Hi all,
Is is possible to pair a LightwaveRF bulb without the LightwaveRF bulb, using an RFXtrx433 and Indigo?
I've got what I assume is the latest RFXCOM plugin for the RFXtrx433 and the latest version of Indigo running, plus a new LightwaveRF CFR bulb.
If so - could someone be kind enough to explain it? Messed around trying to get the CFR into pairing mode, set up a LightwaveRF appliance in Indio (not sure if the right device type, was only one I could see with on/off option) but no luck...
