1.2.2 "Major Problem"
Sat Jun 19, 2021 9:44 am
Different Computers offline
   Loading plugin "FindFriendsMini 1.2.2"
   Starting plugin "FindFriendsMini 1.2.2" (pid 8221)
   FindFriendsMini Error           ==================================================================================================================================
   FindFriendsMini Error           Returned Error:No module named http.cookiejar
   FindFriendsMini Error           -- FATAL ERROR - Cannot find pyicloud or cannot load pyicloud or dependency.
   FindFriendsMini Error           Major Problem. Please contact developer.  Error:No module named http.cookiejar
   FindFriendsMini
   FindFriendsMini                 ================================================ Initializing New Plugin Session =================================================
   FindFriendsMini                 Plugin name:                   FindFriendsMini
   FindFriendsMini                 Plugin version:                1.2.2
   FindFriendsMini                 Plugin ID:                     com.GlennNZ.indigoplugin.FindFriendsMini
   FindFriendsMini                 Indigo version:                2021.1.0
   FindFriendsMini                 Python version:                2.7.16 (default, Jan 26 2020, 23:50:38) [GCC 4.2.1 Compatible Apple LLVM 9.0.0 (clang-900.0.31)]
   FindFriendsMini                 Python Directory:              /System/Library/Frameworks/Python.framework/Versions/2.7
   FindFriendsMini                 Major Problem equals:          2
   FindFriendsMini                 ==================================================================================================================================
   FindFriendsMini Error           Major Problem:   Please Disable Plugin.  Now Sleeping.  Please contact Developer.
I upgraded to 1.2.2 right after upgrading Indigo to 2021.1. The old plugin version 1.04 ran fine, and downgrading the plugin back to that worked.
Sat Jun 19, 2021 3:39 pm
GlennNZ offline
Re: 1.2.2 "Major Problem"
Thanks.
It’s a bug from me unfortunately after updating a now python3 library. Interestingly others didn’t report this, so must be common to have http.cookiejar installed in python2.
Give me 5 and I’ll have a update.
Glenn
Sat Jun 19, 2021 4:55 pm
GlennNZ offline
1.2.3
In Plugin store should fix this issue.
Mon Jun 21, 2021 7:10 am
Working great now! Many thanks.
