klikaanklikuit awst6000 not connecting to rfxcom
Sat Oct 25, 2014 10:44 am
henkjanvries offline
I have a klikaanklikuit sensor which i can't add with the rfxcom plugin.
the aswt is a movement sensor, and it works when connected to other receivers, but when it transmits nothing is seen in the log.
I have rfxcom plugin set to debug.
does anyone have a tip or a solution?
https://www.youtube.com/watch?v=qwcI3htvvVE
http://www.klikaanklikuit.nl/advies/productwijzer/productwijzer-awst-6000/
Mon Oct 27, 2014 9:31 am
Lucardos offline
Re: klikaanklikuit awst6000 not connecting to rfxcom
I use the same movement sensor without any problem.
In the beginning I also did not see any signal on the RFXCOM, but found out that the signal strength of the AWST6000 is weaker then other KAKU units.
I have installed the KAKU "AEX-701" Wireless signal amplifier in between and all works fine now.
Sat Nov 01, 2014 5:59 am
Hi Lucardos
Ive held the sensor next to the rfxcom but im not getting anything in the debug log.
It does work because i connected it to a led lamp and that goes on when body heat is detected
Sat Nov 01, 2014 1:25 pm
b_weijenberg offline
Is the sensor received with the AC or ARC protocol enabled? (I suppose AC must be used)
If you have a Windows system you can try using RFXmngr.
Sat Dec 27, 2014 9:23 am
hi b_weijenberg
Ive downloaded the software and attached the rfxcom, i don't know how to receive any signal in the software.
any tips?
Sat Dec 27, 2014 9:43 am
With AC enabled in the RFXtrx433 you should be able to receive the sensor.
If possible test with RFXmngr on a Windows system.
Please contact RFXCOM support if you don't receive the sensor in RFXmngr.
