Brennenstuhl device not working
Thu Nov 27, 2014 2:03 am
zatter offline
Hi all,
I have bought a set of Brennenstuhl RCS1044N devices and can't get them to work properly with the most recent RFXCOM plugin. In the RfxMngr the device is recognized correctly as a PT2262 device with the proper codes etc. I have posted the sequence of log outputs from RfxMgr as well as the RFXCOM plugin output below. I also tried to just create an ELRO appliance device but wasn't sure about the correct code here. Any suggestions based on the output below?
The sequence below was triggered by an A ON command followed by an A OFF command.
Thanks very much !
09130000000551015E70
Packettype = Lighting4
subtype = PT2262
Sequence nbr = 0
Code = 000551
S1- S24 = 0000 0000 0000 0101 0101 0001
Pulse = 350 usec
Signal level = 7
0913000100155F015E70
subtype = PT2262
Sequence nbr = 1
Code = 00155F
S1- S24 = 0000 0000 0001 0101 0101 1111
Pulse = 350 usec
Signal level = 7
09130002000554015E70
subtype = PT2262
Sequence nbr = 2
Code = 000554
S1- S24 = 0000 0000 0000 0101 0101 0100
Pulse = 350 usec
Signal level = 7
0913000300155F015E70
subtype = PT2262
Sequence nbr = 3
Code = 00155F
Pulse = 350 usec
Signal level = 7
############## RXCCOM debug messages for the same sequence ############
27.11.2014 08:51:41
RFXCOM Debug processing: 9 19 0 0 0 5 81 1 94 112 (09 13 00 00 00 05 51 01 5E 70)
RFXCOM Error unknown device type detected (type = 19)
RFXCOM Debug ++++++++++++++
RFXCOM Debug processing: 9 19 0 1 0 21 95 1 94 112 (09 13 00 01 00 15 5F 01 5E 70)
27.11.2014 08:52:01
RFXCOM Debug processing: 9 19 0 2 0 5 84 1 94 112 (09 13 00 02 00 05 54 01 5E 70)
RFXCOM Debug processing: 9 19 0 3 0 21 95 1 94 112 (09 13 00 03 00 15 5F 01 5E 70)
Fri Nov 28, 2014 3:23 am
b_weijenberg offline
Re: Brennenstuhl device not working
Did you read chapter 7.3 in the RFXtrx User Guide?
Check the switch settings in the Brennenstuhl and use an ELRO AB400 device with house/device code from chapter 7.3
Fri Nov 28, 2014 8:20 am
zatter offline
Yes, I did this before but didn't figure out the correct mapping to continue using both the device remote as well as RXFCOM to control it. I got it working now so I can use A B C D on the remote and assign the correct device addresses as well to make that work. For example, house code A this will mean A5 -> A, A3 -> B, A2 -> C and A17 -> D.
Thanks for your reply!
