See here for 1.5.1+ and a work-around for some
https://github.com/Ghawken/IndigoPlugin ... /tag/1.5.1Apple has big server changes which this is a response to.
Apple has remove support for 'Friend' devices, and accessing friends info, except through ipad/iphones
What does this mean?
It means we can no longer access Friend data in any fashion.
I suspect this is permanent, the web lost access a year or so ago, whilst the web link remained and gave data - that has now gone.
We however continue to access Family and Own Device data (every family device, and every personal device)
This means you may need to change your signed in account - from indigo (with friends) to main apple account with family members/own devices.
I suspect most usage is within Family groups,
Which this new release continues to support.
I have updated and hopefully have minimized the need for any major device deletions/triggers/impact etc.
Steps:
Install this release. (1.5.1). (or 1.5.5 from Code button github.com python_3 tree)
I would go into current iFriendDevice devices (which will be offline and fail to work) and press the Edit button,
& Go to Model: Menu
Change the Model to
FindFriends Family Device.
Select the correct Family iOS Device (and here are all devices from all family, including the logged account) from the popup.
Save and exit.
Repeat for all your 'Friend' plugin devices.
Hopefully usual function resumes….
&& Should we change name of plugin?
Probably - as now really a FindFamily plugin, rather than friends (but will see if any other work-around down the track)
Certainly some the documentation is now out dated, as really need to use main apple account and here we are accessing family members. Not quite as seperate, nor as flexible, but it does look like this change from apple is one way.
(all other implementations have the same issue and one or another of these may come up with another solution - will wait and see, and should be easy to change back if a solution is forthcoming)
Glenn
