Generated Images Not Valid
Thu Mar 29, 2018 8:09 pm
danowitz offline
When I try to open the generated images, I am getting an error that says "The file "All_device.jpg" could not be opened. It may be damaged or use a file format that preview doesn't recognize.
Thoughts?
Joel
Thu Mar 29, 2018 8:43 pm
GlennNZ offline
Re: Generated Images Not Valid
Thoughts?
Joel
Hi
Any number of aspects could be causing that.
- Have you changed the save location? Does your user have directory rights?
- Is the file 0 bytes long?
- Have you entered your Google API key - otherwise images will not be able to be download correctly?
- Does the log show anything???
You could turn on debug and show maps - and post the debug output if problem not simply solved.
Glenn
Sun Aug 19, 2018 11:49 am
Swear I asked this before but I've forgotten the answer.
There's no path listed in the config, and I've looked in the IWS images folder and the ~ user folder, and I can't find where the plugin saves map images by default.
Sun Aug 19, 2018 4:39 pm
GlennNZ offline
Should be here:
Within current User Directory - Documents - and self created directory:
Mac-Username-Home/Documents/Indigo-iFindFriendMini/
Glenn
