Unidentified sensor
Mon Sep 09, 2013 3:38 pm
jalves offline
Unidentified sensor
I just installed a RFXrec433 on my system. Followed the instructions and it easily found my Oregon Scientific outdoor temp/humidity sensor.
For fun I turned on "log unknown sensors as error". When I do that it reports an unknown device of id 333, type 82. The only protocol I've enabled on the plugin is the Oregon Scientific one. Any idea what this sensor is?
I do have an older Taylor weather station with an 433 mhz outdoor sensor. Could it be that? How would I define that for the plugin?
Here's a copy of the relevant part of the log:
Sep 9, 2013 5:26:11 PM
Reloading plugin "RFXCOM 1.3.6"
Stopping plugin "RFXCOM 1.3.6" (pid 10257)
Stopped plugin "RFXCOM 1.3.6"
Starting plugin "RFXCOM 1.3.6" (pid 10341)
Started plugin "RFXCOM 1.3.6"
RFXCOM initializing communication on port /dev/cu.usbserial-04WPINK0 at speed 38400
RFXCOM connected to RFXrec 433.92 MHz, firmware version 67
RFXCOM currently enabled receiver protocols: Oregon Scientific
Sep 9, 2013 5:28:51 PM
Sep 9, 2013 5:29:23 PM
RFXCOM Error unknown device detected (id = 333, type = 82). Select a Temperature sensor (with humidity) from the list of devices
Jeff
Sat Jun 14, 2014 6:07 am
RJdeKok offline
Re: Unidentified sensor
Hi Jalves,
An 82 is one of the following Temperature and humidity sensors
subtype:
0x01 = TH1 is THGN122/123, THGN132, THGR122/228/238/268 0x02 = TH2 is THGR810, THGN800
0x03 = TH3 is RTGR328
0x04 = TH4 is THGR328
0x05 = TH5 is WTGR800
0x06 = TH6 is THGR918/928, THGRN228, THGN500
0x07 = TH7 is TFA TS34C, Cresta
0x08 = TH8 is WT260,WT260H,WT440H,WT450,WT450H 0x09 = TH9 is Viking 02035,02038 (02035 has no humidity) 0x0A = TH10 is Rubicson
0x0B = TH11 is EW109
0x0C = TH12 is Imagintronix Soil sensor
Sat Jun 14, 2014 6:17 am
jalves offline
Thanks. I suspect this belongs to a neighbor. I'm going to see if I can get it added.
Jeff
