Most recent version of the RFXCOM plugin is available here
Tue Jan 13, 2015 3:34 pm
RJdeKok offline
The most recent versions of the RFXCOM Plugin are available here. Note the newest version requires Indigo 7+, but an older version is still available for Indigo 6.
Mon Feb 16, 2015 1:36 pm
davidh offline
Re: Most recent version of the RFXCOM plugin is available he
I downloaded this, plug in the RFX and its lights flash on, but I think there is some error as it won't talk to X10 or Lightwave with Indigo, but does fine with Domoticz. I wonder ifI have missed something: here is what the event log says:
RFXCOM Error communication error occured
RFXCOM Debug Traceback (most recent call last):
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/RFXCOM.indigoPlugin/Contents/Server Plugin/RFXTRX.py", line 531, in readPacket
data = self.port.read()
File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/PlugIns/serial/serialposix.py", line 493, in read
raise SerialException('read failed: %s' % (e,))
SerialException: read failed: [Errno 6] Device not configured
RFXCOM Debug getConfiguration start
RFXCOM Error "RFXCOM serial port" serial port open error: [Errno 2] No such file or directory: '/dev/cu.usbserial-A1YHQTY1'
RFXCOM Error make sure the USB virtual serial port driver (ex: FTDI driver) is installed and correct port is selected
RFXCOM Error serial port could not be opened
Connected to MR26 interface on port usbserial-A1YHQTY1
RFXCOM initializing communication on port /dev/cu.usbserial-A1YHQTY1 at speed 38400
RFXCOM Debug serial port opened
RFXCOM Debug send reset cmd: 13 0 0 0 0 0 0 0 0 0 0 0 0 0 (0D 00 00 00 00 00 00 00 00 00 00 00 00 00)
RFXCOM Debug PIC INIT IS: none
RFXCOM Debug send init cmd: 13 0 0 1 2 0 0 0 0 0 0 0 0 0 (0D 00 00 01 02 00 00 00 00 00 00 00 00 00)
Error undefined byte from mr26 interface
RFXCOM Debug incomplete packet: 13 (0D)
RFXCOM Error incomplete packet received
RFXCOM Debug rcvd init reply: none
RFXCOM Error initialization failed (retrying in 10 seconds)
RFXCOM Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 290, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/RFXCOM.indigoPlugin/Contents/Server Plugin/RFXTRX.py", line 1842, in startComm
<type 'exceptions.AttributeError'>: 'NoneType' object has no attribute 'close'
Any suggestions for a Newbie? Many thanks.
Tue Aug 04, 2015 10:00 am
RJdeKok offline
It seems your RFXTRX is not connected to USB port usbserial-A1YHQTY1
