Only one node neighbors node1 ?
Sun Jul 08, 2018 8:03 am
Umtauscher offline
Re: Only one node neighbors node1 ?
  Script                          056 - Relay Switch [822568]: 12, 27, 28, 39, 50, 54, 57, 58, 59, 60, 61, 74, 76, 86, 97, 122, 133
   Script                          056 - Relay Switch 2 [2804526]: None
   Script                          057 - Relay Switch [386978470]: 3, 27, 28, 39, 50, 54, 56, 58, 59, 60, 62, 74, 76, 78, 80, 86, 97, 122, 131, 133
   Script                          058 - Relay Switch 2 [18186564]: None
   Script                          059 - Relay Switch 2 [1985889449]: None
   Script                          061 - Relay Switch 2 [1443673078]: None
   Script                          062 - Switch 2 [1056355098]: None
   Script                          074 - Relay Switch 2 [1407270308]: None
   Script                          1. OG Temperatur [301794450]: None
   Script                          1. OG Tilt/Tamper [699741549]: None
   Script                          107 - Relay Power Switch [24154744]: 9, 12, 54, 58, 62, 63, 86, 97, 100
   Script                          114 - Relay Power Switch [742161752]: 3, 4, 9, 12, 27, 39, 50, 54, 56, 57, 58, 59, 62, 63, 74, 78, 80, 86, 97, 100, 113
   Script                          122 - Switch 2 [513441554]: None
   Script                          131 - Switch 2 [1141000126]: None
   Script                          133 - Wall Plug Relay (FGWP102) [1711124218]: 3, 4, 10, 12, 27, 58, 59, 60, 74, 78, 80, 122
   Script                          2. OG Temperatur [1843310254]:
   Script                          2. OG Tilt/Tamper [1177008313]:
   Script                          Arbeitsplatte [139991636]: 3, 4, 10, 27, 54, 56, 57, 58, 59, 60, 61, 62, 74, 78, 80, 86, 97, 122, 131, 133
   Script                          Arbeitsplatte links [117201011]: 3, 4, 10, 12, 27, 28, 39, 54, 56, 57, 58, 59, 60, 61, 62, 74, 76, 78, 80, 86, 97, 103, 131, 133
   Script                          Außenlampe Eingang [924668941]: 3, 4, 12, 27, 28, 57, 58, 59, 60, 61, 62, 74, 78, 86, 97, 103, 122
   Script                          Bewegungsmelder 1.OG [348473248]: 1, 3, 27, 28, 39, 50, 54, 56, 57, 58, 59, 62, 78, 122, 131
   Script                          Bewegungsmelder 2. OG [381893400]: 1, 3, 4, 9, 27, 28, 50, 54, 56, 57, 58, 59, 60, 61, 62, 76, 78, 86, 97
   Script                          Bewegungsmelder Gästeklo [68361281]: 1, 3, 9, 12, 58, 59, 60, 62, 74, 78, 80, 97, 100, 122
   Script                          Bewegungsmelder Küche [89688834]: 1, 3, 4, 9, 12, 22, 27, 39, 56, 58, 60, 61, 62, 63, 75, 78
   Script                          Boxenlampen [1875461131]: 10, 12, 27, 57, 58, 60, 62, 74, 78, 86, 122, 133
   Script                          Dachfenster links [1440251296]: 27, 28, 39, 50, 54, 56, 57, 59, 62, 76, 86, 97, 122
   Script                          Dachfenster links Tamper Switch [73192680]: None
   Script                          Dachfenster links Temperatur [1489754979]: None
   Script                          Dachfenster rechts [1618377781]: 27, 28, 39, 50, 54, 56, 57, 59, 76, 86, 97, 124
   Script                          Dachfenster rechts Tamper Switch [163594255]: None
   Script                          Dachfenster rechts Temperatur [1957884309]: None
   Script                          Deckenlampe [1433310462]: 3, 4, 12, 56, 58, 59, 60, 62, 74, 78, 80, 122, 133
   Script                          Deckenlampe Dimmer [140509571]: 3, 4, 12, 27, 28, 39, 50, 54, 56, 57, 58, 59, 60, 61, 62, 74, 76, 80, 97, 122, 131, 133
   Script                          Deckenlampe Küche [1716683166]: 3, 4, 10, 12, 27, 28, 54, 57, 58, 59, 60, 61, 74, 78, 80, 86, 97, 103, 122, 131, 133
   Script                          Deckenlampe Ruth [1896970978]: 3, 4, 10, 12, 27, 28, 39, 50, 54, 56, 57, 58, 62, 76, 86, 97, 122, 131, 133
   Script                          Deckenlampe Studio [1685088213]:
   Script                          Eingangstür [1061866982]: 3, 4, 12, 27, 54, 57, 58, 60, 61, 62, 74, 78, 80, 86, 97, 122, 131
   Script                          Eingangstür - Tamper Switch [1976961658]: None
   Script                          Eingangstür - Temperatur [74210471]: None
   Script                          Esstisch [1436322377]: 3, 4, 10, 12, 27, 28, 39, 50, 54, 56, 57, 59, 60, 61, 62, 74, 78, 80, 86, 97, 103, 122, 131, 133
   Script                          Fenster Ruth  [1554611290]: 1, 3, 27, 28, 39, 54, 57, 58, 59, 74, 76, 86, 97
   Script                          Fenster Ruth Tamper Switch [627069345]: None
   Script                          Fenster Ruth Temperatur [584178040]: None
   Script                          Fenster Studio [615947154]: 27, 28, 39, 50, 54, 56, 57, 59, 76, 86, 124
   Script                          Fenster Studio Tamper Switch [1086255929]: None
   Script                          Fenster Studio Temperatur [1895929939]:
   Script                          Fenster W. li. [67242493]: 1, 9, 27, 39, 54, 57, 58, 59, 62, 86, 97
   Script                          Fenster W. li. Tamper Switch [132345432]: None
   Script                          Fenster W. li. Temperatur [1873863007]: None
   Script                          Fenster W. re. [662606495]: 12, 27, 28, 39, 54, 56, 57, 58, 59, 60, 61, 62, 76, 86, 97, 114, 122, 131
   Script                          Fenster W. re. Tamper Switch [1409009467]: None
   Script                          Fenster W. re. Temperature [1990184362]: None
   Script                          Helligkeit 1.OG [1836194591]: None
   Script                          Helligkeit 2.OG [207926896]: None
   Script                          Helligkeit Küche [978386071]: None
   Script                          Keller Nord Tamper Switch [1447841539]: None
   Script                          Keller Nord Temperatur [1762776311]: None
   Script                          Keller Süd Tamper Switch [1556105200]: None
   Script                          Keller Süd Temperatur [703541392]: None
   Script                          Kellerfenster Nord [1227213437]: 1, 58, 60, 62, 122, 131
   Script                          Kellerfenster Süd [808008304]: 1, 3, 58, 60, 61, 62, 63, 74, 78, 80
   Script                          Keyfob (FGKF601) [374652588]: 1, 3, 4, 9, 10, 12, 27, 28, 50, 56, 57, 58, 59, 60, 61, 62, 74, 76, 78, 80, 86, 97, 100, 122, 124
   Script                          Klofenster [1234445639]: 3, 4, 12, 27, 28, 39, 54, 56, 57, 58, 59, 60, 61, 62, 78, 80, 86, 97, 122, 131
   Script                          Klofenster - Tamper Switch [35483318]: None
   Script                          Klofenster - Temperatur [135929692]:
   Script                          Küche Temperatur [1094029124]: None
   Script                          Küche Tilt/Tamper [99430321]: None
   Script                          Küchenfenster [1725081489]: 1, 4, 10, 12, 27, 56, 58, 59, 60, 61, 62, 74, 78, 80, 86, 97, 122, 124, 131
   Script                          Küchenfenster - Tamper Switch [829195639]: None
   Script                          Küchenfenster Temperatur [9646215]: None
   Script                          Luminance Gästeklo [1285976121]: None
   Script                          Rauchmelder [887932831]: None
   Script                          Rolladen Dach links [1646658939]: 27, 28, 39, 54, 56, 57, 58, 59, 60, 76, 86, 97
   Script                          Rolladen Dach rechts [1423365922]: 3, 27, 28, 50, 54, 56, 57, 58, 59, 60, 61, 74, 76, 86, 97, 122, 133
   Script                          Schrankbeleuchtung [1122371918]: 27, 39, 50, 54, 56, 57, 58, 59, 60, 61, 62, 74, 76, 86, 97, 122, 131
   Script                          Schreibtischlampe [15714752]: 4, 12, 27, 28, 39, 50, 54, 56, 57, 58, 59, 60, 61, 62, 74, 86, 122, 131
   Script                          Sirene [92722386]: 3, 4, 10, 12, 27, 28, 39, 50, 54, 56, 57, 58, 59, 60, 62, 74, 76, 78, 80, 86, 97, 122, 131, 133
   Script                          Sirene Tamper Switch [136256874]: None
   Script                          Sirene Temperature [7613047]:
   Script                          Stehlampe [832091583]: 4, 10, 27, 28, 54, 57, 58, 59, 61, 62, 74, 76, 78, 80, 86, 122, 131, 133
   Script                          Stehlampe Ruth [13889882]: 3, 4, 12, 28, 39, 50, 54, 56, 57, 58, 59, 60, 62, 74, 76, 78, 86, 97, 122, 131, 133
   Script                          Stehlampe Schlafzimmer [1640544170]: 3, 12, 27, 28, 39, 50, 56, 57, 58, 59, 62, 74, 76, 78, 80, 86, 97, 122, 131
   Script                          Telefonlampe [1459060434]: 3, 10, 12, 27, 56, 58, 59, 61, 62, 74, 76, 78, 86, 97, 122, 131, 133
   Script                          Temperatur [114756656]:
   Script                          Temperature Gästeklo [856118609]: None
   Script                          Terrassentür [1967020541]: 3, 4, 10, 12, 27, 57, 58, 59, 60, 61, 62, 74, 78, 80, 86, 97, 122, 131, 133
   Script                          Terrassentür - Tamper Switch [1983697695]: None
   Script                          Terrassentür Temperatur  [1746329838]: None
   Script                          Tilt/Tamper [1216827691]:
   Script                          Tilt/Tamper Gästeklo [682227201]: None
   Script                          Tischlampe [1880470196]: 4, 27, 28, 39, 50, 54, 56, 57, 59, 70, 74, 82, 84, 86, 94, 97, 100, 102, 104, 124, 126, 127
   Script                          Treppenhaus EG [1417133177]: 4, 12, 27, 28, 39, 56, 58, 60, 62, 74, 80, 86, 97, 103, 122, 131
   Script                          Treppenhaus OG [190514559]: 3, 10, 12, 27, 28, 39, 50, 56, 57, 58, 61, 62, 74, 76, 78, 80, 86, 97, 103, 122, 131, 133
   Script                          Ventilator [1038077280]: 1, 3, 4, 10, 12, 27, 28, 54, 56, 57, 58, 59, 60, 62, 70, 73, 76, 77, 78, 80, 82, 85, 86, 97, 99, 102, 122, 124, 126, 127, 130
   Script                          Wassersensor [1307154806]: 12, 58, 60, 61, 62, 131
   Script                          Weihnachtsbaum alt [176679712]: 1, 114
   Script                          Zwischenstecker [1489676697]: 3, 4, 10, 12, 27, 54, 57, 58, 60, 62, 74, 80, 97, 122, 131, 133
Sun Jul 08, 2018 8:11 am
I am so sorry - I included the device ID instead of the device address. This one please:
for dev in indigo.devices.itervalues(filter='indigo.zwave'):
       indigo.server.log(u"{0} [{1}]: {2}".format(dev.name, dev.address, dev.ownerProps['zwNodeNeighborsStr']))
   except KeyError:
      indigo.server.log(u"{0} [{1}]: None".format(dev.name, dev.address))
Sun Jul 08, 2018 8:14 am
Umtauscher offline
I thought so. :D
   Embedded script executor host started
   Z-Wave                          received "2. OG Temperatur" sensor update to 26.6 °C
   Script                          056 - Relay Switch [56]: 12, 27, 28, 39, 50, 54, 57, 58, 59, 60, 61, 74, 76, 86, 97, 122, 133
   Script                          056 - Relay Switch 2 [56]: None
   Script                          057 - Relay Switch [57]: 3, 27, 28, 39, 50, 54, 56, 58, 59, 60, 62, 74, 76, 78, 80, 86, 97, 122, 131, 133
   Script                          058 - Relay Switch 2 [58]: None
   Script                          059 - Relay Switch 2 [59]: None
   Script                          061 - Relay Switch 2 [61]: None
   Script                          062 - Switch 2 [62]: None
   Script                          074 - Relay Switch 2 [74]: None
   Script                          1. OG Temperatur [83]: None
   Script                          1. OG Tilt/Tamper [83]: None
   Script                          107 - Relay Power Switch [107]: 9, 12, 54, 58, 62, 63, 86, 97, 100
   Script                          114 - Relay Power Switch [114]: 3, 4, 9, 12, 27, 39, 50, 54, 56, 57, 58, 59, 62, 63, 74, 78, 80, 86, 97, 100, 113
   Script                          122 - Switch 2 [122]: None
   Script                          131 - Switch 2 [131]: None
   Script                          133 - Wall Plug Relay (FGWP102) [133]: 3, 4, 10, 12, 27, 58, 59, 60, 74, 78, 80, 122
   Script                          2. OG Temperatur [84]:
   Script                          2. OG Tilt/Tamper [84]:
   Script                          Arbeitsplatte [12]: 3, 4, 10, 27, 54, 56, 57, 58, 59, 60, 61, 62, 74, 78, 80, 86, 97, 122, 131, 133
   Script                          Arbeitsplatte links [122]: 3, 4, 10, 12, 27, 28, 39, 54, 56, 57, 58, 59, 60, 61, 62, 74, 76, 78, 80, 86, 97, 103, 131, 133
   Script                          Außenlampe Eingang [131]: 3, 4, 12, 27, 28, 57, 58, 59, 60, 61, 62, 74, 78, 86, 97, 103, 122
   Script                          Bewegungsmelder 1.OG [83]: 1, 3, 27, 28, 39, 50, 54, 56, 57, 58, 59, 62, 78, 122, 131
   Script                          Bewegungsmelder 2. OG [84]: 1, 3, 4, 9, 27, 28, 50, 54, 56, 57, 58, 59, 60, 61, 62, 76, 78, 86, 97
   Script                          Bewegungsmelder Gästeklo [130]: 1, 3, 9, 12, 58, 59, 60, 62, 74, 78, 80, 97, 100, 122
   Script                          Bewegungsmelder Küche [79]: 1, 3, 4, 9, 12, 22, 27, 39, 56, 58, 60, 61, 62, 63, 75, 78
   Script                          Boxenlampen [80]: 10, 12, 27, 57, 58, 60, 62, 74, 78, 86, 122, 133
   Script                          Dachfenster links [82]: 27, 28, 39, 50, 54, 56, 57, 59, 62, 76, 86, 97, 122
   Script                          Dachfenster links Tamper Switch [82]: None
   Script                          Dachfenster links Temperatur [82]: None
   Script                          Dachfenster rechts [94]: 27, 28, 39, 50, 54, 56, 57, 59, 76, 86, 97, 124
   Script                          Dachfenster rechts Tamper Switch [94]: None
   Script                          Dachfenster rechts Temperatur [94]: None
   Script                          Deckenlampe [10]: 3, 4, 12, 56, 58, 59, 60, 62, 74, 78, 80, 122, 133
   Script                          Deckenlampe Dimmer [86]: 3, 4, 12, 27, 28, 39, 50, 54, 56, 57, 58, 59, 60, 61, 62, 74, 76, 80, 97, 122, 131, 133
   Script                          Deckenlampe Küche [62]: 3, 4, 10, 12, 27, 28, 54, 57, 58, 59, 60, 61, 74, 78, 80, 86, 97, 103, 122, 131, 133
   Script                          Deckenlampe Ruth [59]: 3, 4, 10, 12, 27, 28, 39, 50, 54, 56, 57, 58, 62, 76, 86, 97, 122, 131, 133
   Script                          Deckenlampe Studio [57]:
   Script                          Eingangstür [135]: 3, 4, 12, 27, 54, 57, 58, 60, 61, 62, 74, 78, 80, 86, 97, 122, 131
   Script                          Eingangstür - Tamper Switch [135]: None
   Script                          Eingangstür - Temperatur [135]: None
   Script                          Esstisch [58]: 3, 4, 10, 12, 27, 28, 39, 50, 54, 56, 57, 59, 60, 61, 62, 74, 78, 80, 86, 97, 103, 122, 131, 133
   Script                          Fenster Ruth  [102]: 1, 3, 27, 28, 39, 54, 57, 58, 59, 74, 76, 86, 97
   Script                          Fenster Ruth Tamper Switch [102]: None
   Script                          Fenster Ruth Temperatur [102]: None
   Script                          Fenster Studio [104]: 27, 28, 39, 50, 54, 56, 57, 59, 76, 86, 124
   Script                          Fenster Studio Tamper Switch [104]: None
   Script                          Fenster Studio Temperatur [104]:
   Script                          Fenster W. li. [101]: 1, 9, 27, 39, 54, 57, 58, 59, 62, 86, 97
   Script                          Fenster W. li. Tamper Switch [101]: None
   Script                          Fenster W. li. Temperatur [101]: None
   Script                          Fenster W. re. [105]: 12, 27, 28, 39, 54, 56, 57, 58, 59, 60, 61, 62, 76, 86, 97, 114, 122, 131
   Script                          Fenster W. re. Tamper Switch [105]: None
   Script                          Fenster W. re. Temperature [105]: None
   Script                          Helligkeit 1.OG [83]: None
   Script                          Helligkeit 2.OG [84]: None
   Script                          Helligkeit Küche [79]: None
   Script                          Keller Nord Tamper Switch [95]: None
   Script                          Keller Nord Temperatur [95]: None
   Script                          Keller Süd Tamper Switch [99]: None
   Script                          Keller Süd Temperatur [99]: None
   Script                          Kellerfenster Nord [95]: 1, 58, 60, 62, 122, 131
   Script                          Kellerfenster Süd [99]: 1, 3, 58, 60, 61, 62, 63, 74, 78, 80
   Script                          Keyfob (FGKF601) [127]: 1, 3, 4, 9, 10, 12, 27, 28, 50, 56, 57, 58, 59, 60, 61, 62, 74, 76, 78, 80, 86, 97, 100, 122, 124
   Script                          Klofenster [136]: 3, 4, 12, 27, 28, 39, 54, 56, 57, 58, 59, 60, 61, 62, 78, 80, 86, 97, 122, 131
   Script                          Klofenster - Tamper Switch [136]: None
   Script                          Klofenster - Temperatur [136]:
   Script                          Küche Temperatur [79]: None
   Script                          Küche Tilt/Tamper [79]: None
   Script                          Küchenfenster [77]: 1, 4, 10, 12, 27, 56, 58, 59, 60, 61, 62, 74, 78, 80, 86, 97, 122, 124, 131
   Script                          Küchenfenster - Tamper Switch [77]: None
   Script                          Küchenfenster Temperatur [77]: None
   Script                          Luminance Gästeklo [130]: None
   Script                          Rauchmelder [60]: None
   Script                          Rolladen Dach links [50]: 27, 28, 39, 54, 56, 57, 58, 59, 60, 76, 86, 97
   Script                          Rolladen Dach rechts [39]: 3, 27, 28, 50, 54, 56, 57, 58, 59, 60, 61, 74, 76, 86, 97, 122, 133
   Script                          Schrankbeleuchtung [28]: 27, 39, 50, 54, 56, 57, 58, 59, 60, 61, 62, 74, 76, 86, 97, 122, 131
   Script                          Schreibtischlampe [97]: 4, 12, 27, 28, 39, 50, 54, 56, 57, 58, 59, 60, 61, 62, 74, 86, 122, 131
   Script                          Sirene [124]: 3, 4, 10, 12, 27, 28, 39, 50, 54, 56, 57, 58, 59, 60, 62, 74, 76, 78, 80, 86, 97, 122, 131, 133
   Script                          Sirene Tamper Switch [124]: None
   Script                          Sirene Temperature [124]:
   Script                          Stehlampe [3]: 4, 10, 27, 28, 54, 57, 58, 59, 61, 62, 74, 76, 78, 80, 86, 122, 131, 133
   Script                          Stehlampe Ruth [27]: 3, 4, 12, 28, 39, 50, 54, 56, 57, 58, 59, 60, 62, 74, 76, 78, 86, 97, 122, 131, 133
   Script                          Stehlampe Schlafzimmer [54]: 3, 12, 27, 28, 39, 50, 56, 57, 58, 59, 62, 74, 76, 78, 80, 86, 97, 122, 131
   Script                          Telefonlampe [4]: 3, 10, 12, 27, 56, 58, 59, 61, 62, 74, 76, 78, 86, 97, 122, 131, 133
   Script                          Temperatur [103]:
   Script                          Temperature Gästeklo [130]: None
   Script                          Terrassentür [70]: 3, 4, 10, 12, 27, 57, 58, 59, 60, 61, 62, 74, 78, 80, 86, 97, 122, 131, 133
   Script                          Terrassentür - Tamper Switch [70]: None
   Script                          Terrassentür Temperatur  [70]: None
   Script                          Tilt/Tamper [103]:
   Script                          Tilt/Tamper Gästeklo [130]: None
   Script                          Tischlampe [76]: 4, 27, 28, 39, 50, 54, 56, 57, 59, 70, 74, 82, 84, 86, 94, 97, 100, 102, 104, 124, 126, 127
   Script                          Treppenhaus EG [61]: 4, 12, 27, 28, 39, 56, 58, 60, 62, 74, 80, 86, 97, 103, 122, 131
   Script                          Treppenhaus OG [60]: 3, 10, 12, 27, 28, 39, 50, 56, 57, 58, 61, 62, 74, 76, 78, 80, 86, 97, 103, 122, 131, 133
   Script                          Ventilator [74]: 1, 3, 4, 10, 12, 27, 28, 54, 56, 57, 58, 59, 60, 62, 70, 73, 76, 77, 78, 80, 82, 85, 86, 97, 99, 102, 122, 124, 126, 127, 130
   Script                          Wassersensor [103]: 12, 58, 60, 61, 62, 131
   Script                          Weihnachtsbaum alt [113]: 1, 114
   Script                          Zwischenstecker [78]: 3, 4, 10, 12, 27, 54, 57, 58, 60, 62, 74, 80, 97, 122, 131, 133
Sun Jul 08, 2018 8:19 am
Perfect, thanks. Let me have a look.
Sun Jul 08, 2018 9:18 am
I must admit that I'm a bit confused by all this.
Here is the most recent information you posted, with only the distinct devices shown (eliminates all sub-devices).
Your example of the Ventilator device (which shows Node 1 as a neighbor):
Does *not* seem to match Node 74 in the image you posted. That appears to show neighbors of [3, 27, 28, 39, 50, 54, 56, 58, 59, 60, 62, 74, 76, 78, 80, 86, 97, 122, 131, 133] which corresponds to Node 57.
In response to your initial question, it appears that about 12 of your devices list Node 1 as a neighbor.
Regarding the device list not matching the image, I wonder if you've discovered a bug where a combination of display settings may be breaking the plot (I haven't reconciled all your devices against the plot.) Have you made any changes to your system since posting the image above? I'm going to look at this a bit more for my own system to see if I'm getting similar results.
Sun Jul 08, 2018 9:57 am
Umtauscher offline
I just made an plot to rule out any changes that might have happened yesterday.
This shoul replect exacly what you see in the script output.
Sun Jul 08, 2018 10:02 am
This may be a slightly more useful script for our exercise:
matrix = {}
        neighbors = dev.ownerProps['zwNodeNeighborsStr']
        if len(neighbors) > 0 and neighbors != u'- none -':
            matrix[int(dev.address)] = neighbors
    except KeyError:
        pass
for key in sorted(matrix):
    indigo.server.log(u"{0}: {1}".format(key, matrix[key]))
and the output as run against my server:
3: 2, 4, 5, 8, 10, 11, 12, 13, 15, 16, 17, 18, 21, 22, 25, 27, 28, 29, 30, 39, 41
4: 2, 3, 5, 7, 8, 10, 11, 12, 13, 15, 16, 18, 20, 21, 22, 24, 25, 27, 28, 39, 41
5: 2, 3, 4, 8, 10, 11, 12, 13, 15, 16, 17, 18, 21, 22, 25, 27, 28, 29, 30, 39
7: 4, 8, 11, 12, 20, 23
8: 2, 4, 5, 7, 10, 11, 12, 13, 15, 20, 21, 23, 27, 28, 29, 30, 41, 42
10: 2, 3, 4, 5, 8, 11, 15, 16, 17, 18, 21, 22, 25, 27, 28, 30, 39, 41, 42
11: 3, 4, 5, 7, 8, 10, 12, 13, 15, 16, 20, 21, 22, 27, 28, 29, 39, 42, 44
12: 2, 3, 4, 5, 8, 10, 11, 13, 15, 16, 18, 20, 21, 22, 23, 24, 25, 28, 29, 39, 41, 42
13: 3, 4, 5, 7, 11, 12, 15, 16, 17, 21, 22, 24, 28, 29, 30, 39, 41, 42
14: 2, 3, 4, 5, 7, 8, 10, 11, 12, 15, 18, 20, 21, 22, 27, 28, 42
15: 2, 3, 4, 5, 8, 10, 11, 12, 13, 16, 17, 18, 21, 22, 25, 27, 28, 29, 39, 41
16: 2, 3, 4, 5, 10, 11, 12, 13, 15, 17, 22, 25, 27, 28, 29, 39, 41
17: 3, 5, 10, 13, 15, 16, 22, 27, 29, 30, 41
18: 2, 3, 4, 5, 8, 10, 12, 15, 21, 22, 25, 27, 28, 29, 39, 41
20: 8, 11, 23, 24
21: 2, 4, 5, 11, 12, 13, 15, 28, 29, 30
22: 2, 3, 4, 5, 10, 11, 13, 15, 16, 17, 21, 27, 28, 29, 30, 41
23: 2, 7, 8, 12, 20
24: 2, 4, 8, 12, 13, 20, 29, 39, 41
25: 3, 4, 5, 10, 12, 15, 16, 18, 27, 28, 29, 39, 41
27: 2, 3, 4, 5, 8, 10, 11, 15, 16, 17, 18, 21, 22, 25, 28, 29, 39, 41, 42
28: 3, 4, 5, 8, 10, 11, 12, 13, 15, 16, 17, 18, 21, 22, 25, 27, 29, 30, 39, 41
29: 2, 3, 4, 5, 8, 11, 12, 13, 15, 16, 18, 21, 24, 25, 27, 28, 30, 41
30: 2, 3, 5, 8, 10, 13, 16, 17, 18, 21, 22, 28, 29, 41
31: 2, 3, 4, 5, 8, 10, 11, 12, 15, 16, 17, 18, 20, 21, 22, 25, 27, 28, 29, 30, 39, 41
32: 2, 3, 4, 5, 6, 8, 10, 11, 12, 13, 15, 16, 17, 18, 21, 22, 24, 25, 26, 27, 28, 29, 30
33: 2, 3, 4, 5, 6, 7, 8, 10, 11, 12, 13, 15, 16, 17, 18, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30
34: 2, 3, 4, 5, 6, 8, 10, 11, 12, 13, 15, 16, 17, 18, 21, 22, 24, 25, 26, 27, 28, 29
37: 4, 7, 8, 11, 12, 15, 23
38: 2, 3, 4, 5, 6, 8, 10, 11, 12, 13, 15, 16, 17, 18, 20, 21, 22, 23, 24, 25, 27, 28, 29, 30
39: 2, 3, 4, 5, 10, 11, 12, 13, 15, 16, 17, 18, 27, 28, 29, 41
41: 2, 3, 4, 5, 8, 10, 12, 13, 15, 16, 17, 18, 21, 22, 24, 25, 27, 28, 29, 30, 39, 42
42: 11, 12, 13
44: 4, 5, 7, 8, 11, 12, 15, 20, 23, 41
Sun Jul 08, 2018 10:09 am
Umtauscher offline
and that's mine
3: 4, 10, 27, 28, 54, 57, 58, 59, 61, 62, 74, 76, 78, 80, 86, 122, 131, 133
4: 3, 10, 12, 27, 56, 58, 59, 61, 62, 74, 76, 78, 86, 97, 122, 131, 133
10: 3, 4, 12, 56, 58, 59, 60, 62, 74, 78, 80, 122, 133
12: 3, 4, 10, 27, 54, 56, 57, 58, 59, 60, 61, 62, 74, 78, 80, 86, 97, 122, 131, 133
27: 3, 4, 12, 28, 39, 50, 54, 56, 57, 58, 59, 60, 62, 74, 76, 78, 86, 97, 122, 131, 133
28: 27, 39, 50, 54, 56, 57, 58, 59, 60, 61, 62, 74, 76, 86, 97, 122, 131
39: 3, 27, 28, 50, 54, 56, 57, 58, 59, 60, 61, 74, 76, 86, 97, 122, 133
50: 27, 28, 39, 54, 56, 57, 58, 59, 60, 76, 86, 97
54: 3, 12, 27, 28, 39, 50, 56, 57, 58, 59, 62, 74, 76, 78, 80, 86, 97, 122, 131
56: 12, 27, 28, 39, 50, 54, 57, 58, 59, 60, 61, 74, 76, 86, 97, 122, 133
57: 3, 27, 28, 39, 50, 54, 56, 58, 59, 60, 62, 74, 76, 78, 80, 86, 97, 122, 131, 133
58: 3, 4, 10, 12, 27, 28, 39, 50, 54, 56, 57, 59, 60, 61, 62, 74, 78, 80, 86, 97, 103, 122, 131, 133
59: 3, 4, 10, 12, 27, 28, 39, 50, 54, 56, 57, 58, 62, 76, 86, 97, 122, 131, 133
60: 3, 10, 12, 27, 28, 39, 50, 56, 57, 58, 61, 62, 74, 76, 78, 80, 86, 97, 103, 122, 131, 133
61: 4, 12, 27, 28, 39, 56, 58, 60, 62, 74, 80, 86, 97, 103, 122, 131
62: 3, 4, 10, 12, 27, 28, 54, 57, 58, 59, 60, 61, 74, 78, 80, 86, 97, 103, 122, 131, 133
70: 3, 4, 10, 12, 27, 57, 58, 59, 60, 61, 62, 74, 78, 80, 86, 97, 122, 131, 133
74: 1, 3, 4, 10, 12, 27, 28, 54, 56, 57, 58, 59, 60, 62, 70, 73, 76, 77, 78, 80, 82, 85, 86, 97, 99, 102, 122, 124, 126, 127, 130
76: 4, 27, 28, 39, 50, 54, 56, 57, 59, 70, 74, 82, 84, 86, 94, 97, 100, 102, 104, 124, 126, 127
77: 1, 4, 10, 12, 27, 56, 58, 59, 60, 61, 62, 74, 78, 80, 86, 97, 122, 124, 131
78: 3, 4, 10, 12, 27, 54, 57, 58, 60, 62, 74, 80, 97, 122, 131, 133
79: 1, 3, 4, 9, 12, 22, 27, 39, 56, 58, 60, 61, 62, 63, 75, 78
80: 10, 12, 27, 57, 58, 60, 62, 74, 78, 86, 122, 133
82: 27, 28, 39, 50, 54, 56, 57, 59, 62, 76, 86, 97, 122
83: 1, 3, 27, 28, 39, 50, 54, 56, 57, 58, 59, 62, 78, 122, 131
84: 1, 3, 4, 9, 27, 28, 50, 54, 56, 57, 58, 59, 60, 61, 62, 76, 78, 86, 97
86: 3, 4, 12, 27, 28, 39, 50, 54, 56, 57, 58, 59, 60, 61, 62, 74, 76, 80, 97, 122, 131, 133
94: 27, 28, 39, 50, 54, 56, 57, 59, 76, 86, 97, 124
95: 1, 58, 60, 62, 122, 131
97: 4, 12, 27, 28, 39, 50, 54, 56, 57, 58, 59, 60, 61, 62, 74, 86, 122, 131
99: 1, 3, 58, 60, 61, 62, 63, 74, 78, 80
101: 1, 9, 27, 39, 54, 57, 58, 59, 62, 86, 97
102: 1, 3, 27, 28, 39, 54, 57, 58, 59, 74, 76, 86, 97
103: 12, 58, 60, 61, 62, 131
104: 27, 28, 39, 50, 54, 56, 57, 59, 76, 86, 124
105: 12, 27, 28, 39, 54, 56, 57, 58, 59, 60, 61, 62, 76, 86, 97, 114, 122, 131
107: 9, 12, 54, 58, 62, 63, 86, 97, 100
113: 1, 114
114: 3, 4, 9, 12, 27, 39, 50, 54, 56, 57, 58, 59, 62, 63, 74, 78, 80, 86, 97, 100, 113
122: 3, 4, 10, 12, 27, 28, 39, 54, 56, 57, 58, 59, 60, 61, 62, 74, 76, 78, 80, 86, 97, 103, 131, 133
124: 3, 4, 10, 12, 27, 28, 39, 50, 54, 56, 57, 58, 59, 60, 62, 74, 76, 78, 80, 86, 97, 122, 131, 133
127: 1, 3, 4, 9, 10, 12, 27, 28, 50, 56, 57, 58, 59, 60, 61, 62, 74, 76, 78, 80, 86, 97, 100, 122, 124
130: 1, 3, 9, 12, 58, 59, 60, 62, 74, 78, 80, 97, 100, 122
131: 3, 4, 12, 27, 28, 57, 58, 59, 60, 61, 62, 74, 78, 86, 97, 103, 122
133: 3, 4, 10, 12, 27, 58, 59, 60, 74, 78, 80, 122
135: 3, 4, 12, 27, 54, 57, 58, 60, 61, 62, 74, 78, 80, 86, 97, 122, 131
136: 3, 4, 12, 27, 28, 39, 54, 56, 57, 58, 59, 60, 61, 62, 78, 80, 86, 97, 122, 131
Sun Jul 08, 2018 11:24 am
There is considerable difference between the text and the image for Node 74.
Text:
Image:
74: 3, 27, 28, 39, 50, 54, 56, 58, 59, 60, 62, 76, 78, 80, 86, 97, 122, 131, 133
Did you force a new graphic to be generated? The matrix image won't update on its own.
Sun Jul 08, 2018 11:51 am
Umtauscher offline
Yes I can see that, but I triggered a refresh right befor I sent it.
Even now 4, 10 und 12 are missing. The timestamp on file is 19:31 her, so I know its new.
Is there anything that could be supressing those nodes - but they are visible on others...
Sun Jul 08, 2018 12:01 pm
Umtauscher offline
I just deleted the preferneces file and reinitialized it.
No difference on 74.. :(
I just wanted to rule out any side effects of the settings....
neighbors Kopie.png (32.37 KiB) Viewed 3789 times
Sun Jul 08, 2018 12:35 pm
There may be a bug in the plugin--I need to do some more digging. Here is a script that will generate a very simple matrix with no evaluation of the output. It will place the image on the server desktop.
Run this script within Indigo:
from os.path import expanduser
import matplotlib.pyplot as plt
import numpy as np
# Create a dict of all z-wave devices and their neighbor lists.
matrix = {}
        matrix[int(dev.address)] = dev.ownerProps['zwNodeNeighbors']
    except KeyError:
        pass
# Plot the matrix.
keys = matrix.keys()
for key in keys:
    for item in matrix[key]:
        plt.scatter(key, item)
plt.xticks(np.arange(1, max(keys) + 1, 1))
plt.yticks(np.arange(1, max(keys) + 1, 1))
plt.tick_params(axis='both', which='major', labelsize=8)
plt.savefig('{0}/Desktop/matrix.png'.format(expanduser("~")))
indigo.server.log(u'Saving image.')
It may not look as nice for installs with large address numbers.
Sun Jul 08, 2018 1:16 pm
Umtauscher offline
hmm, I think that's not what you expected?
Sun Jul 08, 2018 1:59 pm
That's because of the high node numbers you have (~140 of them). This version allows you to change the size of the output image.
import numpy as np
matrix = {}
    except KeyError:
        pass
# Plot the matrix.
for key in keys:
fig = plt.gcf()
fig.set_size_inches(20, 20)
If you need to make the image larger, change this line:
Sun Jul 08, 2018 2:42 pm
Umtauscher offline
The node 1 entry on device 60 is gone now, don't ask me why. I didn't do anything actively...
