I have am getting the below error regularly, although devices seem to update, ie battery % is accurate and Last Updated is updated. . I have deleted account settings and reauthneticated, and so no apparent issues there.
Any ideas?
I cant seem to supress it and it repeats for each device, so a lot of errors in my logs.
Simon
- Code: Select all
FindFriendsMini ==================================================================================================================================
FindFriendsMini Error within get Data. ?Network connection or issue: Error Given: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
FindFriendsMini Error (plugin.py: Function: refreshData line: 967): Exception : Message : Caught Exception
FindFriendsMini Error Traceback:
File "plugin.py", line 917, in refreshData
devicetargets = self.appleAPI.devices
File "/Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins/iFindFriendsMini.indigoPlugin/Contents/Server Plugin/pyicloud/base.py", line 705, in devices
return FindMyiPhoneServiceManager(
File "/Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins/iFindFriendsMini.indigoPlugin/Contents/Server Plugin/pyicloud/services/findmyiphone.py", line 29, in __init__
self.refresh_client()
File "/Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins/iFindFriendsMini.indigoPlugin/Contents/Server Plugin/pyicloud/services/findmyiphone.py", line 37, in refresh_client
req = self.session.post(
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/requests/sessions.py", line 637, in post
return self.request("POST", url, data=data, json=json, **kwargs)
File "/Library/Application Support/Perceptive Automation/Indigo 2023.2/Plugins/iFindFriendsMini.indigoPlugin/Contents/Server Plugin/pyicloud/base.py", line 87, in request
response = super(PyiCloudSession, self).request(method, url, timeout=15, **kwargs )
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/requests/sessions.py", line 589, in request
resp = self.send(prep, **send_kwargs)
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/requests/sessions.py", line 703, in send
r = adapter.send(request, **kwargs)
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/requests/adapters.py", line 501, in send
raise ConnectionError(err, request=request)
FindFriendsMini Error Error in plugin execution:
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/urllib3/connectionpool.py", line 790, in urlopen
response = self._make_request(
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/urllib3/connectionpool.py", line 536, in _make_request
response = conn.getresponse()
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/urllib3/connection.py", line 461, in getresponse
httplib_response = super().getresponse()
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/http/client.py", line 1378, in getresponse
response.begin()
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/http/client.py", line 318, in begin
version, status, reason = self._read_status()
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/http/client.py", line 287, in _read_status
raise RemoteDisconnected("Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
During handling of the above exception, another exception occurred:
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/requests/adapters.py", line 486, in send
resp = conn.urlopen(
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/urllib3/connectionpool.py", line 844, in urlopen
retries = retries.increment(
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/urllib3/util/retry.py", line 470, in increment
raise reraise(type(error), error, _stacktrace)
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/site-packages/urllib3/util/util.py", line 38, in reraise
raise value.with_traceback(tb)
response.begin()
urllib3.exceptions.ProtocolError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
requests.exceptions.ConnectionError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
