RFXCOM / LightwaveRF "state key brightnesslevel" error
Sat Aug 02, 2014 10:13 am
Vangelis offline
Got a weird error when trying to turn on a LightwaveRF light via RFCOM. Light is paired and working as I can test using the on/off pane under 'devices'
Am seeing this in the Event Log
device "Master Bedroom Light" state key brightnessLevel not defined (ignoring update request)
I don't get this if I do not put a 'brightness' value in the config, however the light still doesn't turn on :(
Any thoughts on what I am doing wrong?
Vangelis
Sat Aug 02, 2014 1:17 pm
Re: RFXCOM / LightwaveRF "state key brightnesslevel" error
Is the device setup as a dimmer or switch/appliance?
Thu Aug 07, 2014 5:30 am
Vangelis offline
Thanks Durosity - Changed the 'Device' from LWAppliance to LWDimmer but still doesn't work - however the error msg has dissappeared from the event log and I know get a brightness control in the Operation Panel.
Its weird that I can control it under the Device Tab but not as part of an Action :(
Thoughts?
Vangelis
Thu Aug 07, 2014 9:59 am
Have you tried deleting the action and creating a new one? Perhaps something has just got stuck?
Fri Aug 08, 2014 9:18 am
Vangelis offline
School Boy error in the end.... I was sending the 'Status to the Server' instead of executing the command to turn on and off the light.
@Durosity - Thanks for the tip on Appliance / Dimmer however
Vangelis
