Share your Grafana Dashboard!
Mon Apr 02, 2018 3:37 pm
vtmikel offline
Please use this thread to share an image of your own Grafana dashboard, to show people what's possible.
Mine: https://www.dropbox.com/s/tui7c7pe5epf5cy/Dashboard%20Picture.png?dl=0
Tue Apr 03, 2018 3:09 pm
nathanw offline
Re: Share your Grafana Dashboard!
Haven't migrated to the new plugin yet, but here's what my dashboard looks like at the moment.
Everything but the electricity data is from Indigo/this plugin; the electricity data is from a Brultech GreenEye Monitor with the InfluxDB-enabled btmon.py
(I am seeing a few glitches in the temperature set point data, down to 0 and up to 127 occasionally, that don't obviously correspond to Indigo log events)
Fri Apr 06, 2018 6:35 am
I really like the way these dashboards cleanly present the data. Thanks for the continued work on the plugin, especially on reducing the dependencies required to get it up and running!
Mon Apr 16, 2018 4:47 pm
TwitchCaptain offline
I wrote most of these graphs with regex matches, and they're very generic. Quite willing to share the dashboard.
Here's the json that defines the dashboard:
  "__inputs": [
      "name": "DS_INDIGO",
      "label": "Indigo",
      "description": "",
      "type": "datasource",
      "pluginId": "influxdb",
      "pluginName": "InfluxDB"
  "__requires": [
      "type": "grafana",
      "id": "grafana",
      "name": "Grafana",
      "version": "5.0.4"
      "type": "panel",
      "id": "graph",
      "name": "Graph",
      "version": "5.0.0"
      "id": "influxdb",
      "name": "InfluxDB",
      "version": "5.0.0"
      "type": "panel",
      "id": "natel-discrete-panel",
      "name": "Discrete",
      "version": "0.0.7"
  "annotations": {
    "list": [
        "builtIn": 1,
        "datasource": "-- Grafana --",
        "enable": true,
        "hide": true,
        "iconColor": "rgba(0, 211, 255, 1)",
        "name": "Annotations & Alerts",
        "type": "dashboard"
  "editable": true,
  "gnetId": null,
  "graphTooltip": 1,
  "id": null,
  "links": [],
  "panels": [
      "backgroundColor": "rgba(128,128,128,0.1)",
      "colorMaps": [
          "color": "#7EB26D",
          "text": "Locked"
          "color": "#890f02",
          "text": "Unlocked"
      "crosshairColor": "#8F070C",
      "datasource": "${DS_INDIGO}",
      "display": "timeline",
      "expandFromQueryS": 1440,
      "extendLastValue": true,
      "gridPos": {
        "h": 8,
        "w": 12,
        "x": 0,
        "y": 0
      "highlightOnMouseover": true,
      "id": 10,
      "legendSortBy": "-ms",
      "lineColor": "#cffaff",
      "links": [],
      "metricNameColor": "#badff4",
      "rangeMaps": [
          "from": "null",
          "text": "N/A",
          "to": "null"
      "rowHeight": 25,
      "showLegend": true,
      "showLegendCounts": false,
      "showLegendNames": true,
      "showLegendPercent": true,
      "showLegendTime": true,
      "showLegendValues": true,
      "showTimeAxis": true,
      "showTransitionCount": true,
      "targets": [
          "alias": "$tag_name",
          "groupBy": [
              "params": [
                "name"
              "type": "tag"
          "measurement": "device_changes",
          "orderByTime": "ASC",
          "policy": "default",
          "refId": "A",
          "resultFormat": "time_series",
          "select": [
                "params": [
                  "onState"
                "type": "field"
          "tags": [
              "key": "name",
              "operator": "=",
              "value": "Big Garage Door"
          "alias": "Gate",
          "groupBy": [
              "params": [
                "varname"
              "type": "tag"
          "measurement": "variable_changes",
          "refId": "B",
          "select": [
                "params": [
                  "value"
                "type": "field"
          "tags": [
              "key": "varname",
              "operator": "=",
              "value": "GateStatus"
          "groupBy": [
              "params": [
                "name"
              "type": "tag"
          "refId": "C",
          "select": [
                "params": [
                  "onState"
                "type": "field"
          "tags": [
              "key": "name",
              "operator": "=~",
              "value": "/Lock$/"
      "textSize": 12,
      "textSizeTime": 9,
      "timeTextColor": "#d8d9da",
      "title": "Entry Locks",
      "type": "natel-discrete-panel",
      "units": "short",
      "valueMaps": [
          "op": "=",
          "text": "Locked",
          "value": "true"
          "op": "=",
          "text": "Unlocked",
          "value": "false"
      "valueTextColor": "#0a50a1",
      "writeAllValues": false,
      "writeLastValue": true,
      "writeMetricNames": true
      "colorMaps": [
          "color": "#f2c96d",
          "text": "Off"
          "color": "#7eb26d",
          "text": "On"
      "gridPos": {
        "h": 5,
        "w": 12,
        "x": 12,
        "y": 0
      "id": 4,
      "lineColor": "rgba(0,0,0,0.1)",
      "links": [],
      "metricNameColor": "#2f575e",
      "rangeMaps": [
          "from": "0",
          "text": "Off",
          "to": "0"
          "from": "1",
          "text": "On",
          "to": "1"
      "rowHeight": 20,
      "showLegend": true,
      "targets": [
          "groupBy": [
              "params": [
                "name"
              "type": "tag"
          "refId": "A",
          "select": [
                "params": [
                  "onState.num"
                "type": "field"
          "tags": [
              "key": "name",
              "operator": "=~",
              "value": "/Motion$/"
      "textSize": 12,
      "textSizeTime": 9,
      "title": "Motion Sensors",
      "units": "short",
      "valueMaps": [],
      "valueTextColor": "#badff4",
      "writeLastValue": false,
      "colorMaps": [
          "color": "#6d1f62",
          "text": "On"
          "color": "#052b51",
          "text": "Off"
      "expandFromQueryS": 0,
      "gridPos": {
        "h": 13,
        "w": 12,
        "x": 12,
        "y": 5
      "id": 6,
      "lineColor": "#9ac48a",
      "links": [],
      "metricNameColor": "#82b5d8",
      "rangeMaps": [
          "from": "0",
          "text": "Off",
          "to": "0"
          "from": "1",
          "text": "On",
          "to": "1"
          "from": "null",
          "text": "Off",
          "to": "null"
          "from": "-1",
          "text": "Off",
          "to": "-1"
      "rowHeight": 24,
      "showDistinctCount": false,
      "showLegend": false,
      "showLegendCounts": true,
      "showLegendValues": false,
      "targets": [
          "groupBy": [
              "params": [
                "name"
              "type": "tag"
          "refId": "A",
          "select": [
                "params": [
                  "onState.num"
                "type": "field"
          "tags": [
              "key": "name",
              "operator": "=~",
              "value": "/(Light|Lamp)( Plug)?$/"
      "textSize": 12,
      "textSizeTime": 9,
      "title": "Lights",
      "units": "short",
      "valueMaps": [
          "op": "=",
          "text": "Off",
          "value": "null"
      "valueTextColor": "#000000",
      "colorMaps": [
          "color": "#7EB26D",
          "text": "Closed"
          "color": "#890f02",
          "text": "Open"
      "gridPos": {
        "h": 6,
        "w": 12,
        "x": 0,
        "y": 8
      "id": 12,
      "legendMaxValues": 2,
      "links": [],
      "metricNameColor": "#584477",
      "rangeMaps": [
          "from": "1",
          "text": "Open",
          "to": "1"
          "from": "0",
          "text": "Closed",
          "to": "0"
      "rowHeight": 24,
      "showLegend": true,
      "targets": [
          "groupBy": [
              "params": [
                "name"
              "type": "tag"
          "refId": "A",
          "select": [
                "params": [
                  "onState.num"
                "type": "field"
          "tags": [
              "key": "name",
              "operator": "=~",
              "value": "/Window$/"
              "condition": "OR",
              "key": "name",
              "operator": "=",
              "value": "Garage Man Door"
              "condition": "OR",
              "key": "name",
              "operator": "=",
              "value": "Security Box Door"
      "textSize": 12,
      "textSizeTime": 9,
      "title": "Doors & Windows",
      "units": "short",
      "valueMaps": [
          "op": "=",
          "text": "N/A",
          "value": "null"
      "valueTextColor": "#3f6833",
      "aliasColors": {},
      "bars": false,
      "dashLength": 10,
      "dashes": false,
      "fill": 1,
      "gridPos": {
        "h": 9,
        "w": 12,
        "x": 0,
        "y": 14
      "id": 18,
      "legend": {
        "alignAsTable": true,
        "avg": true,
        "current": true,
        "max": true,
        "min": true,
        "rightSide": false,
        "show": true,
        "total": false,
        "values": true
      "lines": true,
      "linewidth": 1,
      "links": [],
      "nullPointMode": "null",
      "percentage": false,
      "pointradius": 5,
      "points": false,
      "renderer": "flot",
      "seriesOverrides": [
          "alias": "/Visibility$/",
          "yaxis": 2
      "spaceLength": 10,
      "stack": false,
      "steppedLine": false,
      "targets": [
          "groupBy": [
              "params": [
                "name"
              "type": "tag"
          "refId": "A",
          "select": [
                "params": [
                  "sensorValue"
                "type": "field"
          "tags": [
              "key": "name",
              "operator": "=~",
              "value": "/Luminance/"
          "alias": "$tag_name Visibility",
          "groupBy": [
              "params": [
                "name"
              "type": "tag"
          "measurement": "weather_changes",
          "refId": "B",
          "select": [
                "params": [
                  "state.visibility.num"
                "type": "field"
          "tags": []
      "thresholds": [],
      "timeFrom": null,
      "timeShift": null,
      "title": "Visibility",
      "tooltip": {
        "shared": true,
        "sort": 0,
        "value_type": "individual"
      "type": "graph",
      "xaxis": {
        "buckets": null,
        "mode": "time",
        "name": null,
        "show": true,
        "values": []
      "yaxes": [
          "format": "percent",
          "label": "Luminance %",
          "logBase": 1,
          "max": null,
          "min": null,
          "show": true
          "format": "lengthmi",
          "label": "Visibility (Miles)",
          "logBase": 1,
          "max": null,
          "min": null,
          "show": true
      "colorMaps": [
          "color": "#CCC",
          "text": "N/A"
      "gridPos": {
        "h": 5,
        "w": 12,
        "x": 12,
        "y": 18
      "id": 16,
      "links": [],
      "metricNameColor": "#000000",
      "rangeMaps": [
          "from": "null",
          "text": "N/A",
          "to": "null"
          "from": "0",
          "text": "Off",
          "to": "0"
          "from": "1",
          "text": "On",
          "to": "1"
      "rowHeight": 25,
      "showLegend": true,
      "targets": [
          "groupBy": [
              "params": [
                "name"
              "type": "tag"
          "refId": "A",
          "select": [
                "params": [
                  "onState.num"
                "type": "field"
          "tags": [
              "key": "name",
              "operator": "=~",
              "value": "/Fan$/"
              "condition": "OR",
              "key": "name",
              "operator": "=~",
              "value": "/Dehumidifer/"
      "textSize": 12,
      "textSizeTime": 9,
      "title": "Fans & Devices",
      "units": "short",
      "valueMaps": [
          "op": "=",
          "text": "N/A",
          "value": "null"
      "writeMetricNames": false
      "aliasColors": {},
      "bars": false,
      "dashLength": 10,
      "dashes": false,
      "description": "Office Temperature reports in C, so it gets its own data source with math to convert to F.",
      "fill": 1,
      "gridPos": {
        "h": 7,
        "w": 24,
        "x": 0,
        "y": 23
      "id": 8,
      "legend": {
        "avg": true,
        "current": true,
        "hideEmpty": false,
        "hideZero": false,
        "max": true,
        "min": true,
        "rightSide": true,
        "show": true,
        "total": false,
        "values": true
      "lines": true,
      "linewidth": 1,
      "links": [],
      "pointradius": 5,
      "points": false,
      "renderer": "flot",
          "alias": "/Humidity$/",
          "yaxis": 2
      "spaceLength": 10,
      "stack": false,
      "targets": [
          "alias": "$tag_name Temperature",
          "groupBy": [
              "params": [
                "name"
              "type": "tag"
          "refId": "A",
          "select": [
                "params": [
                  "state.temperatureF.num"
                "type": "field"
          "tags": []
          "groupBy": [
              "params": [
                "name"
              "type": "tag"
          "measurement": "thermostat_changes",
          "refId": "B",
          "select": [
                "params": [
                  "state.temperatureInput1"
                "type": "field"
          "tags": []
          "groupBy": [
              "params": [
                "name"
              "type": "tag"
          "refId": "C",
          "select": [
                "params": [
                  "state.sensorValue"
                "type": "field"
          "tags": [
              "key": "name",
              "operator": "=~",
              "value": "/Temperature$/"
              "condition": "AND",
              "key": "name",
              "operator": "!=",
              "value": "Office Temperature"
          "groupBy": [
              "params": [
                "name"
              "type": "tag"
          "hide": false,
          "refId": "D",
          "select": [
                "params": [
                "type": "field"
          "tags": []
          "groupBy": [
              "params": [
                "name"
              "type": "tag"
          "refId": "E",
          "select": [
                "params": [
                  "state.sensorValue"
                "type": "field"
                "params": [
                  "*1.8+32"
                "type": "math"
          "tags": [
              "key": "name",
              "operator": "=",
          "alias": "$tag_name Humidity",
          "groupBy": [
              "params": [
                "name"
              "type": "tag"
          "refId": "G",
          "select": [
                "params": [
                  "state.humidity.num"
                "type": "field"
          "tags": []
          "groupBy": [
              "params": [
                "name"
              "type": "tag"
          "hide": false,
          "query": "SELECT \"sensorValue\" FROM \"device_changes\" WHERE (\"name\" =~ /Humi?dity$/) AND $timeFilter GROUP BY \"name\"",
          "rawQuery": false,
          "refId": "F",
          "select": [
                "params": [
                  "sensorValue"
                "type": "field"
          "tags": [
              "key": "name",
              "operator": "=~",
              "value": "/Humidity$/"
          "groupBy": [
              "params": [
                "name"
              "type": "tag"
          "hide": false,
          "refId": "H",
          "select": [
                "params": [
                  "state.humidityInput1"
                "type": "field"
          "tags": []
      "thresholds": [],
      "timeFrom": null,
      "timeShift": null,
      "title": "Temperature & Relative Humidity",
      "tooltip": {
        "shared": true,
        "sort": 1,
      "type": "graph",
      "xaxis": {
        "buckets": null,
        "mode": "time",
        "name": null,
        "show": true,
        "values": []
      "yaxes": [
          "format": "farenheit",
          "label": "°  Fahrenheit",
          "logBase": 1,
          "max": null,
          "min": null,
          "show": true
          "format": "humidity",
          "label": "% Relative Humidity",
          "logBase": 1,
          "max": null,
          "min": null,
          "show": true
      "aliasColors": {},
      "bars": false,
      "dashLength": 10,
      "dashes": false,
      "fill": 3,
      "gridPos": {
        "h": 9,
        "w": 24,
        "x": 0,
        "y": 30
      "id": 14,
      "legend": {
        "avg": true,
        "current": true,
        "max": true,
        "min": false,
        "rightSide": true,
        "show": true,
        "total": false,
        "values": true
      "lines": true,
      "linewidth": 3,
      "links": [],
      "pointradius": 5,
      "points": false,
      "renderer": "flot",
      "seriesOverrides": [],
      "spaceLength": 10,
      "stack": false,
      "targets": [
          "groupBy": [
              "params": [
                "name"
              "type": "tag"
          "refId": "C",
          "select": [
                "params": [
                  "energyCurLevel"
                "type": "field"
          "tags": [
              "key": "name",
              "operator": "!=",
              "value": "Front Porch Light"
      "thresholds": [],
      "timeFrom": null,
      "timeShift": null,
      "title": "Power",
      "tooltip": {
        "shared": true,
        "sort": 0,
      "type": "graph",
      "xaxis": {
        "buckets": null,
        "mode": "time",
        "name": null,
        "show": true,
        "values": []
      "yaxes": [
          "format": "short",
          "label": "Wh",
          "logBase": 1,
          "max": null,
          "min": null,
          "show": true
          "format": "short",
          "label": null,
          "logBase": 1,
          "max": null,
          "min": null,
          "show": false
  "refresh": "30s",
  "schemaVersion": 16,
  "style": "dark",
  "tags": [],
  "templating": {
    "list": []
  "time": {
    "from": "now-24h",
    "to": "now-10s"
  "timepicker": {
    "nowDelay": "10s",
    "refresh_intervals": [
      "10s",
      "30s",
      "1m",
      "5m"
    "time_options": [
      "5m",
      "15m",
      "1h",
      "6h",
      "12h",
      "24h",
      "2d",
      "7d",
      "30d"
  "timezone": "browser",
  "title": "Home",
  "uid": "xF85NDZiz",
  "version": 52
Screen Shot 2018-04-16 at 3.44.24 PM-min.png (190.25 KiB) Viewed 6999 times
Mon Apr 16, 2018 5:01 pm
frankyhall wrote:
I wrote most of these graphs with regex matches, and they're very generic. Quite willing to share the dashboard. I tried to attach it, but zip and json files are not permitted as attachments.
You can post ZIP files in the Contribution Library. Or, if the json isn't too long, post it inside code tags in a post.
Fri Apr 20, 2018 12:46 pm
vtmikel offline
@frankyhall - Thanks for your dashboard example. It is much more generic than mine, so I'm going to make use of it. I've also found that it's easier to give a few instructions on how to import a dashboard than try to provision it automatically, so I'm updating the Wiki to reflect that.
Fri Apr 20, 2018 2:10 pm
outsidenwnc offline
Nothing spectacular from a graphics design perspective however the neat thing is the one graph has two different data sources - Indigo and (some other home automation software).
Wed Apr 25, 2018 9:17 am
vtmikel offline
Nice dashboards, I've gotten some good ideas from them.
I've stitched together and updated the screenshot of my own dashboard: https://www.dropbox.com/s/tui7c7pe5epf5cy/Dashboard%20Picture.png?dl=0
It's very tall. You have to zoom in to actually see any of the panels. This is rendered on a desktop, but works fine on mobile. I like to keep my dashboard single column because it allows for easier ways to line up events across panels.
One thing I find incredibly valuable about seeing your home automation data in this way is to debug your indigo behaviors. Did my lights really turn off when I left the house? Why did a particular trigger of mine [not] execute? As your home automation setup gets more advanced, these things can become harder and harder to track down. I find the Grafana visualizations incredibly valuable for this.
