Grafana Home Dashboard Error error starting the InfluxDB server
Grafana Home Dashboard Debug not currently connected to any InfluxDB, so will not start the Grafana Server
Grafana Home Dashboard Debug starting BuildConfigurationLists()
Grafana Home Dashboard Debug running ValidateConfigLists()
Grafana Home Dashboard Debug validated included device: Sitting Room
Grafana Home Dashboard Debug validated included device: Living Room
Grafana Home Dashboard Debug validated included device: Dining Room
Grafana Home Dashboard Debug validated included device: Kitchen
Grafana Home Dashboard Debug validated included device: Guest Room
Grafana Home Dashboard Debug validated included device: Guest Ensuite
Grafana Home Dashboard Debug validated included device: Entrance
Grafana Home Dashboard Debug validated included device: Back Toilet
Grafana Home Dashboard Debug validated included device: Sitting Room - Motion Sensor
Grafana Home Dashboard Debug validated included state: state.onOffState
Grafana Home Dashboard Debug validated included state: onState
Grafana Home Dashboard Debug validated included state: energyCurLevel
Grafana Home Dashboard Debug validated included state: energyAccumTotal
Grafana Home Dashboard Debug validated included state: sensorValue
Grafana Home Dashboard Debug validated included state: heatSetpoint
Grafana Home Dashboard Debug validated included state: batteryLevel
Grafana Home Dashboard Debug validated included state: batteryLevel.num
Grafana Home Dashboard Debug completed ValidateConfigLists()
Grafana Home Dashboard Debug completed BuildConfigurationLists
Grafana Home Dashboard Debug starting concurrent tread...
Grafana Home Dashboard fully initialized and ready...
Grafana Home Dashboard Debug no valid InfluxDB server to connect to. InfluxServerStatus: stopped, ExternalDB: False
Grafana Home Dashboard Error no valid InfluxDB server to connect to; please check plugin config. Future errors are now silenced.
Grafana Home Dashboard Debug completed processing closedPrefsConfigUi
Grafana Home Dashboard Debug detected that a influx server restart needs to occur...
Grafana Home Dashboard ######## About to (re) start InfluxDB. Please be patient while this happens. ########
Grafana Home Dashboard shutting down the InfluxDB Server...
Grafana Home Dashboard Error failed to start the Influx server more than once, will not attempt again, please check your config
Grafana Home Dashboard Debug the InfluxDB server not started. InfluxServerStatus: stopped, ExternalDB: False
Grafana Home Dashboard Debug too many attempts to restart the InfluxDB internal server. will not attempt again until user corrects the config.
Loading plugin "Grafana Home Dashboard 0.0.12"
Starting plugin "Grafana Home Dashboard 0.0.12" (pid 466)
Grafana Home Dashboard Error Error in plugin execution InitializeMain:
File "plugin.py", line 12, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Grafana Home Dashboard.indigoPlugin/Contents/Server Plugin/influxdb/__init__.py", line 9, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Grafana Home Dashboard.indigoPlugin/Contents/Server Plugin/influxdb/client.py", line 16, in <module>
ImportError: No module named six.moves
Stopping plugin "Grafana Home Dashboard 0.0.12" (pid 466)
Stopped plugin "Grafana Home Dashboard 0.0.12"
IndigoSam wrote:I'm getting a different error on start up:
- Code: Select all
It is Python 2.7.5. It is actually a clean and new install of Mavericks.
Have I missed something?
Sam.
IndigoSam wrote:'Otherwise I can upgrade to El Cap? I'm re-building things anyway. Unless of course you would like a tester for this, in which case I will await the next beta.
Sam.
Upgrading plugin Grafana Home Dashboard to newer version 0.0.13 (previous version moved to trash)
Loading plugin "Grafana Home Dashboard 0.0.13"
Starting plugin "Grafana Home Dashboard 0.0.13" (pid 691)
File "plugin.py", line 15, in <module>
File "./lib/influxdb/__init__.py", line 9, in <module>
File "./lib/influxdb/client.py", line 14, in <module>
File "./lib/requests/__init__.py", line 43, in <module>
ImportError: No module named urllib3
Stopping plugin "Grafana Home Dashboard 0.0.13" (pid 691)
Stopped plugin "Grafana Home Dashboard 0.0.13"
jens wrote:Get this message...
Grafana Home Dashboard Debug the Grafana data location does not exist, please check your configuration
//Jens
InfluxDB Data Location: /Users/<username>/Documents/InfluxDB
Grafana Dashboard Data Location: /Users/<username>/Documents/Grafana
