Error within get Data. ?Network connection or issue
Tue Feb 06, 2024 6:09 am
siclark offline
Hi Glenn
I have am getting the below error regularly, although devices seem to update, ie battery % is accurate and Last Updated is updated. . I have deleted account settings and reauthneticated, and so no apparent issues there.
Any ideas?
I cant seem to supress it and it repeats for each device, so a lot of errors in my logs.
Simon
FindFriendsMini                 ==================================================================================================================================
   FindFriendsMini                 Error within get Data.  ?Network connection or issue:  Error Given: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
   FindFriendsMini Error           (plugin.py: Function: refreshData  line: 967):    Exception :  Message : Caught Exception
   FindFriendsMini Error           Traceback:
  File "plugin.py", line 917, in refreshData
    devicetargets = self.appleAPI.devices
  File "/Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins/iFindFriendsMini.indigoPlugin/Contents/Server Plugin/pyicloud/base.py", line 705, in devices
    return FindMyiPhoneServiceManager(
  File "/Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins/iFindFriendsMini.indigoPlugin/Contents/Server Plugin/pyicloud/services/findmyiphone.py", line 29, in __init__
    self.refresh_client()
  File "/Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins/iFindFriendsMini.indigoPlugin/Contents/Server Plugin/pyicloud/services/findmyiphone.py", line 37, in refresh_client
    req = self.session.post(
  File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/requests/sessions.py", line 637, in post
    return self.request("POST", url, data=data, json=json, **kwargs)
  File "/Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins/iFindFriendsMini.indigoPlugin/Contents/Server Plugin/pyicloud/base.py", line 87, in request
    response = super(PyiCloudSession, self).request(method, url, timeout=15, **kwargs )
  File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/requests/sessions.py", line 589, in request
    resp = self.send(prep, **send_kwargs)
  File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/requests/sessions.py", line 703, in send
    r = adapter.send(request, **kwargs)
  File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/requests/adapters.py", line 501, in send
    raise ConnectionError(err, request=request)
   FindFriendsMini Error           Error in plugin execution:
  File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/urllib3/connectionpool.py", line 790, in urlopen
    response = self._make_request(
  File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/urllib3/connectionpool.py", line 536, in _make_request
    response = conn.getresponse()
  File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/urllib3/connection.py", line 461, in getresponse
    httplib_response = super().getresponse()
  File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/http/client.py", line 1378, in getresponse
    response.begin()
  File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/http/client.py", line 318, in begin
    version, status, reason = self._read_status()
  File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/http/client.py", line 287, in _read_status
    raise RemoteDisconnected("Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
During handling of the above exception, another exception occurred:
  File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/requests/adapters.py", line 486, in send
    resp = conn.urlopen(
  File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/urllib3/connectionpool.py", line 844, in urlopen
    retries = retries.increment(
  File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/urllib3/util/retry.py", line 470, in increment
    raise reraise(type(error), error, _stacktrace)
  File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/urllib3/util/util.py", line 38, in reraise
    raise value.with_traceback(tb)
    response.begin()
urllib3.exceptions.ProtocolError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
requests.exceptions.ConnectionError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
Tue Feb 06, 2024 2:06 pm
GlennNZ offline
Re: Error within get Data. ?Network connection or issue
Seems like peridiocally doesn’t get a reply from apple servers.
That could be anything eg firewall, server or inbetween, or at their end.
If eventually does reply (which seems so) would just ignore.
Understand that is difficult when red like this - and will see if can remove this level of logging.
Glenn
