Error after update
Posted:
Thu Jun 09, 2022 1:53 pm
by mundmc
First, thank you for all your contributiions!
Now, I haven't used this in a bit, so maybe the error is not related to the recently released update, but I'm getting this in the log:
- Code: Select all
Jun 9, 2022 at 3:44:41 PM
Z-Wave Node Matrix Debugging on (Level: Warning Messages (30)
Z-Wave Node Matrix Error Error in plugin execution MenuAction:
File "plugin.py", line 311, in make_the_matrix
type: key com.fogbert.indigoplugin.nodeMatrix not found in dict
Any thoughts?
Re: Error after update
Posted:
Thu Jun 09, 2022 2:17 pm
by DaveL17
Sorry to hear you're having trouble. I'm going to need a bit more information in order to help. Please restart the plugin and post the first few lines of the Event Log messages that show the plugin environment information.
Posted:
Tue Jun 14, 2022 6:00 pm
by mundmc
Gladly!
- Code: Select all
Starting plugin "Z-Wave Node Matrix 2022.0.2" (pid 29433)
Z-Wave Node Matrix =================================================== Initializing New Plugin Session ===================================================
Z-Wave Node Matrix Plugin name: Z-Wave Node Matrix
Z-Wave Node Matrix Plugin version: 2022.0.2
Z-Wave Node Matrix Plugin ID: com.fogbert.indigoplugin.nodeMatrix
Z-Wave Node Matrix Indigo version: 2022.1.1
Z-Wave Node Matrix Python version: 3.10.2 (v3.10.2:a58ebcc701, Jan 13 2022, 14:50:16) [Clang 13.0.0 (clang-1300.0.29.30)]
Z-Wave Node Matrix Mac OS Version: 10.15.7
Z-Wave Node Matrix Process ID: 29433
Z-Wave Node Matrix =======================================================================================================================================
Started plugin "Z-Wave Node Matrix 2022.0.2"
Is that what you asked for?
Posted:
Tue Jun 14, 2022 7:37 pm
by DaveL17
That's what I needed, thanks.
I responded to your DM on that other issue. If that suggestion solves your issue, I'll get a fix pushed out.
Posted:
Sat Jul 30, 2022 3:41 am
by Londonmark
Am getting the same thing...
0 Jul 2022 at 10:41:05
Reloading plugin "Z-Wave Node Matrix 2022.0.2" using API v3.0
Stopping plugin "Z-Wave Node Matrix 2022.0.2" (pid 4234)
Stopped plugin "Z-Wave Node Matrix 2022.0.2"
Starting plugin "Z-Wave Node Matrix 2022.0.2" (pid 4869)
Z-Wave Node Matrix Indigo version: 2022.1.2
Z-Wave Node Matrix Mac OS Version: 12.5
Z-Wave Node Matrix Process ID: 4869
Z-Wave received "Hall Motion Sensor (Z-wave)" status update is off
Posted:
Sat Jul 30, 2022 5:05 am
by DaveL17
Sorry - this one slipped through the cracks.
I've pushed
version 2022.0.4 which should address this bug.
Posted:
Sat Jul 30, 2022 4:01 pm
by Londonmark
It does. But I can’t find the matrix! Trying to save it to my documents folder and although it says it’s generated nothing appears.
Posted:
Sat Jul 30, 2022 6:13 pm
by DaveL17
Take a look at the plugin configuration dialog -- it might be configured to save the image to a prior version of Indigo.
Posted:
Mon Aug 01, 2022 4:18 am
by Londonmark
Solved it. I'd tried to save in Documents, but it didn't like that so I reinstalled and found it was trying to save in Indigowebserver rather than Web Assets.
Posted:
Mon Aug 01, 2022 4:43 am
by DaveL17
Londonmark wrote:Solved it. I'd tried to save in Documents, but it didn't like that so I reinstalled and found it was trying to save in Indigowebserver rather than Web Assets.
Glad you were able to sort it.
