Rachio Gen 3
Fri Apr 16, 2021 12:31 pm
EagleDTW offline
Re: Rachio Gen 3
I just reduced polling interval from 3 to 6, should I do more and does that mean that it won't update effectively?
Fri Apr 16, 2021 12:34 pm
Re: Rachio Gen 3
As I said in the HTTPd-2 thread, when using webhooks you only need to poll for the weather and forecast data, if you use it. You don't poll for sprinkler zone status. In my install, I have the polling interval set to 120 (every 2 hours). And I could make it longer than that, since I don't actually use that data at all.
When you have webhooks enabled, the Rachio servers push zone changes to the plugin (via the HTTPd plugin).
Fri Apr 16, 2021 12:36 pm
EagleDTW offline
Re: Rachio Gen 3
Perfect will give it a go, thank you Joe!
Best, Daniel
