Data filters are gone!
Fri Jul 07, 2023 8:50 am
roquej offline
All my setup data filters are gone. Any suggestions on how to recover them? Or do I have to bite the bullet and reenter them?
JP
Fri Jul 07, 2023 9:03 am
roquej offline
Re: Data filters are gone!
Devices disappear also. Please, tell me there is way to recover them...
JP
Fri Jul 07, 2023 9:12 am
jltnol offline
Don't know if there is a way to recover them but I'd make sure you are using the right database. Could be something happened and you are using a new one. Hope this is an easy fix for you.
Fri Jul 07, 2023 12:52 pm
roquej offline
Thank you. That makes sense. How do I change the DB?
JP
Sat Jul 08, 2023 12:01 am
jltnol offline
So again, not sure what might have caused everything to disappear, but Indigo stores the working database in the Library/Application Support/Perceptive Automation folder. If everything is gone, it would make sense that the data base you are currently using isn't the right one. You can look in the folder mentioned above and see if there is an older one, and in Indigo, you can go to the File/Select Database menu, and it should bring you to the folder where an older database might be.
Sat Jul 08, 2023 9:09 am
roquej offline
The indigo DB is fine. Nothing else is the issue. The InfluxDB just got blanked. I bit the bullet and recreated the device, variable, and filters in the plugin and I am back to normal. And then made a backup of the InfluxDB folder, just in case.
The dashboard was fine, just no data.
JP
