BlueIris in VM
Tue Jul 02, 2019 6:12 pm
chase offline
Re: BlueIris in VM
So I figured I'd try it out. Tried to install both Parallels and Fusion on my Mac Pro server that's currently running Security Spy. Can't do it.
Both VMs require kernel extensions, which require permission in System Preferences to install. But that button is blocked from working when using any kind of remote access. I tried both Screen Sharing and TeamViewer. Nothing.
So I'll need to pull the Mac Pro out of the server closet, hook up a monitor, keyboard, and mouse, and then I can install them. Not sure when I'll get around to doing that.
You actually only need a mouse... (you can use your OS X screen share and your laptop to view the screen). Or an apple scripted mouse click at the correct coordinates will also register a valid button click.
Tue Jul 02, 2019 6:28 pm
Re: BlueIris in VM
Ah. That I can do. Thanks!
