Nothing to do with the plugin, but given many users may also use the iOS app, and secure the connection using stunnel a recent iOs update broke the connection. Not entirely sure when this broke given limited time out of the home over lockdown but the default stunnel config used TLS1.1 which is no longer supported. It was tricky to track down as I had long forgotten the setup for stunnel on the PC, and the https connection worked fine in a browser (self signed cert warnings aside).
Fix is simple, in the stunnel.conf add the line
- Code: Select all
sslVersion = TLSv1.2
The con file is in the config folder in the stunnel programme files
Restart stunnel and you are good to go.
Some "alternate" fixes online insist you need to generate a new certificate but it is not the case.
Maybe will help someone avoid head scratching.
Neil
