hamw wrote:Does anyone know the range of these sensors? I'm looking into monitoring my crawl space with either 1-wire or perhaps this solution. The signal would have to travel probably 75 ft and pass through walls etc. I currently have some wireless sensors down there from a cheap AcuRite weather station and it works, but it is very location dependent.
Also, I was thinking I might clip the terminals to a 3v wall wart to eliminate the batteries - thoughts?
Dewster35 wrote:Can the existing device in indigo simply have it's ID changed if there is a battery change? I ran into problems duplicating devices and changing the ID's... would be a real pain if you have to create a new device each time... that means I've got to go into my control pages and change those each time, change my triggers...etc, etc.
AlaskaDave wrote:1. When configuring the RFXCOM plug-in I was presented with two serial port options. USBSERIAL-03VGC637 (chose) and USBSERIAL-A700ahVc. Whey two serial port options and did I select the right one? Does it matter?
