oregon scientific wind speed always north
Fri Jun 27, 2014 5:14 pm
the wind speed seems to be ok, the direction is always 0 / North. I also mounted it point south. no change.
here the debug log.
Jun 27, 2014, 6:03:45 PM
RFXCOM Debug getConfiguration start
RFXCOM initializing communication on port /dev/cu.usbserial-08WCLA8J at speed 38400
RFXCOM Debug serial port opened
RFXCOM Debug send reset cmd: 13 0 0 0 0 0 0 0 0 0 0 0 0 0 (0D 00 00 00 00 00 00 00 00 00 00 00 00 00)
RFXCOM Debug PIC INIT IS: none
RFXCOM Debug send init cmd: 13 0 0 1 2 0 0 0 0 0 0 0 0 0 (0D 00 00 01 02 00 00 00 00 00 00 00 00 00)
RFXCOM Debug rcvd init reply: 13 1 0 0 2 82 66 0 0 32 1 1 0 0 (0D 01 00 00 02 52 42 00 00 20 01 01 00 00)
RFXCOM connected to RFXrec 433.92 MHz, firmware version 66
RFXCOM currently enabled receiver protocols: Oregon Scientific
RFXCOM enabling undecoded packet displaying
RFXCOM Debug send set mode cmd: 13 0 0 2 3 82 0 128 0 32 0 0 0 0 (0D 00 00 02 03 52 00 80 00 20 00 00 00 00)
RFXCOM Debug rcvd set mode reply: 13 1 0 1 3 82 66 128 0 32 1 1 0 0 (0D 01 00 01 03 52 42 80 00 20 01 01 00 00)
RFXCOM Debug processing: 16 86 2 2 63 0 0 0 0 20 0 18 0 0 0 0 89 (10 56 02 02 3F 00 00 00 00 14 00 12 00 00 00 00 59)
RFXCOM Debug Wind sensor 63 direction 0 avgSpeed 2.00 gust 1.80.
RFXCOM Debug Wind sensor 63 direction 0 avgSpeed 4.50 gust 4.00.
RFXCOM Debug Wind sensor 63 in list
RFXCOM Debug ++++++++++++++
RFXCOM Debug processing: 16 86 2 3 63 0 0 0 0 15 0 18 0 0 0 0 89 (10 56 02 03 3F 00 00 00 00 0F 00 12 00 00 00 00 59)
RFXCOM Debug Wind sensor 63 direction 0 avgSpeed 1.50 gust 1.80.
RFXCOM Debug Wind sensor 63 direction 0 avgSpeed 3.40 gust 4.00.
RFXCOM Debug processing: 10 82 1 4 196 4 0 238 55 1 73 (0A 52 01 04 C4 04 00 EE 37 01 49)
RFXCOM Debug Temp sensor 1220 now 74.84 degrees and 55 humidity.
RFXCOM Debug Temp sensor 1220 in list
RFXCOM Debug UpdateMinMax state temperature value 74.8
RFXCOM Debug check if new day: last date 2014/06/27, new date 2014/06/27
is this a hardware or software problem?
it looks as if the data used are position 6 and 7 (starting at 0) : direction = (ord(data[6]) << 8) + ord(data[7]) (bolded in the log file.
position 6 and 7 are always 0.
any advice appreciated
ps. it was an adventure to put this on top of the roof... and it is difficult to change..
the python code looks like:
   def handleWind(self, data):
      devicetype = ord(data[1])
      subtype = ord(data[2])
      sensor = (ord(data[5]) << 8) + ord(data[4])
      direction = (ord(data[6]) << 8) + ord(data[7])    ####################<<<<<<< this where it gets calculated..
      avgSpeed = float(((ord(data[8]) << 8) + ord(data[9]))) / 10
      gust = float(((ord(data[10]) << 8) + ord(data[11]))) / 10
      batteryAndSignalData = data[16]
      batteryLevel = self.getBatteryLevel(batteryAndSignalData)
      signalStrength = self.getSignalStrength(batteryAndSignalData)
      temp = 0
      chill = 0
      #WIND 1-3 Temperature & wind chill not supported
      #WIND 4 Temperature & wind chill are supported
      if (subtype == 4):
         temp = ord(data[13])
         vFactor = 1
         temp2 = ord(data[12])
         if ord(data[12])>127:
            temp2 = ord(data[12])-128
            vFactor = -1
         temp+=(temp2*256)
         temp = temp*vFactor*0.1
         chill = ord(data[15])
         vFactor = 1
         chill2 = ord(data[14])
         if ord(data[14])>127:
            chill2 = ord(data[14])-128
            vFactor = -1
         chill+=(chill2*256)
         chill = chill*vFactor*0.1
      self.plugin.debugLog(u"Wind sensor %d direction %d avgSpeed %.2f gust %.2f." % (sensor, direction, avgSpeed, gust))
      avgSpeed = self.convertWindspeedToUnits(avgSpeed)
      gust = self.convertWindspeedToUnits(gust)
      if sensor in self.tempList.keys():
         self.plugin.debugLog(u"Wind sensor %d in list" % sensor)
         self.tempList[sensor].updateStateOnServer(key=u"avgSpeed", value=avgSpeed)
         self.tempList[sensor].updateStateOnServer(key=u"gust", value=gust)
         self.tempList[sensor].updateStateOnServer(key=u"directionDegrees", value=direction)
         self.tempList[sensor].updateStateOnServer(key=u"directionText", value=self.convertDirectionDegreesToText(direction))
         if (subtype == 4):
            self.tempList[sensor].updateStateOnServer(key=u"temperature", value=self.convertTemperatureToUnit(temp))
            self.tempList[sensor].updateStateOnServer(key=u"windChill", value=self.convertTemperatureToUnit(chill))
         self.tempList[sensor].updateStateOnServer(key=u"type", value=subtype)
         self.tempList[sensor].updateStateOnServer(key=u"lastUpdated", value=time.strftime('%Y/%m/%d %H:%M:%S'))
         self.tempList[sensor].updateStateOnServer(key=u"batteryLevel", value=batteryLevel)
         self.tempList[sensor].updateStateOnServer(key=u"signalStrength", value=signalStrength)
         display = "--"
         displayMode = self.tempList[sensor].pluginProps["displayField"]
         if displayMode == "Speed":
            display = "%d %s" % (avgSpeed, self.plugin.unitsWind)
         elif displayMode == "SpeedDirection":
            display = "%s at %d %s" % (self.convertDirectionDegreesToText(direction), avgSpeed, self.plugin.unitsWind)
         elif displayMode == "SpeedCompass":
            display = "%d %s %s" % (avgSpeed, self.plugin.unitsWind, direction)
         elif displayMode == "SpeedGust":
            display = "%d %s (%d %s)" % (avgSpeed, self.plugin.unitsWind, gust, self.plugin.unitsWind)
         self.tempList[sensor].updateStateOnServer(key=u"display", value=display)
         self.handleUnknownDevice(devicetype,sensor)
Sat Jun 28, 2014 2:51 am
b_weijenberg offline
Re: oregon scientific wind speed always north
The sensor transmits direction = 0! Check the WGR800 sensor.
Or a firmware problem in the RFXtrx, check with the latest firmware.
if you enter the received (hex) data in RFXmngr - Simulate with spaces removed you get:
Simulate: 105602033F000000000F00120000000059
Packettype = WIND
subtype = WIND2 - WGR800
Sequence nbr = 3
ID = 16128
Direction = 0 degrees N
Average speed = 1,5 mtr/sec = 5,4 km/hr = 3,36 mph
Wind gust = 1,8 mtr/sec = 6,48 km/hr = 4,03 mph
Signal level = 5
Battery = OK
Sat Jun 28, 2014 7:06 am
RFXCOM Debug Teststring=105602033F000000000F00120000000059
I get north when I use the test string..
I guess, I should upgrade the RFX software?
the link I found: http://www.rjdekok.nl/downloads/rfxtrx_ ... plugin.zip does not work..
where can I down load the latest version?
I have the following version:
Sat Jun 28, 2014 9:21 am
RFXtrx433/RFXrec433 firmware is available at http://rfxcom.com/Downloads
I have tested with firmware version 77 and this version operates correct:
28-6-2014 17:19:49= 1056010036000087000000000000001A69
Packettype = WIND
subtype = WIND1 - WTGR800
Sequence nbr = 0
ID = 13824
Direction = 135 degrees SE
Average speed = 0 mtr/sec = 0 km/hr = 0 mph
Wind gust = 0 mtr/sec = 0 km/hr = 0 mph
Signal level = 6
Battery = OK
Your sensor must be bad if you still receive North in the latest firmware version.
Sat Jun 28, 2014 9:43 am
ok downloaded the firmware. how to I install? could not find anything for the mac -- the attached EXE only works with windows.
Sat Jun 28, 2014 10:28 am
RFXflash can be used in Windows or Linux with mono.
Sat Jun 28, 2014 11:13 am
Does it work in a mac virtualbox win xp ?
Sat Jun 28, 2014 1:10 pm
tried a spare wind sensor from Norm, same result, must be the software.
Sat Jun 28, 2014 7:55 pm
have successfully flashed RFXcom 433 with version 77 in windows7 in a virtual box. I am astonished that that worked.
BUT no change its still just north. tried 2 oregon wind sensor devices!
Jun 28, 2014, 8:51:12 PM
RFXCOM Debug rcvd init reply: 13 1 0 1 2 82 77 0 0 32 1 1 0 0 (0D 01 00 01 02 52 4D 00 00 20 01 01 00 00)
RFXCOM connected to RFXrec 433.92 MHz, firmware version 77
RFXCOM Debug UpdateMinMax state temperature value 86.5
RFXCOM Debug check if new day: last date 2014/06/28, new date 2014/06/28
RFXCOM Debug UpdateMinMax state humidity value 0
RFXCOM Debug processing: 16 86 2 15 63 0 0 0 0 9 0 14 0 0 0 0 89 (10 56 02 0F 3F 00 00 00 00 09 00 0E 00 00 00 00 59)
RFXCOM Debug Wind sensor 63 direction 0 avgSpeed 0.90 gust 1.40.
RFXCOM Debug Wind sensor 63 direction 0 avgSpeed 2.00 gust 3.10.
RFXCOM Debug processing: 16 86 2 16 63 0 0 0 0 14 0 17 0 0 0 0 89 (10 56 02 10 3F 00 00 00 00 0E 00 11 00 00 00 00 59)
RFXCOM Debug Wind sensor 63 direction 0 avgSpeed 1.40 gust 1.70.
RFXCOM Debug Wind sensor 63 direction 0 avgSpeed 3.10 gust 3.80.
RFXCOM Debug processing: 10 82 1 17 196 4 0 224 56 1 73 (0A 52 01 11 C4 04 00 E0 38 01 49)
RFXCOM Debug Temp sensor 1220 now 72.32 degrees and 56 humidity.
RFXCOM Debug UpdateMinMax state temperature value 72.3
any other idea?
Sat Jun 28, 2014 8:06 pm
when I use the windows manager, I get:
1056020F3F000000000C000C0000000069
Packettype = WIND
Sequence nbr = 15
ID = 16128
Average speed = 1.2 mtr/sec = 4.32 km/hr = 2.68 mph
Wind gust = 1.2 mtr/sec = 4.32 km/hr = 2.68 mph
Signal level = 6
Battery = OK
still just north. Its hard to believe that 2 wind sensors have the same hardware defect. or may be they do.
An y suggestions?
Sat Jun 28, 2014 11:16 pm
berkinet offline
kw123 wrote:
...Any suggestions?
Well, you could move to the South Pole. Then the wind direction would always be correct. :wink:
Sun Jun 29, 2014 12:26 am
And I don't need AC
Sun Jun 29, 2014 6:55 am
Which Oregon sensor is this?
Sun Jun 29, 2014 7:54 am
WGR 800
Sun Jun 29, 2014 10:58 am
Is the wind direction correct displayed on the Oregon base station?
