new setup - unable to receive rfxcom devices
Fri Jan 16, 2015 8:41 am
Redleg offline
I am unable to identify devices through my rfxcom setup. I have installed the drivers and plugin for my RFXtrx433. I am running firmware version (type1) 83 on the unit.
I have 5 Oregon thermo/humidity meters that have worked with the RFXcom unit in a VeraLite setup, but with Indigo I am just not able to get the device identified and installed.
Who can help?
This is what I receive from the data log:
00 00 00)
RFXCOM Debug PIC INIT IS: none
RFXCOM Debug send init cmd: 13 0 0 1 2 0 0 0 0 0 0 0 0 0 (0D 00 00 01 02 00 00 00 00 00 00 00 00 00)
RFXCOM Debug rcvd init reply: 13 1 0 1 2 83 83 0 0 32 1 1 0 0 (0D 01 00 01 02 53 53 00 00 20 01 01 00 00)
RFXCOM connected to RFXtrx 433.92 MHz, firmware version 83
RFXCOM currently enabled receiver protocols: Oregon Scientific
RFXCOM enabling receiver protocols: Undecoded
RFXCOM Debug send set mode cmd: 13 0 0 2 3 83 0 128 0 32 0 0 0 0 (0D 00 00 02 03 53 00 80 00 20 00 00 00 00)
RFXCOM Debug rcvd set mode reply: 13 1 0 2 3 83 83 128 0 32 1 1 0 0 (0D 01 00 02 03 53 53 80 00 20 01 01 00 00)
RFXCOM Debug send save to flash cmd: 13 0 0 3 6 0 0 0 0 0 0 0 0 0 (0D 00 00 03 06 00 00 00 00 00 00 00 00 00)
RFXCOM stored changed settings into non-volatile memory
RFXCOM Debug rcvd save to flash reply: 13 1 0 3 6 83 83 128 0 32 1 1 0 0 (0D 01 00 03 06 53 53 80 00 20 01 01 00 00)
RFXCOM Debug processing: 12 3 9 0 61 34 246 8 72 54 62 47 30 (0C 03 09 00 3D 22 F6 08 48 36 3E 2F 1E)
RFXCOM Debug ++++++++++++++
RFXCOM Debug processing: 11 3 9 1 52 28 146 69 228 17 144 8 (0B 03 09 01 34 1C 92 45 E4 11 90 08)
RFXCOM Debug processing: 15 3 9 2 83 156 209 165 44 156 175 97 85 188 141 1 (0F 03 09 02 53 9C D1 A5 2C 9C AF 61 55 BC 8D 01)
RFXCOM Debug processing: 15 3 9 3 83 156 209 165 40 156 175 97 85 60 101 1 (0F 03 09 03 53 9C D1 A5 28 9C AF 61 55 3C 65 01)
RFXCOM Debug processing: 15 3 9 4 83 156 209 165 36 156 175 97 85 188 60 1 (0F 03 09 04 53 9C D1 A5 24 9C AF 61 55 BC 3C 01)
RFXCOM Debug processing: 15 3 9 5 83 136 211 165 12 159 47 25 85 102 81 1 (0F 03 09 05 53 88 D3 A5 0C 9F 2F 19 55 66 51 01)
RFXCOM Debug processing: 15 3 9 6 83 136 211 165 8 159 47 25 85 230 185 1 (0F 03 09 06 53 88 D3 A5 08 9F 2F 19 55 E6 B9 01)
RFXCOM Debug processing: 21 3 9 7 136 136 211 165 4 159 175 58 193 116 41 107 224 11 71 149 55 6 (15 03 09 07 88 88 D3 A5 04 9F AF 3A C1 74 29 6B E0 0B 47 95 37 06)
RFXCOM Debug processing: 15 3 9 8 82 4 211 165 168 129 47 28 85 94 240 0 (0F 03 09 08 52 04 D3 A5 A8 81 2F 1C 55 5E F0 00)
RFXCOM Debug processing: 15 3 9 9 82 4 211 165 164 129 47 28 85 222 169 0 (0F 03 09 09 52 04 D3 A5 A4 81 2F 1C 55 DE A9 00)
RFXCOM Debug processing: 15 3 9 10 82 192 210 165 108 128 175 24 85 50 92 1 (0F 03 09 0A 52 C0 D2 A5 6C 80 AF 18 55 32 5C 01)
RFXCOM Debug processing: 15 3 9 11 82 192 210 165 104 128 175 24 85 178 180 1 (0F 03 09 0B 52 C0 D2 A5 68 80 AF 18 55 B2 B4 01)
RFXCOM Debug processing: 15 3 9 12 82 192 210 165 100 128 175 24 85 50 237 1 (0F 03 09 0C 52 C0 D2 A5 64 80 AF 18 55 32 ED 01)
Fri Jan 16, 2015 4:23 pm
Re: new setup - unable to receive rfxcom devices
I just spent half an hour trying to get mine to work (which arrived today).
Eventually, pressing the 'test' button in RFXCOM's plugin config dialogue box kicked it into life - the log was seeing the device and setting the protocols etc, as yours is, but it wasn't seeing any button presses from my Lightwave device; as soon as pressed Test, it started seeing my button presses.
Might be worth a try?
Peter
