Multitool Plugin Updates
Thu Jan 25, 2018 7:01 am
The initial release of the Multitool Plugin contained a couple of older files due to a failed merge. Version 1.0.14 should correct that error and the plugin should now contain updated files.
Any users that downloaded the initial release should upgrade to this version.
Please let me know if you see anything that doesn't work as expected.
Reason: Revise title, make sticky.
Fri Mar 23, 2018 11:04 am
Re: Multitool Plugin - Updates
Multitool Plugin v1.0.16 is now available.
1.0.16
  • Adds Subscribe to Changes tool for devices and variables.
  • Improves code commenting and adds Sphinx compatibility to docstrings.
  • Code refinements.
1.0.15
  • Adds menu item to check for plugin updates.
You can download it here.
Instructions for using the plugin can be found at the Wiki.
Wed Jul 25, 2018 8:08 am
Re: Multitool Plugin Updates
Multitool Plugin v1.0.19 is now available.
1.0.19
  • Adds tool to list indigo.server methods.
1.0.18
  • Fixes bug in naming of PluginConfig.xml (which caused problems on systems set up as case sensitive.)
1.0.17
  • Increments API version requirement to API 2.0.
Sun Feb 24, 2019 9:10 pm
Multitool Plugin v1.0.23 is now available.
v1.0.23
  • Device Dependencies Tool - Added 'List Dependencies' button; the dialog no longer closes after dependencies are logged (allowing users to run multiple queries before closing the tool.)
  • Device Dependencies Tool - Changed button title from 'Execute' to 'Close'.
  • Device Ping Tool - Added 'Ping Device' button; the dialog no longer closes after ping is sent (allowing users to ping multiple devices before closing the tool.)
  • Device Ping Tool - Changed button title from 'Execute' to 'Close'.
  • Error Inventory Tool - renamed the output file and included facility to automatically name the output file so that prior output is not over-written.
  • Indigo Inventory Tool [NEW] - outputs a listing of all Indigo Actions, Control Pages, Devices, Schedules, Triggers and Variables (and their folder locations.)
  • Methods - Indigo Base Tool - renamed the tool and dramatically increased the scope of tool.
  • Object Dictionary Tool - Added 'Print Dict' button; the dialog no longer closes after the object dictionary is output to the log (allowing users to query multiple objects before closing the tool.)
  • Object Dictionary Tool - Changed button title from 'Execute' to 'Close'.
  • Plugin Inventory Tool - Prettier log output.
  • Serial Ports Tool - Prettier log output.
  • Serial Ports Tool - Added setting to ignore BlueTooth ports.
  • Speak String Tool - Added 'Speak String' button; the dialog no longer closes after string is spoken (allowing users to adjust and copy the string before closing the tool.)
  • Speak String Tool - Changed button title from 'Execute' to 'Close'
  • Substitution Generator Tool - Changed button title from 'Execute' to 'Close'.
v1.0.22
  • Synchronize self.pluginPrefs in closedPrefsConfigUi().
v1.0.21
  • Removes plugin update checker.
v1.0.20
  • Changes Python lists to tuples where possible to increase performance.
Wed Nov 20, 2019 1:54 pm
I have added a pre-release of the Multitool Plugin which now includes Modify Numeric Variable and Modify Time Variable Action items. I have also updated the plugin documentation with descriptions of how to use the tools. I'm tossing this out as a pre-release in case I've missed the mark.
1.0.26
  • Adds the Modify Numeric Variable and Modify Time Variable Action items.
1.0.25
  • Removes all references to legacy version checking.
1.0.24
  • Ensures plugin is compatible with the Indigo server version.
  • Standardizes SupportURL behavior across all functions.
You can download the pre-release here.
You can see the documentation here. (The new stuff is on the Actions page.)
Fri Jan 31, 2020 6:39 am
Multitool Plugin v1.0.28 is now available.
This release finalizes the last pre-release and provides a few other refinements and bug fixes. This release is recommended for all users.
1.0.28
  • Clarifies instructions for color picker tool.
  • Fixes bug in Device Ping tool.
1.0.27
  • Improvements to configuration validation.
  • Code refinements.
Sun Nov 08, 2020 8:52 am
Multitool Plugin v1.0.31 is now available.
1.0.31
  • Fixes broken link to readme logo.
1.0.30
  • Further integration of DLFramework.
1.0.29
  • Better integration of DLFramework.
Sun Jan 03, 2021 2:11 pm
Multitool Plugin v1.0.32 is now available.
  • Adds tool to view man pages in Preview: enter the name of the command that you want to view a man page for and it will open (formatted) in Preview.
  • Updates license file.
man page viewer.png (209.09 KiB) Viewed 4206 times
Sun Jan 17, 2021 5:45 pm
Multitool Plugin v1.0.33 is now available.
  • Fixes bug in Indigo Substitution Generator
Tue May 10, 2022 5:44 pm
Multitool Plugin v2022.0.1 is now available.
Note that this release has been removed from GitHub. Please see below for further information.
Updates plugin for Indigo 2022.1 and Python 3. Note that this version of the plugin requires at least version 2022.1 of Indigo. It will not work on older versions. Also, the plugin documentation referenced below may not yet be updated to reflect all the changes in this release (the docs will be updated soon.)
  • Hides hidden methods for "Methods - Indigo Base..." and "Methods - Plugin Base..." tools by default.
  • Adds enabled state to device inventory output.
  • Standardizes Indigo method implementation.
Thu May 19, 2022 2:50 pm
Multitool Plugin v2022.1.2 is now available.
  • Fixes bug where plugin ID was inadvertently changed from `com.fogbert.indigoplugin.multitool` to `com.fogbert.indigoplugin.Multitool`
  • Includes changes from v2022.0.1 and v2022.1.1. (those two releases have been removed from GitHub.
A note about this release-- during a prior update, the plugin ID was inadvertently changed. This caused a few minor issues with respect to integrating the plugin into the Indigo Plugin Store. This release should fix this issue. Users may need to delete an existing plugin installation before installing this update.
All users on Indigo 2022.1 should apply this update. Reactivating the "Show in Plugin Store..." menu item may require a server restart. Sorry for the confusion.
Sun Jun 12, 2022 1:23 pm
Multitool Plugin v2022.1.3 is now available.
NOTE: This version contains a bug. Users should download version 2022.1.4 instead.
NOTE: this is a pre-release with a fairly large number of changes (most of which are under the hood). Since it's a pre-release, it's not available in the Indigo Plugin Store and is only available from the GitHub link below. Please report issues with this version in this forum or via GitHub.
  • "Modify Numeric Variable" and "Modify Time Variable" now support Indigo substitutions.
  • Change "Subscribe to Changes" object selector from textfield to list to make it easier to select objects to subscribe to.
  • Moves plugin environment logging to plugin menu (log on request instead of every plugin restart).
  • Refactors code.
  • Improves settings validation for "Speak String" tool.
Sun Jun 12, 2022 2:27 pm
Multitool Plugin v2022.1.4 is now available.
Found a bug. Please use this version instead of 2022.1.3.
  • Fixes bug in "Substitution Generator" -- "Module not callable."
  • Refines list of devices and variables returned with the 'Device / Variable' dropdown menu.
  • Updates WiKi for latest changes.
Wed Jun 15, 2022 6:23 pm
Multitool Plugin v2022.1.6 is now available.
This release includes changes found in pre-releases 2022.1.3 and 2022.1.4 plus some other changes and additions. The combined list of noteworthy changes in this "official" release:
  • Renames "Object Dictionary" tool as "Object Inspection" tool and adds ability to print a directory of the selected object.
  • "Modify Numeric Variable" and "Modify Time Variable" Actions now support Indigo substitutions.
  • Refines list of devices and variables returned with the "Device / Variable" dropdown menus.
  • Changes "Subscribe to Changes" object selector from textfield to list to make it easier to select targets.
  • Moves plugin environment logging to plugin menu (print on request instead of each plugin restart).
  • Improves configuration validation for "Speak String" tool.
The Wiki has also been updated to reflect the latest changes.
Mon Jul 04, 2022 6:03 am
Multitool Plugin v2022.1.7 is now available.
for Z-Wave devices.
======================================= Battery Level Report =======================================
Basement - Flood (Water)   |--------------------------------------------------| 100%
Basement - Smoke           |----------------------------------------------| 92%
Foyer - Smoke (Main Floor) |----------------------------------------------| 93%
Foyer - Smoke (Upstairs)   |----------------------------------------------| 92%
Garage - Motion            |--------------------------------------------------| 100%
Garage - Side Door         |--------------------------------------------------| 100%
Guest Bedroom - Motion     |--------------------------------------------------| 100%
Main Attic - Motion        |--------------------------------------------------| 100%
Master Bathroom - Motion   |------------------------------| 61%
Master Bedroom - Motion    |--------------------------------------------------| 100%
Master Closet - Motion     |--------------------------------------------------| 100%
Office - Motion            |-------------------------| 51%
Outdoor - Luminance        |--------------------------------------------------| 100%
Parlor - Motion            |--------------------------------------------------| 100%
