Error after upgrade
Sun Jun 10, 2018 9:22 am
haavarda offline
Error after upgrade
After upgrading to the latest version the log throw the following error:
10. jun. 2018, 17:23:14
   Enabling plugin "Grafana Home Dashboard 1.0.2"
   Starting plugin "Grafana Home Dashboard 1.0.2" (pid 43657)
   Started plugin "Grafana Home Dashboard 1.0.2"
   Grafana Home Dashboard          starting the InfluxDB Server...
10. jun. 2018, 17:24:02
   Grafana Home Dashboard Error    error starting the InfluxDB server... will attempt to resolve.
   Grafana Home Dashboard              no log records exist
   Grafana Home Dashboard          ######## About to (re) start InfluxDB.  Please be patient while this happens. ########
   Grafana Home Dashboard          shutting down the InfluxDB Server...
   Grafana Home Dashboard Error    cannot seem to start InfluxDB, triggering a rebuilding (reset) of Influx config
   Grafana Home Dashboard Error    error while connecting to InfluxDB, this can happen when the Indigo server is slow to start up.  Will continue to try silently in the background.
   Grafana Home Dashboard          config file for InfluxDB has been updated; server will restart shortly.
10. jun. 2018, 17:25:07
   Grafana Home Dashboard Error    failed to start the Influx server after a rebuild, please check your config and contact support on the Indigo forums
Any idea?
Håvard
Sun Jun 10, 2018 11:02 am
vtmikel offline
Re: Error after upgrade
Can you please disable the plguin, and re-enable it. If you have the problem again, please open a ticket on github here: https://github.com/mlamoure/indigo-graf ... ard/issues
Please go into your folder: /Library/Application Support/Perceptive Automation/Indigo 7/Logs/com.vtmikel.grafana
and post the contents / attach your plugin.log file.
Sun Jun 10, 2018 11:13 am
haavarda offline
I have actually experienced this before. But I had just started with Grafana, so I just deleted everything and started over. That "fixed" it.
I have also tried to reload the plugin, and restart the mac, no go.
Will my log file expose anything sensitive? (password etc)
Håvard
Sun Jun 10, 2018 11:20 am
vtmikel offline
It should not. If you want to be extra cautious you can attach the log to a PM here on the forums, or email me: mlamoure at gmail
Sun Jun 10, 2018 11:23 am
haavarda offline
It seams as this is repeating after the error:
2018-06-10 15:22:45.783   DEBUG   Plugin.runConcurrentThread:   detected that a Influx reset needs to occur...
2018-06-10 15:22:45.829   DEBUG   Plugin.CreateInfluxConfig:   setting the InfluxDB data location to: /Users/Server/Documents/InfluxDB
2018-06-10 15:22:45.830   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [meta]
2018-06-10 15:22:45.830   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [data]
2018-06-10 15:22:45.830   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [coordinator]
2018-06-10 15:22:45.831   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [retention]
2018-06-10 15:22:45.831   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [shard-precreation]
2018-06-10 15:22:45.831   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-10 15:22:45.831   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-10 15:22:45.831   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-10 15:22:45.831   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to false
2018-06-10 15:22:45.831   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-10 15:22:45.831   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-10 15:22:45.831   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-10 15:22:45.831   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-10 15:22:45.831   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-10 15:22:45.832   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-10 15:22:45.832   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-10 15:22:45.832   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 15:22:45.832   DEBUG   Plugin.DeleteInfluxAdmin:   droping database user: "user"
2018-06-10 15:22:45.832   DEBUG   Plugin.CreateInfluxAdmin:   creating database admin user: "user"
2018-06-10 15:22:45.832   DEBUG   Plugin.CreateInfluxConfig:   setting the InfluxDB data location to: /Users/Server/Documents/InfluxDB
2018-06-10 15:22:45.833   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [meta]
2018-06-10 15:22:45.833   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [data]
2018-06-10 15:22:45.833   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [coordinator]
2018-06-10 15:22:45.833   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [retention]
2018-06-10 15:22:45.833   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [shard-precreation]
2018-06-10 15:22:45.833   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-10 15:22:45.833   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-10 15:22:45.834   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-10 15:22:45.834   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to true
2018-06-10 15:22:45.834   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-10 15:22:45.834   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-10 15:22:45.834   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-10 15:22:45.834   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-10 15:22:45.834   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-10 15:22:45.834   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-10 15:22:45.834   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-10 15:22:45.835   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 15:22:45.835   DEBUG   Plugin.connect:   running connect()
2018-06-10 15:22:45.835   DEBUG   Plugin.connect:      haulting connect(); StopConnectionAttempts = true
2018-06-10 15:22:50.838   DEBUG   Plugin.checkServerStatus:   running checkServerStatus()
2018-06-10 15:22:50.839   DEBUG   Plugin.checkServerStatus:   completed checkServerStatus(), GrafanaServerStatus: stopped, InfluxServerStatus: stopped
2018-06-10 15:22:50.839   DEBUG   Plugin.runConcurrentThread:   detected that a Influx reset needs to occur...
2018-06-10 15:22:50.887   DEBUG   Plugin.CreateInfluxConfig:   setting the InfluxDB data location to: /Users/Server/Documents/InfluxDB
2018-06-10 15:22:50.888   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [meta]
2018-06-10 15:22:50.888   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [data]
2018-06-10 15:22:50.888   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [coordinator]
2018-06-10 15:22:50.888   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [retention]
2018-06-10 15:22:50.889   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [shard-precreation]
2018-06-10 15:22:50.889   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-10 15:22:50.889   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-10 15:22:50.889   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-10 15:22:50.889   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to false
2018-06-10 15:22:50.889   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-10 15:22:50.889   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-10 15:22:50.889   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-10 15:22:50.889   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-10 15:22:50.889   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-10 15:22:50.889   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-10 15:22:50.890   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-10 15:22:50.890   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 15:22:50.890   DEBUG   Plugin.DeleteInfluxAdmin:   droping database user: "user"
2018-06-10 15:22:50.890   DEBUG   Plugin.CreateInfluxAdmin:   creating database admin user: "user"
2018-06-10 15:22:50.890   DEBUG   Plugin.CreateInfluxConfig:   setting the InfluxDB data location to: /Users/Server/Documents/InfluxDB
2018-06-10 15:22:50.891   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [meta]
2018-06-10 15:22:50.891   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [data]
2018-06-10 15:22:50.891   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [coordinator]
2018-06-10 15:22:50.891   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [retention]
2018-06-10 15:22:50.891   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [shard-precreation]
2018-06-10 15:22:50.891   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-10 15:22:50.892   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-10 15:22:50.892   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-10 15:22:50.892   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to true
2018-06-10 15:22:50.892   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-10 15:22:50.892   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-10 15:22:50.892   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-10 15:22:50.892   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-10 15:22:50.892   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-10 15:22:50.892   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-10 15:22:50.892   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-10 15:22:50.893   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 15:22:50.893   DEBUG   Plugin.connect:   running connect()
2018-06-10 15:22:50.893   DEBUG   Plugin.connect:      haulting connect(); StopConnectionAttempts = true
2018-06-10 15:22:55.898   DEBUG   Plugin.checkServerStatus:   running checkServerStatus()
2018-06-10 15:22:55.899   DEBUG   Plugin.checkServerStatus:   completed checkServerStatus(), GrafanaServerStatus: stopped, InfluxServerStatus: stopped
Håvard
Sun Jun 10, 2018 11:30 am
vtmikel offline
Is the InfluxDB user name you have set "user" or did you edit that from your logs? Can you try something else for the user name?
Sun Jun 10, 2018 11:31 am
haavarda offline
Sorry I just changed it in the log. I use the default.
Håvard
Sun Jun 10, 2018 11:39 am
vtmikel offline
Is there anything else in the log file you are removing? I'm expecting other entries that I do not see here.
Sun Jun 10, 2018 11:42 am
haavarda offline
Nope. But here is a part of it. Copied from the last part. The hole file is 26mb
2018-06-10 17:30:51.785   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-10 17:30:51.785   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-10 17:30:51.785   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-10 17:30:51.785   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to false
2018-06-10 17:30:51.786   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-10 17:30:51.786   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-10 17:30:51.786   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-10 17:30:51.786   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-10 17:30:51.786   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-10 17:30:51.786   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-10 17:30:51.786   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-10 17:30:51.787   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 17:30:51.787   DEBUG   Plugin.DeleteInfluxAdmin:   droping database user: indigo
2018-06-10 17:30:51.787   DEBUG   Plugin.CreateInfluxAdmin:   creating database admin user: indigo
2018-06-10 17:30:51.787   DEBUG   Plugin.CreateInfluxConfig:   setting the InfluxDB data location to: /Users/Server/Documents/InfluxDB
2018-06-10 17:30:51.788   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [meta]
2018-06-10 17:30:51.788   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [data]
2018-06-10 17:30:51.788   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [coordinator]
2018-06-10 17:30:51.788   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [retention]
2018-06-10 17:30:51.788   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [shard-precreation]
2018-06-10 17:30:51.788   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-10 17:30:51.788   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-10 17:30:51.788   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-10 17:30:51.788   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to true
2018-06-10 17:30:51.788   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-10 17:30:51.788   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-10 17:30:51.789   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-10 17:30:51.789   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-10 17:30:51.789   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-10 17:30:51.789   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-10 17:30:51.789   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-10 17:30:51.789   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 17:30:51.789   DEBUG   Plugin.connect:   running connect()
2018-06-10 17:30:51.789   DEBUG   Plugin.connect:      haulting connect(); StopConnectionAttempts = true
2018-06-10 17:30:56.790   DEBUG   Plugin.checkServerStatus:   running checkServerStatus()
2018-06-10 17:30:56.790   DEBUG   Plugin.checkServerStatus:   completed checkServerStatus(), GrafanaServerStatus: stopped, InfluxServerStatus: stopped
2018-06-10 17:30:56.790   DEBUG   Plugin.runConcurrentThread:   detected that a Influx reset needs to occur...
2018-06-10 17:30:56.838   DEBUG   Plugin.CreateInfluxConfig:   setting the InfluxDB data location to: /Users/Server/Documents/InfluxDB
2018-06-10 17:30:56.839   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [meta]
2018-06-10 17:30:56.840   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [data]
2018-06-10 17:30:56.840   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [coordinator]
2018-06-10 17:30:56.840   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [retention]
2018-06-10 17:30:56.840   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [shard-precreation]
2018-06-10 17:30:56.840   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-10 17:30:56.840   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-10 17:30:56.840   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-10 17:30:56.840   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to false
2018-06-10 17:30:56.840   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-10 17:30:56.840   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-10 17:30:56.840   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-10 17:30:56.841   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-10 17:30:56.841   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-10 17:30:56.841   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-10 17:30:56.841   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-10 17:30:56.841   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 17:30:56.841   DEBUG   Plugin.DeleteInfluxAdmin:   droping database user: indigo
2018-06-10 17:30:56.842   DEBUG   Plugin.CreateInfluxAdmin:   creating database admin user: indigo
2018-06-10 17:30:56.842   DEBUG   Plugin.CreateInfluxConfig:   setting the InfluxDB data location to: /Users/Server/Documents/InfluxDB
2018-06-10 17:30:56.843   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [meta]
2018-06-10 17:30:56.843   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [data]
2018-06-10 17:30:56.843   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [coordinator]
2018-06-10 17:30:56.843   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [retention]
2018-06-10 17:30:56.843   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [shard-precreation]
2018-06-10 17:30:56.843   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-10 17:30:56.843   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-10 17:30:56.843   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-10 17:30:56.843   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to true
2018-06-10 17:30:56.843   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-10 17:30:56.843   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-10 17:30:56.844   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-10 17:30:56.844   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-10 17:30:56.844   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-10 17:30:56.844   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-10 17:30:56.844   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-10 17:30:56.844   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 17:30:56.844   DEBUG   Plugin.connect:   running connect()
2018-06-10 17:30:56.844   DEBUG   Plugin.connect:      haulting connect(); StopConnectionAttempts = true
2018-06-10 17:31:01.845   DEBUG   Plugin.checkServerStatus:   running checkServerStatus()
2018-06-10 17:31:01.845   DEBUG   Plugin.checkServerStatus:   completed checkServerStatus(), GrafanaServerStatus: stopped, InfluxServerStatus: stopped
2018-06-10 17:31:01.845   DEBUG   Plugin.runConcurrentThread:   detected that a Influx reset needs to occur...
2018-06-10 17:31:01.891   DEBUG   Plugin.CreateInfluxConfig:   setting the InfluxDB data location to: /Users/Server/Documents/InfluxDB
2018-06-10 17:31:01.892   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [meta]
2018-06-10 17:31:01.892   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [data]
2018-06-10 17:31:01.893   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [coordinator]
2018-06-10 17:31:01.893   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [retention]
2018-06-10 17:31:01.893   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [shard-precreation]
2018-06-10 17:31:01.893   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-10 17:31:01.893   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-10 17:31:01.893   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-10 17:31:01.893   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to false
2018-06-10 17:31:01.893   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-10 17:31:01.893   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-10 17:31:01.893   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-10 17:31:01.893   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-10 17:31:01.894   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-10 17:31:01.894   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-10 17:31:01.894   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-10 17:31:01.894   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 17:31:01.894   DEBUG   Plugin.DeleteInfluxAdmin:   droping database user: indigo
2018-06-10 17:31:01.894   DEBUG   Plugin.CreateInfluxAdmin:   creating database admin user: indigo
2018-06-10 17:31:01.894   DEBUG   Plugin.CreateInfluxConfig:   setting the InfluxDB data location to: /Users/Server/Documents/InfluxDB
2018-06-10 17:31:01.896   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [meta]
2018-06-10 17:31:01.896   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [data]
2018-06-10 17:31:01.896   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [coordinator]
2018-06-10 17:31:01.896   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [retention]
2018-06-10 17:31:01.896   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [shard-precreation]
2018-06-10 17:31:01.896   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-10 17:31:01.896   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-10 17:31:01.896   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-10 17:31:01.897   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to true
2018-06-10 17:31:01.897   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-10 17:31:01.897   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-10 17:31:01.897   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-10 17:31:01.897   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-10 17:31:01.897   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-10 17:31:01.897   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-10 17:31:01.897   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-10 17:31:01.898   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 17:31:01.898   DEBUG   Plugin.connect:   running connect()
2018-06-10 17:31:01.898   DEBUG   Plugin.connect:      haulting connect(); StopConnectionAttempts = true
2018-06-10 17:31:06.898   DEBUG   Plugin.checkServerStatus:   running checkServerStatus()
2018-06-10 17:31:06.898   DEBUG   Plugin.checkServerStatus:   completed checkServerStatus(), GrafanaServerStatus: stopped, InfluxServerStatus: stopped
2018-06-10 17:31:06.899   DEBUG   Plugin.runConcurrentThread:   detected that a Influx reset needs to occur...
2018-06-10 17:31:06.949   DEBUG   Plugin.CreateInfluxConfig:   setting the InfluxDB data location to: /Users/Server/Documents/InfluxDB
2018-06-10 17:31:06.951   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [meta]
2018-06-10 17:31:06.951   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [data]
2018-06-10 17:31:06.951   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [coordinator]
2018-06-10 17:31:06.951   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [retention]
2018-06-10 17:31:06.951   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [shard-precreation]
2018-06-10 17:31:06.951   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-10 17:31:06.951   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-10 17:31:06.951   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-10 17:31:06.951   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to false
2018-06-10 17:31:06.952   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-10 17:31:06.952   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-10 17:31:06.952   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-10 17:31:06.952   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-10 17:31:06.952   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-10 17:31:06.952   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-10 17:31:06.952   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-10 17:31:06.953   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 17:31:06.953   DEBUG   Plugin.DeleteInfluxAdmin:   droping database user: indigo
2018-06-10 17:31:06.953   DEBUG   Plugin.CreateInfluxAdmin:   creating database admin user: indigo
2018-06-10 17:31:06.953   DEBUG   Plugin.CreateInfluxConfig:   setting the InfluxDB data location to: /Users/Server/Documents/InfluxDB
2018-06-10 17:31:06.970   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [meta]
2018-06-10 17:31:06.971   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [data]
2018-06-10 17:31:06.971   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [coordinator]
2018-06-10 17:31:06.971   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [retention]
2018-06-10 17:31:06.971   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [shard-precreation]
2018-06-10 17:31:06.971   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-10 17:31:06.971   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-10 17:31:06.971   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-10 17:31:06.971   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to true
2018-06-10 17:31:06.971   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-10 17:31:06.971   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-10 17:31:06.972   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-10 17:31:06.972   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-10 17:31:06.972   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-10 17:31:06.972   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-10 17:31:06.972   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-10 17:31:06.972   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 17:31:06.972   DEBUG   Plugin.connect:   running connect()
2018-06-10 17:31:06.972   DEBUG   Plugin.connect:      haulting connect(); StopConnectionAttempts = true
2018-06-10 17:31:07.486   DEBUG   Plugin.runConcurrentThread:   Received StopThread
2018-06-10 17:31:10.366   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 17:31:10.366   DEBUG   Plugin.StartInfluxServer:   starting the InfluxDB Server using command: /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/influxdb/influxd run -config /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/influxdb/influxdb.conf
2018-06-10 17:32:00.389   ERROR   Plugin.StartInfluxServer:   error starting the InfluxDB server... will attempt to resolve.
2018-06-10 17:32:00.389   DEBUG   Plugin.restartAll:   not currently connected to any InfluxDB, so will not start the Grafana Server
2018-06-10 17:32:00.390   DEBUG   Plugin.BuildConfigurationLists:   starting BuildConfigurationLists()
2018-06-10 17:32:02.162   DEBUG   Plugin.ValidateConfigLists:   running ValidateConfigLists()
2018-06-10 17:32:02.196   DEBUG   Plugin.ValidateConfigLists:   completed ValidateConfigLists()
2018-06-10 17:32:02.292   DEBUG   Plugin.BuildConfigurationLists:   completed BuildConfigurationLists
2018-06-10 17:32:02.292   DEBUG   Plugin.pruneFilterBlocksEventLog:   entering pruneFilterBlocksEventLog()
2018-06-10 17:32:02.292   DEBUG   Plugin.pruneFilterBlocksEventLog:   log prune error: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Grafana Home Dashboard.indigoPlugin/Contents/Server Plugin/filter.log'
2018-06-10 17:32:02.292   DEBUG   Plugin.pruneFilterBlocksEventLog:   completed pruneFilterBlocksEventLog()
2018-06-10 17:32:03.049   DEBUG   Plugin.runConcurrentThread:   fully initiatlized and ready.  starting concurrent tread...
2018-06-10 17:32:08.054   DEBUG   Plugin.checkServerStatus:   running checkServerStatus()
2018-06-10 17:32:08.054   DEBUG   Plugin.checkServerStatus:   completed checkServerStatus(), GrafanaServerStatus: stopped, InfluxServerStatus: stopped
2018-06-10 17:32:08.054   DEBUG   Plugin.runConcurrentThread:   detected that a influx server restart needs to occur...
2018-06-10 17:32:08.102   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 17:32:08.102   ERROR   Plugin.StartInfluxServer:   cannot seem to start InfluxDB, triggering a rebuilding (reset) of Influx config
2018-06-10 17:32:08.102   DEBUG   Plugin.connect:   running connect()
2018-06-10 17:32:08.112   DEBUG   Plugin.connect:      connection attempt 1: error while connecting to InfluxDB: HTTPConnectionPool(host='localhost', port=8086): Max retries exceeded with url: /query?q=CREATE+DATABASE+%22indigo%22&db=indigo (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x108c557d0>: Failed to establish a new connection: [Errno 61] Connection refused',))
2018-06-10 17:32:08.112   ERROR   Plugin.connect:   error while connecting to InfluxDB, this can happen when the Indigo server is slow to start up.  Will continue to try silently in the background.
2018-06-10 17:32:08.112   DEBUG   Plugin.connect:   completed connect()
2018-06-10 17:32:13.114   DEBUG   Plugin.checkServerStatus:   running checkServerStatus()
2018-06-10 17:32:13.114   DEBUG   Plugin.checkServerStatus:   completed checkServerStatus(), GrafanaServerStatus: stopped, InfluxServerStatus: stopped
2018-06-10 17:32:13.114   DEBUG   Plugin.runConcurrentThread:   detected that a Influx reset needs to occur...
2018-06-10 17:32:13.163   DEBUG   Plugin.CreateInfluxConfig:   setting the InfluxDB data location to: /Users/Server/Documents/InfluxDB
2018-06-10 17:32:13.164   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [meta]
2018-06-10 17:32:13.164   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [data]
2018-06-10 17:32:13.164   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [coordinator]
2018-06-10 17:32:13.164   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [retention]
2018-06-10 17:32:13.164   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [shard-precreation]
2018-06-10 17:32:13.165   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-10 17:32:13.165   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-10 17:32:13.165   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-10 17:32:13.165   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to false
2018-06-10 17:32:13.165   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-10 17:32:13.165   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-10 17:32:13.165   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-10 17:32:13.165   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-10 17:32:13.165   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-10 17:32:13.165   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-10 17:32:13.165   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-10 17:32:13.166   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 17:32:13.166   DEBUG   Plugin.StartInfluxServer:   starting the InfluxDB Server using command: /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/influxdb/influxd run -config /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/influxdb/influxdb.conf
2018-06-10 17:33:03.203   ERROR   Plugin.StartInfluxServer:   error starting the InfluxDB server... will attempt to resolve.
2018-06-10 17:33:03.204   DEBUG   Plugin.DeleteInfluxAdmin:   droping database user: indigo
2018-06-10 17:33:03.204   DEBUG   Plugin.CreateInfluxAdmin:   creating database admin user: indigo
2018-06-10 17:33:03.205   DEBUG   Plugin.CreateInfluxConfig:   setting the InfluxDB data location to: /Users/Server/Documents/InfluxDB
2018-06-10 17:33:03.206   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [meta]
2018-06-10 17:33:03.207   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [data]
2018-06-10 17:33:03.207   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [coordinator]
2018-06-10 17:33:03.207   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [retention]
2018-06-10 17:33:03.207   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [shard-precreation]
2018-06-10 17:33:03.207   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-10 17:33:03.207   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-10 17:33:03.207   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-10 17:33:03.208   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to true
2018-06-10 17:33:03.208   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-10 17:33:03.208   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-10 17:33:03.208   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-10 17:33:03.208   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-10 17:33:03.208   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-10 17:33:03.208   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-10 17:33:03.209   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-10 17:33:03.209   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 17:33:03.209   ERROR   Plugin.StartInfluxServer:   failed to start the Influx server after a rebuild, please check your config and contact support on the Indigo forums
2018-06-10 17:33:03.209   DEBUG   Plugin.connect:   running connect()
2018-06-10 17:33:03.219   DEBUG   Plugin.connect:      connection attempt 2: error while connecting to InfluxDB: HTTPConnectionPool(host='localhost', port=8086): Max retries exceeded with url: /query?q=CREATE+DATABASE+%22indigo%22&db=indigo (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x108c3eb50>: Failed to establish a new connection: [Errno 61] Connection refused',))
2018-06-10 17:33:03.219   DEBUG   Plugin.connect:       triggering a InfluxDB restart since connections are failing
2018-06-10 17:33:03.219   DEBUG   Plugin.connect:   completed connect()
2018-06-10 17:33:03.220   DEBUG   Plugin.runConcurrentThread:   Received StopThread
2018-06-10 17:35:57.533   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 17:35:57.759   DEBUG   Plugin.StartInfluxServer:   starting the InfluxDB Server using command: /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/influxdb/influxd run -config /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/influxdb/influxdb.conf
2018-06-10 17:36:47.782   ERROR   Plugin.StartInfluxServer:   error starting the InfluxDB server... will attempt to resolve.
2018-06-10 17:36:47.783   DEBUG   Plugin.restartAll:   not currently connected to any InfluxDB, so will not start the Grafana Server
2018-06-10 17:36:47.783   DEBUG   Plugin.BuildConfigurationLists:   starting BuildConfigurationLists()
2018-06-10 17:36:49.549   DEBUG   Plugin.ValidateConfigLists:   running ValidateConfigLists()
2018-06-10 17:36:49.584   DEBUG   Plugin.ValidateConfigLists:   completed ValidateConfigLists()
2018-06-10 17:36:49.677   DEBUG   Plugin.BuildConfigurationLists:   completed BuildConfigurationLists
2018-06-10 17:36:49.677   DEBUG   Plugin.pruneFilterBlocksEventLog:   entering pruneFilterBlocksEventLog()
2018-06-10 17:36:49.677   DEBUG   Plugin.pruneFilterBlocksEventLog:   log prune error: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Grafana Home Dashboard.indigoPlugin/Contents/Server Plugin/filter.log'
2018-06-10 17:36:49.678   DEBUG   Plugin.pruneFilterBlocksEventLog:   completed pruneFilterBlocksEventLog()
2018-06-10 17:36:50.353   DEBUG   Plugin.runConcurrentThread:   fully initiatlized and ready.  starting concurrent tread...
2018-06-10 17:36:55.355   DEBUG   Plugin.checkServerStatus:   running checkServerStatus()
2018-06-10 17:36:55.355   DEBUG   Plugin.checkServerStatus:   completed checkServerStatus(), GrafanaServerStatus: stopped, InfluxServerStatus: stopped
2018-06-10 17:36:55.355   DEBUG   Plugin.runConcurrentThread:   detected that a influx server restart needs to occur...
2018-06-10 17:36:55.396   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 17:36:55.397   ERROR   Plugin.StartInfluxServer:   cannot seem to start InfluxDB, triggering a rebuilding (reset) of Influx config
2018-06-10 17:36:55.397   DEBUG   Plugin.connect:   running connect()
2018-06-10 17:36:55.406   DEBUG   Plugin.connect:      connection attempt 1: error while connecting to InfluxDB: HTTPConnectionPool(host='localhost', port=8086): Max retries exceeded with url: /query?q=CREATE+DATABASE+%22indigo%22&db=indigo (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x108fd97d0>: Failed to establish a new connection: [Errno 61] Connection refused',))
2018-06-10 17:36:55.406   ERROR   Plugin.connect:   error while connecting to InfluxDB, this can happen when the Indigo server is slow to start up.  Will continue to try silently in the background.
2018-06-10 17:36:55.407   DEBUG   Plugin.connect:   completed connect()
2018-06-10 17:37:00.407   DEBUG   Plugin.checkServerStatus:   running checkServerStatus()
2018-06-10 17:37:00.407   DEBUG   Plugin.checkServerStatus:   completed checkServerStatus(), GrafanaServerStatus: stopped, InfluxServerStatus: stopped
2018-06-10 17:37:00.407   DEBUG   Plugin.runConcurrentThread:   detected that a Influx reset needs to occur...
2018-06-10 17:37:00.449   DEBUG   Plugin.CreateInfluxConfig:   setting the InfluxDB data location to: /Users/Server/Documents/InfluxDB
2018-06-10 17:37:00.476   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [meta]
2018-06-10 17:37:00.476   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [data]
2018-06-10 17:37:00.476   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [coordinator]
2018-06-10 17:37:00.476   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [retention]
2018-06-10 17:37:00.476   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [shard-precreation]
2018-06-10 17:37:00.476   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-10 17:37:00.476   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-10 17:37:00.477   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-10 17:37:00.477   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to false
2018-06-10 17:37:00.477   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-10 17:37:00.477   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-10 17:37:00.477   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-10 17:37:00.477   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-10 17:37:00.477   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-10 17:37:00.477   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-10 17:37:00.477   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-10 17:37:00.478   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 17:37:00.478   DEBUG   Plugin.StartInfluxServer:   starting the InfluxDB Server using command: /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/influxdb/influxd run -config /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/influxdb/influxdb.conf
2018-06-10 17:37:50.494   ERROR   Plugin.StartInfluxServer:   error starting the InfluxDB server... will attempt to resolve.
2018-06-10 17:37:50.494   DEBUG   Plugin.DeleteInfluxAdmin:   droping database user: indigo
2018-06-10 17:37:50.494   DEBUG   Plugin.CreateInfluxAdmin:   creating database admin user: indigo
2018-06-10 17:37:50.494   DEBUG   Plugin.CreateInfluxConfig:   setting the InfluxDB data location to: /Users/Server/Documents/InfluxDB
2018-06-10 17:37:50.504   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [meta]
2018-06-10 17:37:50.505   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [data]
2018-06-10 17:37:50.505   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [coordinator]
2018-06-10 17:37:50.505   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [retention]
2018-06-10 17:37:50.505   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [shard-precreation]
2018-06-10 17:37:50.505   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-10 17:37:50.505   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-10 17:37:50.506   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-10 17:37:50.506   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to true
2018-06-10 17:37:50.506   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-10 17:37:50.506   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-10 17:37:50.506   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-10 17:37:50.507   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-10 17:37:50.507   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-10 17:37:50.507   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-10 17:37:50.507   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-10 17:37:50.507   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 17:37:50.507   ERROR   Plugin.StartInfluxServer:   failed to start the Influx server after a rebuild, please check your config and contact support on the Indigo forums
2018-06-10 17:37:50.508   DEBUG   Plugin.connect:   running connect()
2018-06-10 17:37:50.516   DEBUG   Plugin.connect:      connection attempt 2: error while connecting to InfluxDB: HTTPConnectionPool(host='localhost', port=8086): Max retries exceeded with url: /query?q=CREATE+DATABASE+%22indigo%22&db=indigo (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x108fc3b50>: Failed to establish a new connection: [Errno 61] Connection refused',))
2018-06-10 17:37:50.516   DEBUG   Plugin.connect:       triggering a InfluxDB restart since connections are failing
2018-06-10 17:37:50.516   DEBUG   Plugin.connect:   completed connect()
2018-06-10 17:37:55.516   DEBUG   Plugin.checkServerStatus:   running checkServerStatus()
2018-06-10 17:37:55.517   DEBUG   Plugin.checkServerStatus:   completed checkServerStatus(), GrafanaServerStatus: stopped, InfluxServerStatus: stopped
2018-06-10 17:37:55.517   DEBUG   Plugin.runConcurrentThread:   detected that a Influx reset needs to occur...
2018-06-10 17:37:55.558   DEBUG   Plugin.CreateInfluxConfig:   setting the InfluxDB data location to: /Users/Server/Documents/InfluxDB
2018-06-10 17:37:55.560   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [meta]
2018-06-10 17:37:55.560   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [data]
2018-06-10 17:37:55.560   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [coordinator]
2018-06-10 17:37:55.560   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [retention]
2018-06-10 17:37:55.560   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [shard-precreation]
2018-06-10 17:37:55.560   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-10 17:37:55.560   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-10 17:37:55.560   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-10 17:37:55.560   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to false
2018-06-10 17:37:55.561   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-10 17:37:55.561   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-10 17:37:55.561   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-10 17:37:55.561   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-10 17:37:55.561   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-10 17:37:55.561   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-10 17:37:55.561   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-10 17:37:55.561   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 17:37:55.562   DEBUG   Plugin.DeleteInfluxAdmin:   droping database user: indigo
2018-06-10 17:37:55.562   DEBUG   Plugin.CreateInfluxAdmin:   creating database admin user: indigo
2018-06-10 17:37:55.562   DEBUG   Plugin.CreateInfluxConfig:   setting the InfluxDB data location to: /Users/Server/Documents/InfluxDB
2018-06-10 17:37:55.563   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [meta]
2018-06-10 17:37:55.563   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [data]
2018-06-10 17:37:55.563   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [coordinator]
2018-06-10 17:37:55.563   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [retention]
2018-06-10 17:37:55.563   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [shard-precreation]
2018-06-10 17:37:55.563   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-10 17:37:55.563   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-10 17:37:55.564   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-10 17:37:55.564   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to true
2018-06-10 17:37:55.564   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-10 17:37:55.564   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-10 17:37:55.564   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-10 17:37:55.564   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-10 17:37:55.564   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-10 17:37:55.564   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-10 17:37:55.564   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-10 17:37:55.565   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 17:37:55.565   DEBUG   Plugin.connect:   running connect()
2018-06-10 17:37:55.575   DEBUG   Plugin.connect:      connection attempt 3: error while connecting to InfluxDB: HTTPConnectionPool(host='localhost', port=8086): Max retries exceeded with url: /query?q=CREATE+DATABASE+%22indigo%22&db=indigo (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x108fd9950>: Failed to establish a new connection: [Errno 61] Connection refused',))
2018-06-10 17:37:55.575   DEBUG   Plugin.connect:   completed connect()
2018-06-10 17:38:00.575   DEBUG   Plugin.checkServerStatus:   running checkServerStatus()
2018-06-10 17:38:00.576   DEBUG   Plugin.checkServerStatus:   completed checkServerStatus(), GrafanaServerStatus: stopped, InfluxServerStatus: stopped
2018-06-10 17:38:00.576   DEBUG   Plugin.runConcurrentThread:   detected that a Influx reset needs to occur...
2018-06-10 17:38:00.618   DEBUG   Plugin.CreateInfluxConfig:   setting the InfluxDB data location to: /Users/Server/Documents/InfluxDB
2018-06-10 17:38:00.628   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [meta]
2018-06-10 17:38:00.628   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [data]
2018-06-10 17:38:00.629   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [coordinator]
2018-06-10 17:38:00.629   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [retention]
2018-06-10 17:38:00.629   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [shard-precreation]
2018-06-10 17:38:00.629   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-10 17:38:00.629   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-10 17:38:00.630   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-10 17:38:00.630   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to false
2018-06-10 17:38:00.630   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-10 17:38:00.630   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-10 17:38:00.630   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-10 17:38:00.630   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-10 17:38:00.630   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-10 17:38:00.630   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-10 17:38:00.630   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-10 17:38:00.631   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 17:38:00.631   DEBUG   Plugin.DeleteInfluxAdmin:   droping database user: indigo
2018-06-10 17:38:00.631   DEBUG   Plugin.CreateInfluxAdmin:   creating database admin user: indigo
2018-06-10 17:38:00.631   DEBUG   Plugin.CreateInfluxConfig:   setting the InfluxDB data location to: /Users/Server/Documents/InfluxDB
2018-06-10 17:38:00.667   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [meta]
2018-06-10 17:38:00.667   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [data]
2018-06-10 17:38:00.667   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [coordinator]
2018-06-10 17:38:00.667   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [retention]
2018-06-10 17:38:00.667   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [shard-precreation]
2018-06-10 17:38:00.667   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-10 17:38:00.667   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-10 17:38:00.668   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-10 17:38:00.668   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to true
2018-06-10 17:38:00.668   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-10 17:38:00.668   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-10 17:38:00.668   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-10 17:38:00.668   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-10 17:38:00.668   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-10 17:38:00.668   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-10 17:38:00.668   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-10 17:38:00.710   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 17:38:00.710   DEBUG   Plugin.connect:   running connect()
2018-06-10 17:38:00.719   DEBUG   Plugin.connect:      connection attempt 4: error while connecting to InfluxDB: HTTPConnectionPool(host='localhost', port=8086): Max retries exceeded with url: /query?q=CREATE+DATABASE+%22indigo%22&db=indigo (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x108fc3c50>: Failed to establish a new connection: [Errno 61] Connection refused',))
2018-06-10 17:38:00.719   DEBUG   Plugin.connect:   completed connect()
2018-06-10 17:38:05.724   DEBUG   Plugin.checkServerStatus:   running checkServerStatus()
2018-06-10 17:38:05.724   DEBUG   Plugin.checkServerStatus:   completed checkServerStatus(), GrafanaServerStatus: stopped, InfluxServerStatus: stopped
2018-06-10 17:38:05.724   DEBUG   Plugin.runConcurrentThread:   detected that a Influx reset needs to occur...
2018-06-10 17:38:05.767   DEBUG   Plugin.CreateInfluxConfig:   setting the InfluxDB data location to: /Users/Server/Documents/InfluxDB
2018-06-10 17:38:05.769   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [meta]
2018-06-10 17:38:05.769   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [data]
2018-06-10 17:38:05.769   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [coordinator]
2018-06-10 17:38:05.769   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [retention]
2018-06-10 17:38:05.769   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [shard-precreation]
2018-06-10 17:38:05.769   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-10 17:38:05.769   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-10 17:38:05.769   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-10 17:38:05.769   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to false
2018-06-10 17:38:05.770   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-10 17:38:05.770   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-10 17:38:05.770   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-10 17:38:05.770   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-10 17:38:05.770   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-10 17:38:05.770   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-10 17:38:05.770   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-10 17:38:05.770   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 17:38:05.771   DEBUG   Plugin.DeleteInfluxAdmin:   droping database user: indigo
2018-06-10 17:38:05.771   DEBUG   Plugin.CreateInfluxAdmin:   creating database admin user: indigo
2018-06-10 17:38:05.771   DEBUG   Plugin.CreateInfluxConfig:   setting the InfluxDB data location to: /Users/Server/Documents/InfluxDB
2018-06-10 17:38:05.772   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [meta]
2018-06-10 17:38:05.772   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [data]
2018-06-10 17:38:05.772   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [coordinator]
2018-06-10 17:38:05.772   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [retention]
2018-06-10 17:38:05.772   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [shard-precreation]
2018-06-10 17:38:05.772   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-10 17:38:05.772   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-10 17:38:05.772   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-10 17:38:05.772   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to true
2018-06-10 17:38:05.772   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-10 17:38:05.772   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-10 17:38:05.773   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-10 17:38:05.773   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-10 17:38:05.773   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-10 17:38:05.773   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-10 17:38:05.773   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-10 17:38:05.773   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-10 17:38:05.773   DEBUG   Plugin.connect:   running connect()
2018-06-10 17:38:05.783   DEBUG   Plugin.connect:      connection attempt 5: error while connecting to InfluxDB: HTTPConnectionPool(host='localhost', port=8086): Max retries exceeded with url: /query?q=CREATE+DATABASE+%22indigo%22&db=indigo (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x108fd9990>: Failed to establish a new connection: [Errno 61] Connection refused',))
2018-06-10 17:38:05.783   DEBUG   Plugin.connect:   completed connect()
2018-06-10 17:38:06.196   DEBUG   Plugin.runConcurrentThread:   Received StopThread
Håvard
Sun Jun 10, 2018 12:00 pm
vtmikel offline
What version of the plugin were you coming from? It shouldn't matter, but I'm curious. It was working in the past but not after the upgrade? Were any changes to the config made?
I see your data location for Influx is: /Users/Server/Documents/InfluxDB
I assume that this directory exists and you have files from your previous use of the plugin in it? I check for the existence of the directory in the plugin, but want to double check.
There's very little that would cause Influx to not start. After reviewing this, the plugin looks to be working as expected in the way that it is attempting to start Influx and test the connection to it. The tests are failing, so Influx is not starting correctly. This part of the plugin has not changed in a very long time.
When the plugin attempts to start Influx, it is blind as to what happens after that. Unfortunaetly, I'll need you to manually start Influx using the terminal, so that you can view the output and see what Influx is reporting back. Here is the command to start influx manually:
Please give it a try and show me the output of Influx starting up.
Mon Jun 11, 2018 12:19 am
haavarda offline
First, thanks for your support. I find this plugin very useful, and makes my setup much better.
I came from the previous version. And had it running smooth. And as I mentioned I had the same issues some time ago when I upgraded then.
I have checked in my documents/ ifluxdb folder, and there is 3 folders there. data,meta and wal.
I pasted your command in the terminal and got the response below:
Server$ /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/influxdb/influxd run -config /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/influxdb/influxdb.conf
-bash: /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Grafana Home Dashboard.indigoPlugin/Contents/Server Plugin/servers/influxdb/influxd: No such file or directory
unifi:~ Server$
Håvard
Mon Jun 11, 2018 2:51 pm
vtmikel offline
Re: Error after upgrade
I verified that the command I gave you works on my machine. That message would indicate that the Influx binary is not in the plugin bundle. But, I can confirm that it's part of the zip for the latest release:
https://github.com/mlamoure/indigo-graf ... s/influxdb
Can you browse to look in the plugin bundle and confirm the files match the link above?
Macs have a bunch of spaces in the folder structure, but I believe I've properly accounted for the way that the directories should be listed to run the Influx server and reference the config. That command is copied and pasted from my plugin code, so you get a "No such file or directory" says volumes -- if you cannot run Influx manually from the command prompt using that command, then the plugin also will have the same result.
Is your Indigo installed to the typical location?
Just to let you know the effort I put into this - I restored an old config I had of the Grafana plugin back from v1.0.1, and upgraded it straight from github. Mine upgraded perfectly without a problem.
v1.0.1 -> v1.0.2 did upgrade the InfluxDB server, but it's a minor upgrade. It also upgraded the Grafana server. I made no changes to the config dialog or the way that the plugin starts the servers themselves. This has been happening the same way since much before the 1.0.0 release.
I'm at a bit of a loss, this is becoming hard for me to debug.
A few options I can suggest:
1. try the "rebuild and restart the InfluxDB server". I expect you will have the same result, but check just to be sure.
2. Do the following:
Disable the plugin from the Plugins menu
Stop your Indigo server.
Go to your Disabled Plugins folder: /Library/Application Support/Perceptive Automation/Indigo 7/Plugins (Disabled)/
Delete the Grafana plugin.
Start your Indigo server
Re-download the plugin:
Install the plugin.
Be patient and let the plugin do it's thing. Send me the plugin.log again.
Both of these options will keep your plugin config, Influx data, and grafana dashboards
If this doesn't work, I need to see more output from the InfluxDB startup in order to figure out what's going on. I've had it on my list to make it so that the plugin can review this output. Either wait until I implement that, or contact me via PM and we can talk about other support options.
Mike
Tue Jun 12, 2018 12:22 am
haavarda offline
Good news :) .
The plugin is up and running again. When I deleted and re-installed the plugin as you described it started up just fine. As far as I could see the files you asked for was in the right directory. See image below (image is taken when the plugin was disabled). And my server is in the default location. So I have no idea why this was happening. I use High Sierra, could there be something there?
Thanks again for your support.
2018-06-12 08:05:29.243   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-12 08:05:29.303   DEBUG   Plugin.CreateInfluxConfig:   setting the InfluxDB data location to: /Users/Server/Documents/InfluxDB
2018-06-12 08:05:29.305   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [meta]
2018-06-12 08:05:29.305   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [data]
2018-06-12 08:05:29.306   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [coordinator]
2018-06-12 08:05:29.306   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [retention]
2018-06-12 08:05:29.306   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [shard-precreation]
2018-06-12 08:05:29.306   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-12 08:05:29.306   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-12 08:05:29.306   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-12 08:05:29.306   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to false
2018-06-12 08:05:29.306   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-12 08:05:29.306   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-12 08:05:29.307   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-12 08:05:29.307   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-12 08:05:29.307   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-12 08:05:29.307   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-12 08:05:29.307   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-12 08:05:29.308   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-12 08:05:29.308   DEBUG   Plugin.StartInfluxServer:   starting the InfluxDB Server using command: /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/influxdb/influxd run -config /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/influxdb/influxdb.conf
2018-06-12 08:05:44.319   DEBUG   Plugin.connect:   running connect()
2018-06-12 08:05:44.332   DEBUG   Plugin.connect:       setting Influx retention policy of: 720d
2018-06-12 08:05:44.335   DEBUG   Plugin.connect:       error while setting the retention policy: retention policy already exists
2018-06-12 08:05:44.335   DEBUG   Plugin.connect:   completed connect()
2018-06-12 08:05:44.335   DEBUG   Plugin.StartInfluxServer:   completed StartInfluxServer()
2018-06-12 08:05:44.336   DEBUG   Plugin.DeleteInfluxAdmin:   droping database user: indigo
2018-06-12 08:05:44.339   DEBUG   Plugin.CreateInfluxAdmin:   creating database admin user: indigo
2018-06-12 08:05:44.428   DEBUG   Plugin.CreateInfluxConfig:   setting the InfluxDB data location to: /Users/Server/Documents/InfluxDB
2018-06-12 08:05:44.481   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [meta]
2018-06-12 08:05:44.482   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [data]
2018-06-12 08:05:44.482   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [coordinator]
2018-06-12 08:05:44.482   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [retention]
2018-06-12 08:05:44.482   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [shard-precreation]
2018-06-12 08:05:44.482   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [monitor]
2018-06-12 08:05:44.482   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [subscriber]
2018-06-12 08:05:44.483   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [http]
2018-06-12 08:05:44.483   DEBUG   Plugin.CreateInfluxConfig:   influxDB auth-enabled set to true
2018-06-12 08:05:44.483   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [logging]
2018-06-12 08:05:44.483   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [ifql]
2018-06-12 08:05:44.483   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[graphite]]
2018-06-12 08:05:44.483   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[collectd]]
2018-06-12 08:05:44.483   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[opentsdb]]
2018-06-12 08:05:44.483   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [[udp]]
2018-06-12 08:05:44.484   DEBUG   Plugin.CreateInfluxConfig:   now editing Influx config section: [continuous_queries]
2018-06-12 08:05:44.484   DEBUG   Plugin.StartInfluxServer:   running StartInfluxServer()
2018-06-12 08:05:44.484   DEBUG   Plugin.StartInfluxServer:   starting the InfluxDB Server using command: /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/influxdb/influxd run -config /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/influxdb/influxdb.conf
2018-06-12 08:05:59.495   DEBUG   Plugin.connect:   running connect()
2018-06-12 08:05:59.583   DEBUG   Plugin.connect:       setting Influx retention policy of: 720d
2018-06-12 08:05:59.586   DEBUG   Plugin.connect:       error while setting the retention policy: retention policy already exists
2018-06-12 08:05:59.586   DEBUG   Plugin.connect:   completed connect()
2018-06-12 08:05:59.587   DEBUG   Plugin.StartInfluxServer:   completed StartInfluxServer()
2018-06-12 08:05:59.587   DEBUG   Plugin.StartGrafanaServer:   running StartGrafanaServer()
2018-06-12 08:05:59.587   DEBUG   Plugin.CreateGrafanaConfig:   running CreateGrafanaConfig()
2018-06-12 08:05:59.588   DEBUG   Plugin.CreateGrafanaConfig:        setting Grafana data directory to: /Users/Server/Documents/Grafana
2018-06-12 08:05:59.588   DEBUG   Plugin.CreateGrafanaConfig:        setting Grafana log directory to: /Users/Server/Documents/Grafana/log
2018-06-12 08:05:59.588   DEBUG   Plugin.CreateGrafanaConfig:        setting Grafana port to: 3006
2018-06-12 08:05:59.590   DEBUG   Plugin.CreateGrafanaConfig:        setting Grafana anonymous to: false
2018-06-12 08:05:59.593   DEBUG   Plugin.CreateGrafanaConfig:   completed CreateGrafanaConfig()
2018-06-12 08:05:59.593   DEBUG   Plugin.BuildConfigurationLists:   starting BuildConfigurationLists()
2018-06-12 08:06:01.466   DEBUG   Plugin.ValidateConfigLists:   running ValidateConfigLists()
2018-06-12 08:06:01.500   DEBUG   Plugin.ValidateConfigLists:   completed ValidateConfigLists()
2018-06-12 08:06:01.599   DEBUG   Plugin.BuildConfigurationLists:   completed BuildConfigurationLists
2018-06-12 08:06:01.599   DEBUG   Plugin.UpdateAll:   running UpdateAll()
2018-06-12 08:06:02.362   DEBUG   Plugin.UpdateAll:   completed UpdateAll()
2018-06-12 08:06:02.362   DEBUG   Plugin.pruneFilterBlocksEventLog:   entering pruneFilterBlocksEventLog()
2018-06-12 08:06:02.362   DEBUG   Plugin.pruneFilterBlocksEventLog:   log prune error: [Errno 2] No such file or directory: '/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Grafana Home Dashboard.indigoPlugin/Contents/Server Plugin/filter.log'
2018-06-12 08:06:02.362   DEBUG   Plugin.pruneFilterBlocksEventLog:   completed pruneFilterBlocksEventLog()
2018-06-12 08:06:03.081   DEBUG   Plugin.runConcurrentThread:   fully initiatlized and ready.  starting concurrent tread...
2018-06-12 08:06:54.907   DEBUG   Plugin.DeviceToInflux:   sending entire device to diff_to_json: CS - OS Sensor - Outside
2018-06-12 08:06:54.919   DEBUG   Plugin.DeviceToInflux:   sending entire device to diff_to_json: CS - OS Sensor - Outside
2018-06-12 08:07:03.086   DEBUG   Plugin.checkServerStatus:   running checkServerStatus()
2018-06-12 08:07:03.087   DEBUG   Plugin.checkServerStatus:   completed checkServerStatus(), GrafanaServerStatus: stopped, InfluxServerStatus: started
2018-06-12 08:07:03.087   DEBUG   Plugin.runConcurrentThread:   detected that a grafana server restart needs to occur...
2018-06-12 08:07:03.141   DEBUG   Plugin.StartGrafanaServer:   running StartGrafanaServer()
2018-06-12 08:07:03.142   DEBUG   Plugin.StartGrafanaServer:   starting the Grafana server using command: /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/grafana/grafana-server -homepath /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/grafana/ -config /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/grafana/conf/indigo.ini
2018-06-12 08:07:13.151   DEBUG   Plugin.StartGrafanaServer:   completed StartGrafanaServer()
2018-06-12 08:07:13.151   DEBUG   Plugin.UpdateAll:   running UpdateAll()
2018-06-12 08:07:15.949   DEBUG   Plugin.UpdateAll:   completed UpdateAll()
2018-06-12 08:08:15.954   DEBUG   Plugin.checkServerStatus:   running checkServerStatus()
2018-06-12 08:08:15.955   DEBUG   Plugin.checkServerStatus:   completed checkServerStatus(), GrafanaServerStatus: started, InfluxServerStatus: started
2018-06-12 08:08:15.955   DEBUG   Plugin.UpdateAll:   running UpdateAll()
2018-06-12 08:08:16.019   DEBUG   Plugin.DeviceToInflux:   sending entire device to diff_to_json: CS - OS Sensor - Outside
2018-06-12 08:08:16.788   DEBUG   Plugin.UpdateAll:   completed UpdateAll()
2018-06-12 08:08:41.354   DEBUG   Plugin.DeviceToInflux:   sending entire device to diff_to_json: CS - OS Sensor - Outside
2018-06-12 08:08:41.364   DEBUG   Plugin.DeviceToInflux:   sending entire device to diff_to_json: CS - OS Sensor - Outside
2018-06-12 08:09:16.794   DEBUG   Plugin.checkServerStatus:   running checkServerStatus()
2018-06-12 08:09:16.795   DEBUG   Plugin.checkServerStatus:   completed checkServerStatus(), GrafanaServerStatus: started, InfluxServerStatus: started
2018-06-12 08:09:16.795   DEBUG   Plugin.UpdateAll:   running UpdateAll()
2018-06-12 08:09:17.960   DEBUG   Plugin.UpdateAll:   completed UpdateAll()
2018-06-12 08:10:17.961   DEBUG   Plugin.checkServerStatus:   running checkServerStatus()
2018-06-12 08:10:17.961   DEBUG   Plugin.checkServerStatus:   completed checkServerStatus(), GrafanaServerStatus: started, InfluxServerStatus: started
2018-06-12 08:10:17.961   DEBUG   Plugin.UpdateAll:   running UpdateAll()
2018-06-12 08:10:18.875   DEBUG   Plugin.UpdateAll:   completed UpdateAll()
2018-06-12 08:10:26.913   DEBUG   Plugin.DeviceToInflux:   sending entire device to diff_to_json: CS - OS Sensor - Outside
2018-06-12 08:10:26.924   DEBUG   Plugin.DeviceToInflux:   sending entire device to diff_to_json: CS - OS Sensor - Outside
Håvard
Tue Jun 12, 2018 1:39 pm
vtmikel offline
I'm glad you got it working. My primary Indigo server is also on High Sierra.
My gut is that you uncovered a bug, but we had to take the nuclear option to resolve it, so I don't know how to fix the underlying cause. Anyway, I'm glad you are up and running.
