Enabling protocols is only for receive active.
Transmit protocols are always enabled and independent of protocols enabled for receive.
So you can always control Rollertrol and LWRF and this does not require any protocol enabled.
For receive disable the BlindsT0 protocol and enable the LWRF protocol. You will now be able to receive wireless LWRF wall switches and LWRF remotes.
The Rollertrol remote cannot be received in this configuration.
See chapter 2.4 in the RFXtrx User Guide which protocols can be enabled at the same time.
http://www.rfxcom.com/Documents/RFXtrx% ... 0Guide.pdfThe LWFR door/window sensors transmit too much RF packets for about 3 to 5 seconds. It is therefore not advised to use this type of sensor. An alternative is the European X10 DS90 sensor. See also
http://www.domoticaforum.eu/viewtopic.php?f=27&t=7337 for more information on this subject.
