Issue with iCloud Login 11th June
Fri Jun 14, 2019 6:58 am
McJohn offline
Re: Issue with iCloud Login 11th June
Thanks for the Python info.
Maybe this command installed another Python version elsewhere?
pip install requests[security]
There is a Python module in this directory:
/System/Library/Frameworks/Python.framework/
And this command in the terminal:
which python
Says:
/usr/local/bin/python
(Look likes the same as Jay's info)
Thanks for your time and your help.
Fri Jun 14, 2019 10:43 am
which python
Says:
That indicates you have a 3rd party Python install. The correct answer should be:
/usr/bin/python
and if you do:
which pip
it will likely tell you that it's finding the pip that's installed with that 3rd party install, so when you run:
it's installing it in the 3rd party Python. I believe all this is discussed in the aforementioned thread.
Fri Jun 14, 2019 10:59 am
McJohn offline
OK, thanks for the info.
And the solution is?
Fri Jun 14, 2019 11:01 am
Delete the non-standard Python install.
Fri Jun 14, 2019 11:13 am
McJohn offline
How?
(Sorry, but we are Apple users over more than 35 years now)
Fri Jun 14, 2019 11:15 am
McJohn wrote:
How?
How did you install it in the first place? Homebrew? Ports? Direct download installer from python.org?
Fri Jun 14, 2019 11:36 am
McJohn offline
Sorry to say but we only use the standard- and developer plugins of Indigo.
So, we never used Homebrew, Ports or other stuff and we never ever installed other Python stuff...
But in the meantime I found something of Karl's plugin... IndigoPlotD... (Sorry Karl).
Page 24 of the manual says it: it installs Homebrew...
Is it not possible to install the update to the right Python?
Thanks for the help!
Screen Shot 2019-06-14 at 19.34.56.png (467.36 KiB) Viewed 5252 times
Fri Jun 14, 2019 9:10 pm
GlennNZ offline
Hi
Somehow or another, another version of python has been installed by something...
Installing homeBrew wouldn’t do this - but once homeBrew is installed you can use it to install python. (from the path it would seem likely that homeBrew has installed python)
Also pip install requests[security] wouldn’t install python.
Could try running
python -m pip install requests[security]
From within the indigo python directory?
Like:
/usr/bin/python -m pip install requests[security]
Alternatively:
Anyone know a way I can run a super old version of OSX & indigo to try to test including libraries/ssl stuff in plugin? VM options?
(found something, I’ll see if can create a VM old Mac version and troubleshoot the connection issue)
Sat Jun 15, 2019 1:01 am
GlennNZ offline
Further to this:
Could try version 0.9.9
May, big may, fix the OSX security issues in old Macs...
In PluginStore
Sorry to disappoint but have managed to create VM version of Mac OSX with Indigo licence, and same error.
Pending timezone/time issues at least will be able to troubleshoot, see what fixes.
Glenn
Sat Jun 15, 2019 1:22 am
McJohn offline
Thank you so much Glenn!
Unfortunately (and I'm sorry to say), version 0.9.9 give the same bad result:
FindFriendsMini Error Login Failed General Error. ('Connection aborted.', error(54, 'Connection reset by peer')){'request': <PreparedRequest [POST]>, 'response': None}
FindFriendsMini Error ('Connection aborted.', error(54, 'Connection reset by peer'))
Further on I tested this:
gave this:
Requirement already satisfied: requests[security] in /usr/local/lib/python2.7/site-packages (2.22.0)
And this one:
gave this:
/usr/bin/python: No module named pip
So, I'm afraid that when I simple delete the wrong Python (Finder/trash) , the right Python still wouldn't be recognized?
Sat Jun 15, 2019 1:33 am
GlennNZ offline
Sorry, Yep, I edited above message probably at the same time.
You need to install requests[security] into right python.
Can't just delete from finder, need to delete from whatever installed it.
G
Sat Jun 15, 2019 1:45 am
GlennNZ offline
Okay,
VM old mac despite 1024x768 screen is yielding some information.
pip -m install requests[security]
Doesn't help. Although rebooting now.
OK Success on old Mac VM
Do need to install a few python packages which need to go to the right python install
These three overcome/obviously are missing on Sierra & Below:
pip install pyopenssl ndg-httpsclient pyasn1
I had an issue where version of package of 'six' was stopping pip from installing. This was overcome by using
 pip install pyopenssl --ignore-installed six --user
 pip install ndg-httpsclient --ignore-installed six --user
 pip install pyansn1 --ignore-installed six --user
Also had an early issue, where pip didn't seem to exist. Overcome by
curl -O https://bootstrap.pypa.io/get-pip.py
python get-pip.py
Downloads get-pip.py, and then runs it with python..
Sat Jun 15, 2019 2:12 am
GlennNZ offline
OK - so for @McJohn
Would try
From a terminal Window:
Download py file to install pip if missing
then
/usr/bin/python get-pip.py --user
Run that file from correct python install
then
/usr/bin/python -m pip install pyasn1 --ignore-installed six --user
then
/usr/bin/python -m pip install pyopenssl --ignore-installed six --user
then
/usr/bin/python -m pip install ndg-httpsclient --ignore-installed six --user
Phew
Then restart Plugin and enter details
Sat Jun 15, 2019 2:23 am
McJohn offline
This one gives an error:
[code]Downloading https://files.pythonhosted.org/packages ... ne-any.whl
Installing collected packages: pip, wheel
ERROR: Could not install packages due to an EnvironmentError: [Errno 13] Permission denied: '/Library/Python/2.7/site-packages/pip'
Consider using the `--user` option or check the permissions.
(There is one Admin at this Mac)
Sorry :cry:
Sat Jun 15, 2019 2:24 am
GlennNZ offline
Yep Check the post again - already updated
