away and picks up and updates the devices (without changing IDs)
Will continue to investigate further,
Glenn
