Error after update
Thu Jun 09, 2022 1:53 pm
mundmc offline
Error after update
First, thank you for all your contributiions!
Now, I haven't used this in a bit, so maybe the error is not related to the recently released update, but I'm getting this in the log:
Jun 9, 2022 at 3:44:41 PM
   Z-Wave Node Matrix              Debugging on (Level: Warning Messages (30)
   Z-Wave Node Matrix Error        Error in plugin execution MenuAction:
  File "plugin.py", line 311, in make_the_matrix
type: key com.fogbert.indigoplugin.nodeMatrix not found in dict
Any thoughts?
Thu Jun 09, 2022 2:17 pm
Re: Error after update
Sorry to hear you're having trouble. I'm going to need a bit more information in order to help. Please restart the plugin and post the first few lines of the Event Log messages that show the plugin environment information.
Tue Jun 14, 2022 6:00 pm
mundmc offline
Gladly!
Starting plugin "Z-Wave Node Matrix 2022.0.2" (pid 29433)
   Z-Wave Node Matrix              =================================================== Initializing New Plugin Session ===================================================
   Z-Wave Node Matrix              Plugin name:                    Z-Wave Node Matrix
   Z-Wave Node Matrix              Plugin version:                 2022.0.2
   Z-Wave Node Matrix              Plugin ID:                      com.fogbert.indigoplugin.nodeMatrix
   Z-Wave Node Matrix              Indigo version:                 2022.1.1
   Z-Wave Node Matrix              Python version:                 3.10.2 (v3.10.2:a58ebcc701, Jan 13 2022, 14:50:16) [Clang 13.0.0 (clang-1300.0.29.30)]
   Z-Wave Node Matrix              Mac OS Version:                 10.15.7
   Z-Wave Node Matrix              Process ID:                     29433
   Z-Wave Node Matrix              =======================================================================================================================================
   Started plugin "Z-Wave Node Matrix 2022.0.2"
Is that what you asked for?
Tue Jun 14, 2022 7:37 pm
That's what I needed, thanks.
I responded to your DM on that other issue. If that suggestion solves your issue, I'll get a fix pushed out.
Sat Jul 30, 2022 3:41 am
Londonmark offline
Am getting the same thing...
0 Jul 2022 at 10:41:05
Reloading plugin "Z-Wave Node Matrix 2022.0.2" using API v3.0
Stopping plugin "Z-Wave Node Matrix 2022.0.2" (pid 4234)
Stopped plugin "Z-Wave Node Matrix 2022.0.2"
Starting plugin "Z-Wave Node Matrix 2022.0.2" (pid 4869)
Z-Wave Node Matrix Indigo version: 2022.1.2
Z-Wave Node Matrix Mac OS Version: 12.5
Z-Wave Node Matrix Process ID: 4869
Z-Wave received "Hall Motion Sensor (Z-wave)" status update is off
Sat Jul 30, 2022 5:05 am
Sorry - this one slipped through the cracks.
I've pushed version 2022.0.4 which should address this bug.
Sat Jul 30, 2022 4:01 pm
Londonmark offline
It does. But I can’t find the matrix! Trying to save it to my documents folder and although it says it’s generated nothing appears.
Sat Jul 30, 2022 6:13 pm
Take a look at the plugin configuration dialog -- it might be configured to save the image to a prior version of Indigo.
Mon Aug 01, 2022 4:18 am
Londonmark offline
Solved it. I'd tried to save in Documents, but it didn't like that so I reinstalled and found it was trying to save in Indigowebserver rather than Web Assets.
Mon Aug 01, 2022 4:43 am
Glad you were able to sort it.
