Proove Thermo/Hydro (TSS320) not working
Fri Nov 14, 2014 4:09 pm
robertgerman offline
Hi Guys,
I am using the RFXCOM plugin with Indigo 6.0.18. I can't seem to get the right info from the thermo sensor to create a new device within Indigo. This is what I am seeing in the event log, any ideas on how to get it to work? It's running on 433.92Mhz, witch should work, right? It says on the box that i works with the Tellstick, and all other devices I've used with me Tellstick earlier are working great with the RFXCOM module:
  RFXCOM Debug                    processing: 9 3 4 187 36 135 15 146 233 16 (09 03 04 BB 24 87 0F 92 E9 10)
  RFXCOM Error                    undecoded packet received: 09 03 04 BB 24 87 0F 92 E9 10
  RFXCOM Debug                    ++++++++++++++
  RFXCOM Debug                    processing: 9 3 4 188 36 149 4 223 245 64 (09 03 04 BC 24 95 04 DF F5 40)
  RFXCOM Error                    undecoded packet received: 09 03 04 BC 24 95 04 DF F5 40
  RFXCOM Debug                    processing: 9 3 4 189 35 176 9 202 185 224 (09 03 04 BD 23 B0 09 CA B9 E0)
  RFXCOM Error                    undecoded packet received: 09 03 04 BD 23 B0 09 CA B9 E0
Sat Nov 15, 2014 3:15 am
b_weijenberg offline
Re: Proove Thermo/Hydro (TSS320) not working
Did you enable the FineOffset/Hideki protocol in the RFXtrx?
Sat Nov 15, 2014 4:52 am
Yes, nearly every protocol is activated.
Sat Nov 15, 2014 5:09 am
Do not enable all protocols!!!
See chapter 2.4 in the RFXtrx User Guide:
The sensitivity of the receiver part is highly influenced by the number of protocols enabled.
Lesser protocols enabled will make the receiver more sensitive for the enabled protocols.
Are you able to use RFXmngr on a Windows system and check with only the FineOffset/Viking or Hideki protocol enabled?
Sat Nov 15, 2014 5:13 am
Aha, I see. Sorry, no Windows at home.
I have a much bigger problem now, I updated to the latest version of the RFXCOM plugin yesterday, no it doesn't ready anything anymore. Do you happen to have an older version (like 1.3)?
Sat Nov 15, 2014 6:23 am
What is in the log?
Are you the only one using this version?
Sat Nov 15, 2014 6:26 am
Acctually, got it to work be deactivating a lot of protocols.
So, back to the real problem, do I need to upgrade the firmware on the RFXCOM module?
Sat Nov 15, 2014 7:58 am
Check the firmware history file which is in the firmware download file.
Update firmware only if improvements are made on protocols you have in use or new protocols are added that you would like to use.
