RFXtrx433 & RFXtrx315
Mon Oct 28, 2013 3:16 pm
tpthaler offline
Hello,
I have a need for using both the RFXtrx433 & RFXtrx315 is this at all possible? I know as it's written it only supports one, is it possible to have two instances of the same plugin (do I just need to hack some of the code to make indigo think it's two different plugins)?
Mon Oct 28, 2013 4:12 pm
tpthaler offline
Re: RFXtrx433 & RFXtrx315
I don't have my RFXtrx315 yet, but it looks like what I thought I could do works... I renamed all the instances in the code and files of RFXCOM and RFXTRX to RFXCOM315 and RFXTRX315, and compiled the RFXTRX315.py file and installed. It installed ok, so when I get my RFXtrx315 in the mail, I'll let you know if it worked ok....
Mon Oct 28, 2013 5:44 pm
The .py files can probably be left as they are (adding 315 to instances of RFXCOM and RFXTRX is likely not necessary), but do make sure that you modified the Info.plist in the Contents folder. The plugin needs to have a unique CFBundleDisplayName and CFBundleIdentifier values.
Mon Oct 28, 2013 7:04 pm
tpthaler offline
Thanks for the info... I tried that first, and it didn't seem to work, but I might have screwed something else up... I am a java programmer of 15+ years, so this python stuff is all new to me!
