BlueIris Indigo Plugin
Fri Feb 16, 2018 4:54 pm
GlennNZ offline
Re: BlueIris Indigo Plugin
Version 0.3.3
Adds Cam Configuration Action Groups (need BI admin access to run these)
Selectable for each Camera; Allows:
- Send Reset to Camera
- Enable/Disable Motion Detection
- Enable/Disable Camera
- Start PTZ Cycle/Stop PTZ Cycle
- Pause/Unpause
Obviously quite useful to be able to turn off/on from within Indigo!
Glenn
Fri Feb 16, 2018 5:05 pm
Seeker offline
thank you!
on 0.3.2, i see how the trigger interface is supposed to work (multi select camera to be included in trigger) but the trigger does not seem to be being picked up by indigo. it worked on 0.3.1.
Feb 16, 2018 at 4:55:45 PM
   BlueIris Plugin Debug           logLevel = 5
   BlueIris Plugin Debug           User prefs saved.
   BlueIris Plugin Debug           Debugging on (Level: 5)
   BlueIris Plugin Debug           Connection established to Blueiris Server:Alienware4491
   BlueIris Plugin Debug           --- validatePrefsConfigUi() method called.
   BlueIris Plugin Debug           closedPrefsConfigUi() method called.
   Trigger                         blue iris app home profile message
   BlueIris Plugin Debug           Removing Trigger blue iris motion light test  (423360035)
   BlueIris Plugin Debug           Adding Trigger blue iris motion light test  (423360035) - motionTrigger
i created a new trigger from scratch. i toggled the cams to trigger (last two lines). then i manually triggered the cams from the BI web interface. no acknowledgment from indigo, nor did the action light turn on that i setup in the trigger. this trigger function was working on the previous version.
any ideas? thanks.
Fri Feb 16, 2018 5:06 pm
GlennNZ offline
Seeker wrote:
thank you!
any ideas? thanks.
OK Can you turn all the debug checkboxes on and try again - post me the Debug log.
Did test pretty well at my end...
I'm not sure I follow the 'toggle cams to trigger'. Won't trigger if just starting up... next 10 seconds or so.
Most of your log is deleting/adding the trigger.
G
Fri Feb 16, 2018 5:24 pm
Seeker offline
thanks, i sent a pm with the log. screencaps of simple trigger added.
i'm right-clicking on the BI web UI (the UI3 beta version), trigger now. this method was working this morning when i was testing the previous version. a slight delay, but it worked and ran the indigo trigger before.
ind 3.png (120.94 KiB) Viewed 3296 times
ind 2.png (99.45 KiB) Viewed 3296 times
ind 1.png (82.59 KiB) Viewed 3296 times
Fri Feb 16, 2018 5:44 pm
GlennNZ offline
Thanks for the log, and the images. They all looks fine& correct --- triggering working well at my end ()
Suspect it is at BI end -
Is the alert still correct/there for this camera?
Is it within BI timeout for alerting ? (won’t resend within this time period)
Has the plugin Just started? (logs doesn’t show that message - but never know)
Glenn
Fri Feb 16, 2018 6:03 pm
Seeker offline
Thanks.
20 second alerts are recording via manual trigger. i'll keep playing around with this. I'm sure it's something on my end.
This is the single greatest plugin for indigo since the amazing Sonos plugin (and DSC plugin, Alexa, HomeBridge, Netatmo, messages, EPS Alarm Clock). :D
Fri Feb 16, 2018 6:48 pm
GlennNZ offline
Seeker wrote:
Thanks.
Welcome to pm or pastebin the full debug log - from event logs directory if still have issues
Also Double check camera device is enabled in Indigo - if it is not for any reason won’t trigger
Glenn
Fri Feb 16, 2018 9:00 pm
CliveS offline
When I downloaded v 0.3.0 I set the auto update to 2 hours and ticked the box but no updates since then, just a FYI.
Now off to delete the demo Blue Iris and install clean with my shiny new serial number, looking forward to removing the demo band across the screen!
CliveS
Fri Feb 16, 2018 9:14 pm
GlennNZ offline
Enjoy! Also enables Direct to Disk recording as well which is probably the most useful feature
The update config settings actually do nothing at the moment - technically only recent pluginstore 0.3.3 is release!
May update the code for this, but the pluginStore API has to be close ..... and that will change everything from update standpoint.
G
Fri Feb 16, 2018 10:31 pm
GlennNZ offline
Here you go then:
0.3.6
- Remove a few unneeded menu items
- Updating code now functioning. Waiting new StoreAPI
- Update Plugin menu items updated.
- New, updated Readme
Can add the camconfig status results to the Camera devices; this will enable us to show - Motion detection On/Off, PTZCycle On/Off, Camera Enabled/Disabled, Pause/Unpause
The issue is it requires a Admin BI login --- Thoughts?
G
Sat Feb 17, 2018 1:16 am
GlennNZ offline
Version 0.4.1
Pulling all possible information from BI Server now.....
Changes:
Cosmetic only fix for Wrong PluginName shown when checking Update
Add Additional Custom States to Server Device
- SystemName - Name of System
- Admin - Whether current user is admin or not
- Audio - Audio enabled
- Clips
- User - Reported Username from BI
- Latitude
- Longitude
- Version - BI Version Number
Add States to BI Camera Device
- Camera Motion Detector On/Off True/False
- Camera Paused -1,0 as per BI
- Camera PtzCycle active True/False
- Added checks for actions that require admin user; won’t run and will inform you of issue if try.
Some/Most of these states require the Indigo Plugin BI Username to have admin rights on the BI server. I have added quite a few checks to capture when they are not, even if changing back and forwards without restarting.
If you don't want to be a BI Admin user - thats fine - the these new states will remain blank.
If any CamConfig commands are run - will immediately update on Camera Device the new setting (Motion Detector off etc.)
Sat Feb 17, 2018 2:48 am
rhanson offline
GlennNZ - see PM
Sat Feb 17, 2018 4:55 am
GlennNZ offline
rhanson wrote:
GlennNZ - see PM
Thanks for the PM and the code.
Had started looking at imageio (have merged it into another branch). Seems to need PIL + others - and really unkeen on adding to much dependencies. Both for weight of code/potential issues but also to limit installs to Mac-indigo server. Personally prefer to keep ‘crap-free’.
The other issue I see is access to clips (not BI default) and also whether any alert images capture. (I turned off images just use videos). I haven’t been running my BI server login with such.
Was hoping was standalone app for Mac that could just package with plugin and externally call (ImageMagick can standalone compile- but haven’t tried to hard). Still hoping will find one can point to directory of recently captured images to make gif.
Will keep thinking! Thanks for the pointers.
Glenn
Sat Feb 17, 2018 5:47 pm
Seeker offline
i'm still having problems with indigo getting notification of a BI trigger. odd thing is it WILL work occasionally.
i just re-read your installation instructions. The part about the camera trigger setup with the 'request from a web service' option. I guess those instructions were added after the first version. I currently have my camera subnet isolated (cameras can not communicate TO the indigo subnet). so i guess i'll need to open this up.
Sat Feb 17, 2018 5:52 pm
GlennNZ offline
Hi
Pretty sure those instructions have been there from the beginning (!) but rest have been tidied up a bit.
If you Have Standard Indigo Digest Authenication: You'll need to follow those instructions. This involves running curl to pass the same call but with digest auth added (which BI doesn't support via its web calls)
If you have changed Indigo to Basic Authentication (like I have): You can do it all from within BI
G
Page 4 of 11 1, 2, 3, 4, 5, 6, 7 ... 11
