RFXtrx433 and Indigo 6 and Home Easy doorbell
Tue May 06, 2014 8:31 am
matei offline
Hi all...
Newbie here with Indigo 6 and the RFXtrx433 interface. I'm trying to set up the Home Easy HE306 doorbell so that Indigo can detect/react to it.
I've installed the RFXCOM plugin, enabled debugging however I don't see anything in the logs like a module address in the logs after pressing the button on the doorbell, thinking that maybe is there something that I overlooked?
Tue May 06, 2014 10:32 am
Re: RFXtrx433 and Indigo 6 and Home Easy doorbell
Wed Jun 25, 2014 7:03 am
col offline
I have just tried to set up this door bell but can't find the address when the button is pressed, I have enabled debugging but nothing is shown in the event log,
I am using the extended rfxcom and plugin
Any thoughts?
Wed Jun 25, 2014 8:14 am
may be you need to press the door bell button.. then lock at the log file, if noting gets received, it might be out of range.
Wed Jun 25, 2014 8:26 am
col offline
I have pressed the door bell right by the RFXCOM transceiver so its not that.
Thu Jun 26, 2014 2:36 am
Vangelis offline
Do you see any activity on the RFXtrx433 led's? If not then it might be that the doorbell is running on a different frequency than the RFXtrx433 is set to receive?
Thu Jun 26, 2014 4:17 am
b_weijenberg offline
Enable the ARC protocol in the RFXtrx if the push button has an address code wheel (A-P).
Enable the AC protocol in the RFXtrx if the push button doesn't have an address code wheel but transmits the HomeEasy protocol for learning mode devices.
Thu Jun 26, 2014 5:24 am
col offline
Thanks, I tried that and still no joy, when I press the door bel button the lights on the RFXCOM don't do anything, its as if it can't even see the doorbell.
Thu Jun 26, 2014 5:31 am
Are you able to try with RFXmngr on a Windows system?
Enable only ARC and undec on.
If nothing received try with only AC and undec on.
Thu Jun 26, 2014 6:30 am
col offline
Fantastic, that solved it, many thanks for your help :D
Thu Jun 26, 2014 6:32 am
What solved it?
Thu Jun 26, 2014 6:56 am
col offline
Enable only ARC.
